$200 DELL 4220 1080p 4,100 Lumens HDMI 3D WiFi DLP Multimedia Projector + Mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-29-2016, 07:59 PM - Thread Starter
Liked: 0
DELL 4220 1080p 4,100 Lumens HDMI 3D WiFi DLP Multimedia Projector + Partial Mount
$200 plus shipping each. Located in New Jersey near Philly if you want to pick up locally.
I have 5 of these units acquired from a school auction and all have been tested and include a remote and power cable. The lowest hours is 408 and that will the be the first unit sold. The others are in the area of 1118-1400. Typical bulb life is 2500 hours. These are capable of producing a 25 foot diagonally measured screen at 10 meters. Please ask prior to purchase which unit you will receive as these are also listed for local sale. These were mainly used for instruction at a tech school, so they are in very good condition. They also include the projector side of the ceiling mount. A few do not have dust caps, so please assume your does not have one.
Detailed item info:
Description
The Dell 4220 can create bright, clear images due to its 2,000:1 contrast ratio and 4,100 lumens. In addition, this DLP projector comes with dual 5-watt speakers, is PC 3D-ready, and can even support 720p HD resolution. These features can truly get the attention of any audience since they improve both the sound and image of the presentation. Furthermore, the ports for USB, HDMI, S-video, and more all make it easy to use a variety of presentation-enhancing accessories with this Dell multimedia projector. Additionally, this device only weighs 6.4 lbs, and its dimensions are 11.26 x 4.33 x 9.76 inches. The small size makes it light enough to travel, whether to several different conference rooms or from one classroom to another. The Dell 4220 also comes with wireless connection capabilities so that several users of this DLP projector can connect. In general, the Dell 4220 is versatile since images can even show up clearly in a well-lit room, which makes it ideal for both business professionals and families who just want to watch movies together using a Dell multimedia projector.
Product Identifiers
Brand Dell
Model 4220
MPN 21036307
UPC 884116063025
Key Features
Display Technology DLP
Resolution 1024x768
Image Brightness 4100 ANSI Lumens
Contrast Ratio 2000:1
Image Aspect Ratio 4:3
Technical Features
Audio Output 3.5 mm Mini Jack, Speaker(s)
Miscellaneous
Features Built-In Speakers, Ceiling Projection, Keystone Correction, Rear Projection
ID:	1861665   Click image for larger version
ID:	1861673   Click image for larger version
phreaktor is offline
Reply Display Devices
4220 , Dell , dlp , projector , wifi
