AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Screens (https://www.avsforum.com/forum/23-screens/)
-   -   Silver Ticket Screen? (https://www.avsforum.com/forum/23-screens/1499693-silver-ticket-screen.html)
Birdybog 11-14-2013 08:48 PM
Amazon has a Silver Ticket HDTV 16:9 120" Fixed Frame Projector Screen available at a very good price with excellent reviews but I can't find any reference to this screen anywhere in this forum. Is anyone here actually using one of these screens? I am building my multi-use basement and will be using a ceiling mounted BenQ W1070 projector. Any input would be appreciated. Thanks.
Cirrusclouds 01-18-2014 10:11 PM
I am interested in this too!
mdd770 01-20-2014 05:11 PM
We bought this screen on Amazon based on the reviews and the needs of the size and format. It certainly delivers.
The build quality is excellent. There were no instructions! so warning...it ended up being no big deal.
There is a 4 step list on the Amazon description in the ad for it, listed in the several images attached to the ad. Also there is a high speed build video on you tube that you can follow for it, if you do a search for this screen. In the video there is a cross bar that the 120 inch model doesn't have, and in the video it seems to come in more sections. Maybe the manufacturer made it with solid top and bottom so there was no more need for a center brace.
When you put the clips in that hold the screen, there are little arrows there for guidance as to where to place them. Use them, BUT don't be afraid to move them slightly here and there, once you are stretching the screen around and anchoring it. They may need to move to match the anchor holes so there is no binding of the material. Don't worry. The surface is flawless in the end.
Anyway, it took 1hr and 10 mins to build, but if I had to do it again, it would take about 30 mins now that I know how.
Hanging on the wall was a snap. It has sliding hooks so you can move the whole screen left and right after hanging on wall studs with screws and a level.
The black borders are really nice, with black velvet to catch any spill-over and it looks very good on the wall.
The picture quality is stunning in our opinion. We are using the BenQ 1070 projector, (also I highly recommend it too), a completely blacked out theater room, and the combination is awesome.
I recommend Gamma be set to 2.8 on the 1070 to really get the blacks dialed in.  We immediately invited over some friends who are in the market for a screen, played a snowboarding Blu Ray from Alaska ("The Art of Flight") , and they immediately went home and ordered it. Highly recommend!
It looks really really good. No problem with colors either.  Very vivid and rich picture in our opinion.
Hope that helps.
Waterbird 01-20-2014 05:34 PM
Apparently they are currently out of stock of the 120" which is what I need. Any idea how to reach out to them and know if there will be any additional offerings on Amazon? Based on what I've seen I'm interested in this screen as well.
Birdybog 01-20-2014 06:29 PM
MDD770 - Thanks for the reply. I went ahead and bought one back in December. I just finished painting so I plan on putting it together this weekend. I will make sure I look at all the info you referenced.
Waterbird - Keep watching the site. I had the same thing happen then they came back available a few days later.
Socio 01-21-2014 02:23 PM
I was looking at these screens as well the Silver Ticket 106" Curved Frame 2.35:1 Projection Screen in particular, not much information on them but from the images on Amazon the curve looks fairly subtle. My projector can do 2.35:1 but does not have a polymorph lens not sure if it will work but is near $300 less than the non-curved 107 inch 2.35:1 Carada screen I was about to pull the trigger on, so tempted to try it.
Waterbird 01-21-2014 03:25 PM
Well for some reason I checked on the 120" this morning and it said 2 available so I pulled the trigger. At $270 (+free shipping with Prime!) I couldn't beat it. Worst case I send it back and be out some time. In my old house I had an 84" Carada that I absolutely loved. Was originally going down that track and decided to try a more inexpensive approach. Was thinking Jamestown and Elite but really wanted this one - luckily it became available. Can't wait!
pjb16 01-21-2014 07:52 PM
Just ordered a 92" based on the reviews on Amazon. Got my fingers crossed that I'll really like it when I get everything set up (hopefully before the super bowl).
cval44 01-24-2014 05:46 AM
I bought one of these about a month ago and could not be happier. The tension system works great and no waves or creases. Be careful putting the center bar in that was the hardest part and I almost messed up the whole screen doing so. (Leave space between the tabs to be able to maneuver the center rod.
