A short review of my new Stewart Cima Neve screen - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #31 of 106 Old 05-22-2019, 12:38 PM
Craig Peer's Avatar
Quoted: 7107 Post(s)
Liked: 8442
Originally Posted by m0j0 View Post
I upgraded my projector and now thinking of upgrading my screen. I currently have a Silver Ticket 110" 16x9 screen but considering a 115" 2.35:1 Stewart Cima Neve screen. What is the surface texture like on your CIMA? I feel like the Silver Ticket surface texture is perhaps becoming a limiting factor now for me since upgrading my projector (upgraded from an Optoma UHD60 to a Sony 695ES).
Send me an email and I'll send you a sample. Compare them in person - there is no better way ! " A picture tells 1000 words " as they say !
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #32 of 106 Old 05-22-2019, 01:55 PM
m0j0's Avatar
Quoted: 672 Post(s)
Liked: 691
Thanks! PM Sent.
m0j0 is offline
post #33 of 106 Old 05-24-2019, 09:20 PM
drober30's Avatar
Quoted: 74 Post(s)
Liked: 32
I would definitely lean toward spending the extra money and buying a Stewart Cima Neve screen but I want thin bezels and I'm sure the Balón Borderless™ for Home Cinema will be priced way outside what I'm willing to spend.
That leaves me looking at Dragonfly Thinline or Silver Ticket Thin Bezel which is pretty inexpensive compared to the others.
drober30 is offline
post #34 of 106 Old 05-25-2019, 08:22 AM
Craig Peer's Avatar
Liked: 8442
Originally Posted by drober30 View Post
I would definitely lean toward spending the extra money and buying a Stewart Cima Neve screen but I want thin bezels and I'm sure the Balón Borderless for Home Cinema will be priced way outside what I'm willing to spend.
The Cima Neve frame, while not a thin bezel, is on the narrower side.
post #35 of 106 Old 05-25-2019, 09:13 AM
drober30's Avatar
Quoted: 74 Post(s)
Liked: 32
I downloaded the spec sheet at it shows them at 2.5" which is significantly larger that the .5 dimensions I'm seeing on the thin boarder frames. My current Carada screen has a 2" flate bezel and 1 3/4" angled portion to the screen, overall it it has a pretty wide appearance.
I saw Elite’s EDGE FREE® technology 100" screen for $350, I'm curios to know how that would compare with picture quality of the Stewart. It seems the price of screens really go up if you need to buy the screen type that combats ambient or room lightning issues.
drober30 is offline
post #36 of 106 Old 05-25-2019, 10:30 AM
Craig Peer's Avatar
Liked: 8442
Get screen samples and compare. I'm not really a fan of the thin bezel screens. If you ever want to overscan onto the frame for one reason or another, you can't. And yes - ALR screens tend to be more expensive, and IMO, have compromises VS a white screen and a dark light controlled room. There is no free lunch as they say.
post #37 of 106 Old 05-25-2019, 12:03 PM
drober30's Avatar
Quoted: 74 Post(s)
Liked: 32
I have a light controlled basement area so a 1.0 - 1.3 gain white screen will work and if I understand correctly, provides the best picture? I wish I could see a thin frame or zero edge in person. Amazon has the Elite so I guess I could return it if I'm not happy.
I do know what you mean, having the felt boarder does assist with not having to fit the picture at 100% perfect, I think I need to really take that into consideration!
drober30 is offline
post #38 of 106 Old 05-28-2019, 10:53 AM
Craig Peer's Avatar
Liked: 8442
In my opinion, yes, a quality 1.0 - 1.3 gain white screen will provide the best picture in a light controlled room. I switched from gray to white 5+ years ago, and couldn't be happier !
post #39 of 106 Old 06-07-2019, 03:10 PM
satfam's Avatar
Quoted: 75 Post(s)
Liked: 64
Like others, I replaced my old HCCV with the Cima Neve that Craig recommended. Couldn’t be happier. It’s amazing how much clearer and detailed the images look. Thanks Craig.
Don Stewart likes this.
H/T: Marantz 7702MK II, MM8077, MM7055, Triton 2s, SCXL, SL/SR-S50s, BL/BR-S50s, H/W-4 Sat3s, dual SB16 Ultras, JVC DLA-RS2000, Stewart Cima Neve 110", Tivo Bolt, PS-3, Apple 4K TV, GIK Acoustics treatments, Panasonic UB820
Gameroom: Denon AVR-X4500H, Emotiva 2-T1’s, C1, 2 B2’s, 4 NHT ceiling speakers, 2 Velo SPL-1000R, Sony XBR85X900F, PS4 Pro, Tivo Bolt,Oppo 203
satfam is offline
post #40 of 106 Old 06-08-2019, 07:17 PM
Quoted: 300 Post(s)
Liked: 76
I'm looking at this screen to go with my JVC X590R in my family. I do have some ambient light coming into the room that I can control. So would this be a good choice?
jsil is offline
post #41 of 106 Old 06-11-2019, 04:05 PM
drober30's Avatar
Quoted: 74 Post(s)
Liked: 32
Will you post pictures, I would like to see how wide the bezels/frame is.
