Silver Ticket Screen? - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 202Likes
post #961 of 1684 Old 10-24-2016, 10:18 AM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
Originally Posted by busybe View Post
Thanks, will try to play around with focus and see if makes a difference. I have not seen any ST woven screen review with similar issue. I am in contact with ST and they have been extremely helpful so far
What happens is you have two patterns (projector SDE and screen fabric) that are very identical but not lined up perfectly.
jasonsong is offline
post #962 of 1684 Old 10-25-2016, 12:32 PM
busybe's Avatar
Quoted: 185 Post(s)
hmm, so you suggest de focusing may help? Or trying to move the screen/projector around to line up?
busybe is offline
post #963 of 1684 Old 10-25-2016, 02:00 PM
Quoted: 4383 Post(s)
Liked: 1616
So, did more testing. It is not my projector as paper test was negative. I tried flipping the screen upside down, no difference. Attached are couple pics of what I am talking about. The lines are everywhere, no matter the distance.
A high resolution camera will always show the patterns especially if you zoom in. The question is whether the patterns are visible to the naked eye at the normal viewing distance.
Dominic Chan is online now
post #964 of 1684 Old 10-26-2016, 04:35 AM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
It will be hard to line up. Actually being too close to lined up is the problem. If they had the pattern at an angle, you wouldn't have the problem.
Defocusing the projector reduces one of the pattern.
post #965 of 1684 Old 10-26-2016, 07:18 AM
brian6751's Avatar
Quoted: 1675 Post(s)
Liked: 1659
The pattern should be cut at an angle. I had confirmed that with ST when I was inquiring about purchasing from them.
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #966 of 1684 Old 10-26-2016, 07:35 AM
Liked: 1616
Yes, the fabric pattern should be cut at an angle to avoid moire pattern. However, if the OP is seeing the fabric patterns (weave lines) themselves, than the issue will remain regardless of the cut angle.
brian6751 likes this.
post #967 of 1684 Old 10-26-2016, 08:56 AM
busybe's Avatar
Quoted: 185 Post(s)
(the pics are not zoomed in) sorry, why would I put pics here if I do not see any patterns visible to naked eye?. naked eye is even worst than what you see through these pictures
busybe is offline
post #968 of 1684 Old 10-26-2016, 09:04 AM
busybe's Avatar
Quoted: 185 Post(s)
Thanks. So, did you have such a problem, or did you buy ST (acoustic transparent) screen?
So, if you think that the issue will remain regardless, where is the problem? My projector?
busybe is offline
post #969 of 1684 Old 10-26-2016, 09:10 AM
Liked: 1616
You previously said "It is not my projector as paper test was negative". Assuming "negative" means that you did not see the same lines on a piece of paper, then the only remaining explanation is that the screen weave is too coarse for the viewing distance.
post #970 of 1684 Old 10-26-2016, 09:26 AM
busybe's Avatar
Quoted: 185 Post(s)
Ok, thanks. Well the thing is, what I see, the distance does not matter, even at 16ft, I see the effect clearly- again, this is only visible in the lighter part of the scene/colors. For dark colors or dark scenes, it is just fine, no lines. so, not sure what it is. ST has been kind enough to mail another screen(to Canada). I will post again next week after I receive and test it.
busybe is offline
post #971 of 1684 Old 10-26-2016, 09:30 AM
brian6751's Avatar
Liked: 1659
I just called them to ask if their AT material was cut on a angle when I was shopping for screens. I did not buy a ST screen.
busybe likes this.
FOR SALE:
post #972 of 1684 Old 10-26-2016, 04:28 PM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
The problem is only when projected on the screen so it's when two patterns are on top of each other is when it's happening.
post #973 of 1684 Old 10-26-2016, 04:29 PM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
Do you know if your screen is rated for 1080p resolution?
post #974 of 1684 Old 10-26-2016, 04:41 PM
brian6751's Avatar
Liked: 1659
Mine is rated for 4k but could possibly go higher.
jasonsong likes this.