I also emailed these guys and they were very quick to answer any question.
imbloodyskint 01-24-2014 06:14 AM
comojoe 01-25-2014 07:11 PM
I just put together the 120" version. Didn't have a center piece to go across middle like that show in the video. Small mark on screen, so I will have to send back to get another one. Quality is good though and velvet wrapped frame is nice.
Waterbird 03-27-2014 06:32 PM
Finally got my 120" screen up. Very easy to assemble, didn't take very long. No wrinkles, screen tensioned out well. The picture is great! I HIGHLY recommend this screen. Good workmanship. Solid build. Again, great picture! Can't believe I was going to spend north of $1,000 when I got this for a fraction. Money well spent.
ShapS 10-23-2014 02:44 PM
pictures anyone?
sitehighyi 10-23-2014 11:35 PM
sitehighyi 10-23-2014 11:37 PM
Was originally going down that track and decided to try a more inexpensive approach. Was thinking Jamestown and Elite but really wanted this one - luckily it became available. Can't wait! http://www.gg.gg/3bpp2
Flatnate 10-26-2014 07:25 AM
Has anyone ever compared their acoustically transparent woven material to others on the market? Impressions?
smokarz 10-27-2014 11:24 AM
No pictures in a screen thread? Lol
merkaba 10-27-2014 12:30 PM
Yea...pictures and more info would be awesome from people who have purchased these.
merkaba 10-27-2014 04:47 PM
how do these screens stay tensioned? Is it velcro or buttons or something else?
ben_g99 10-28-2014 05:41 PM
I have the 112" fixed screen (16:9) and I love it. I was previously using a DIY custom spandex screen.
Here's a good image to show how the screen stays tensioned. http://silverticketproducts.com/prod...TR/image05.png
As others have mentioned, it really is great quality stuff and easy to put together.
EDIT: MORE IMAGES
http://silverticketproducts.com/guid...ace_lug_01.jpg
http://silverticketproducts.com/guid...aterial_02.jpg
http://silverticketproducts.com/guid..._screen_01.jpg
merkaba 10-28-2014 06:44 PM
thanks a lot man....looks nice!
smokarz 10-29-2014 04:16 PM
Thanks for posting the pics ben_g99
I too am currently using a DIY spandex screen and looking to change. What are the differences you observed with this Silver Screen?
Edit: Looks like the price dropped recently? $250 shipped, with prime, for a 120" screen. This will be very hard to beat, even by DIY standards. Unless you're painting with a bucket of paint on your wall ;)
smokarz 10-29-2014 04:59 PM
FYI.
A very nice review from a credible blogger, WITH measurements.
Now, I am really itching to try this screen out.
http://thewirecutter.com/reviews/best-projector-screen/
socal swagger 10-30-2014 02:45 PM
I have the opportunity to go bigger given the bigger iam buying. I have a 120 jamestown and posted for sale looking at 150 silver ticket thru amazon. Question now is how is the quality and ease of assembly of the ST. Unit
merkaba 10-30-2014 04:50 PM
From everything I've read (click some links in this thread and look at amazon reviews) it's a very good quality screen and easy to setup (1 person can do it easily).
socal swagger 10-30-2014 05:30 PM
Wow forgive the spelling auto correct and thumb typing are horrible on my S5.
Regarding the ST. I might take the chance thru amazon. Iam torn between the st and the elite sable
Foos-Man 10-31-2014 05:16 AM
I ordered screen material samples of both the ST and Elite screens and they appear identical with my Benq W1070. Hard to tell on the small samples the uniformity, etc. ST material is thicker, while Elite a bit purer white versus a hint of gray tones in the ST. I can't decide either which one to buy! ST seems to be the same screen as what Monoprice sells and I'm huge Moniprice fan. Elite screen material got favorable reviews.
dabsabre 10-31-2014 03:03 PM
I contacted ST and they're out of samples at the moment. Is this weave visible from 10.5'
Foos-Man 11-04-2014 04:54 AM
Material is pretty smooth, no noticeable weave even up close...it is more vinyl like than something like a woven material.
powersquad 11-14-2014 01:34 PM
Is Silver Ticket screen just as good as a Carada Brilliant White screen? Frame made of good quality? Price difference between the two brands is a fair bit.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
