SeymourAV CenterStage XD AT material 44x120. plus - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-05-2020, 06:58 PM - Thread Starter
cgott42's Avatar
Quoted: 264 Post(s)
Liked: 30
SeymourAV AT quality screen on the cheap
i bought a 50x120 piece of the material. had them fold and sew the bottom so that i could put a 10' metal rod for weight.
on the top i added a 1" velcro strip (facing the viewer) . then i just hung it and viola! huge screen.
it the bottom and velcro on top leave 44" of viewable screen height. and the full 12' width
i ended up reorganizing so i dont need AT.
but if you need AT this is about the best gain you can get.
you can cut to desired size. and also remove velcro if desired)
it's in great shape and gives a great picture (attached) only 1 slight dirt spot to the upper left shown in picture. i never noticed it during movies so it was a non issue and i was too scared anyway to wash it. but you could try.
Price. $120 shipped in US. (without the bar). or pick up and take the bar too. NY 10952
ID:	2694078   Click image for larger version
ID:	2694080   Click image for larger version
ID:	2694082   Click image for larger version
cgott42 is offline
Reply Display Devices