FOR SALE:
post #975 of 1684 Old 10-26-2016, 06:46 PM
Liked: 1616
That was why I suggested previously to de-focus the projector to see if the pattern remains visible. That would allow distinguishing projector issue from screen issue and moire interference patterns.
post #976 of 1684 Old 10-27-2016, 08:43 AM
busybe's Avatar
Quoted: 185 Post(s)
Yes, this is how they advertise -
Silver Ticket 100" Diagonal 16:9 4K Ultra HD Ready HDTV
busybe is offline
post #977 of 1684 Old 10-27-2016, 09:26 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 291
My Moire patterns on ST AT Screen disappeared completely when I upgraded to a 4K projector. (Quasi 4K actually, the Epson 5040)
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #978 of 1684 Old 10-27-2016, 09:55 AM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
Obviously, higher resolution will help significantly because the pixles would be smaller.
post #979 of 1684 Old 10-27-2016, 09:56 AM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
I would contact them.
post #980 of 1684 Old 10-27-2016, 10:11 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 291
If you want to test whether the weave angle could help in any way, take the projector and angle it incrementally to see if the Moire pattern improves or even disappears.
gnolivos is offline
post #981 of 1684 Old 10-27-2016, 10:23 AM
busybe's Avatar
Quoted: 185 Post(s)
Yes I have and they are sending another screen. They mentioned maybe the screen was not cut at a proper angle. I should receive it any day next week, so hopefully will be able to install and test it out by next weekend.
Yeah, maybe I should test it this way as well along with playing with the focus.
busybe is offline
post #982 of 1684 Old 10-27-2016, 02:39 PM
ereed's Avatar
Quoted: 2164 Post(s)
Liked: 1454
Throw a white sheet over the screen and see if you still see lines. If you do...its the projector, if not the its the screen. Some people see weave, some don't.
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is online now
post #983 of 1684 Old 10-27-2016, 03:07 PM
busybe's Avatar
Quoted: 185 Post(s)
I have tried white paper test and could not see those line on the paper.
busybe is offline
post #984 of 1684 Old 10-27-2016, 03:27 PM
ereed's Avatar
Liked: 1454
Ok, but try the sheet too so you can see whole big picture from where you sit. If everything looks good I recommend you get a better quality AT screen.
ereed is online now
post #985 of 1684 Old 10-27-2016, 04:21 PM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 291
It's Moire. Nothing else. I know this screen well and you have Moire. Defocus or get a 4K projector are your only realistic solutions. Or a better AT screen?
gnolivos is offline
post #986 of 1684 Old 10-27-2016, 07:22 PM
ereed's Avatar
Liked: 1454
Yes, appears to be moire from his zoomed in pics. Maybe a perforated screen would be best.
ereed is online now
post #987 of 1684 Old 10-27-2016, 08:16 PM
Liked: 1616
To me the lines look like the actual weave pattern rather than moire (you need to view the image at "1:1").
In any case, de-focusing the projector, or changing the zoom, will allow this to be confirmed for certain.
post #988 of 1684 Old 10-28-2016, 05:22 AM
gnolivos's Avatar
Quoted: 372 Post(s)
Liked: 291
Nope. It's Moire. I have this screen. That's what Moire looks like. You can stare at the screen with projector off and see nothing. Then project a white pattern and then Moire appears. Then zoom in or out and you can watch it 'move'
gnolivos is offline
post #989 of 1684 Old 10-28-2016, 06:45 AM
Liked: 1616
The posted pictures do show some mild "ripply" Moire pattern, but you can also see the much "tighter" pattern which would be the weave. I'm not sure which one the OP is referring to.
Yes, that would prove it without a doubt.
post #990 of 1684 Old 10-28-2016, 08:09 AM
busybe's Avatar
Quoted: 185 Post(s)
Thanks all. I think it has to do with projector's projection hitting the weave pattern in some odd way. The lines that I see,shows the weave across the whole screen on ligher scenes. I beleive I need to adjust both, the screen and the projector. I certainly need to do more testing, once the new screen arrives.
I tried to search reviews on amazon with people using the same screen and there is no complaint of moire, so I am assuming either the screen has not been cut at a proper angle or Epson 3000 and ST WAB screen are not a good match. I certainly cannot afford 4K projector @gnolivos . And I am not sure if I can return ST screen, so I have to find a closest solution that I can enjoy watching on my big screen .
busybe is offline
Reply Screens
