Reasonably priced 150" 16:9 grey screen for room with some ambient light? Or should I just got with a white screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-01-2014, 10:39 AM - Thread Starter
steve71's Avatar
Quoted: 81 Post(s)
Liked: 53
I have a dark corner (14x21ft) of an open, ~2,000sqft space in our walkout basement. This space is mostly for the kids and entertaining/gaming, so it has to work during the daylight hours. It's the back corner of the basement, so it's reasonably dark to begin with - probably too dark to read a book without a light on, unless it was a really good book and you really wanted to read it biggrin.gif. There is no direct sunlight or windows in this part of the room either. Right now the walls are a light color, but I think I'll be repainting this section of the room a reasonably dark color.
The PJ is most likely the Optoma HD25-LV which should give me 21fL according to PJ central.
I want 3D to work well, but I'm not sure if I should be looking at a grey screen (due to ambient light) or a high gain screen for 3D.
Elite screens look good and well priced, but they don't appear to sell a 150" 16:9 grey screen.
Budget is $500-600 and I would prefer a fixed screen.
steve71 is offline
post #2 of 3 Old 01-01-2014, 02:59 PM
Greg_R_STL's Avatar
Quoted: 24 Post(s)
Liked: 31
I would say, be very careful with entry level gray screens. A true high contrast gray screen is something you are going to have to pay more for. At the $500 range, you are simply going to get a screen that is going to make your image dimmer, that's all. Stick with the white screen at that price range.
By the way, I've tested the HD25-LV, and you are going have no problems with ambient light. LV stands for Living room, and they mean it. That thing is a light cannon.
steve71 likes this.
Greg_R_STL is offline
post #3 of 3 Old 01-02-2014, 11:46 AM - Thread Starter
steve71's Avatar
Quoted: 81 Post(s)
Liked: 53
Thanks for that Greg. I ordered up the Elite screens 150" in their cinewhite material. Guess I can get some blinds or curtains if the ambient light is too much.
steve71 is offline
Reply Screens
Optoma Hd25 Lv 3d Home Theater Projector