I’m deciding between the Cima or something with a thin bezel like the Dragonfly Thinframe.
drober30 is offline
post #42 of 106 Old 06-11-2019, 07:33 PM
satfam's Avatar
Quoted: 75 Post(s)
Liked: 64
Cima Neve
The bezel is about 2 3/4” wide. It’s a nice looking screen.
satfam is offline
post #43 of 106 Old 06-11-2019, 08:16 PM
Don Stewart's Avatar
Quoted: 174 Post(s)
Liked: 194
Here is a link to see and/or download a drawing of 123" diag 16:9 Cima screen frame.
https://www.stewartfilmscreen.com/Fi...0900-X123H.pdf
Hope that helps.
Don
Manufactures of Precision Professional Projection Screens.
An ISO 9001:2015 Certified Company.
UL GREENGUARD Certified For Environmentally Friendly Products.
http://www.stewartfilmscreen.com/
Don Stewart is offline
post #44 of 106 Old 06-11-2019, 08:43 PM
drober30's Avatar
Quoted: 74 Post(s)
Liked: 32
Yes, that looks very nice! Thanks!
Hope that helps.
Don
Very helpful, Thanks!
drober30 is offline
post #45 of 106 Old 06-12-2019, 08:41 AM
Steve Sleeve's Avatar
Quoted: 84 Post(s)
Liked: 32
So screen sizes in Dalite and Silver Ticket I am looking at this would be 2K more is it justifiable? Is there anything in the middle
Denon AVR-X6500h Klipsch RP-8000f RP-440C (4) RP-150MS sides in parallel RB-51 rears, 4 JBL C67P pendants for atmos, 2 monolith 12" subs
Epson 5040UB, Sony Ubp-X700, AC infintiy T9, Nvidia Shield, 142" 2.35 silver ticket screen
Steve Sleeve is offline
post #46 of 106 Old 06-13-2019, 09:26 AM
Craig Peer's Avatar
Liked: 8442
The Cima Neve won't cost more than a Da Lite HD Pro screen, which would be the only Da Lite material I'd use for 4K projection ( and is comparable to the Cima Neve ). I haven't seen a Silver Ticket screen myself.
post #47 of 106 Old 08-15-2019, 12:28 PM
rjmcinnis's Avatar
Quoted: 28 Post(s)
@Craig Peer Those pics of movies from your theater look great on that screen! Do you have any pics of your theater with the lights on to see how much light attenuation you are using?
Media Room: 7.1.4 Receiver- Lexicon RV-9 Atmos Amp- Emotiva A-500 Speakers- Revel 228Be/C208/S16/C763 Subwoofer- SVS SB-3000 Projector- JVC NX-7
rjmcinnis is offline
post #48 of 106 Old 08-15-2019, 12:45 PM
Craig Peer's Avatar
Liked: 8442
Do you just want photos of the theater walls / environment ?
rjmcinnis likes this.
post #49 of 106 Old 08-15-2019, 01:46 PM
rjmcinnis's Avatar
Quoted: 28 Post(s)
@Craig Peer
Yes that would be great, thanks!
post #50 of 106 Old 08-15-2019, 02:25 PM
Craig Peer's Avatar
Liked: 8442
@Craig Peer
The lights are cranked up and the picture somewhat over-exposed . The walls that aren't black are painted Sherwin Williams Garrett Grey, which is fairly dark .
Name:	Stewart Cima Neve 2.jpg
ID:	2603286   Click image for larger version
Name:	Revised speaker mounting 1.jpg
ID:	2603288   Click image for larger version
Name:	Revised speaker mounting 3.jpg
ID:	2603296   Click image for larger version
Name:	Revised speaker mounting 6.jpg
Webmonkey and rjmcinnis like this.
post #51 of 106 Old 08-15-2019, 03:12 PM
rjmcinnis's Avatar
Quoted: 28 Post(s)
@Craig Peer So you have a lot of dark in the front to attenuate, but have a bright couch and glass table, and your pics still show nice and dark with no apparent stray light. Hopefully mine will work like that. My concern is my carpet is only Tan. But my walls and ceiling are dark brown. (WILL be actually, haven't had it painted yet, waiting for the wiring install throughout the room)
post #52 of 106 Old 08-16-2019, 09:55 AM
Craig Peer's Avatar
Liked: 8442
My carpet was tan too. I had a giant edge bound " rug " made out of black carpeting. Also, the couch isn't quite as bright as it looks in the photos. Having all the overhead lights cranked makes it look brighter than in person in normal lighting.
post #53 of 106 Old 08-18-2019, 12:58 PM
Webmonkey's Avatar
Quoted: 175 Post(s)
Liked: 47
Which of those screen materials in 1.1 would be best for a JVC X30 (or a JVC N7)? - from what I can tell, the Da Lite 1.1 is also in a "high contrast" version with 20% ambient light rejection.
- I really like the UTB frame bezel from Da-Lite -look more like a modern high end TV
Webmonkey is offline
post #54 of 106 Old 08-18-2019, 02:03 PM
Craig Peer's Avatar
Liked: 8442
I prefer the Cima Neve myself. But get samples and see which works best for you.
post #55 of 106 Old 08-18-2019, 03:27 PM
Quoted: 25 Post(s)
Liked: 3
Craig, I also have light carpet and would like to get a black carpet edge bound. Where did you find the black carpet and who can do the edges? Also, did you make or purchase the sound deadening panels on the back wall? Room looks great!!
sablack2 is offline
post #56 of 106 Old 08-19-2019, 11:41 AM
Craig Peer's Avatar
Liked: 8442
I was lucky that I worked in construction for 20 years. I had my old carpet contractor source the carpet and have it edge bound. I'd suggest finding a carpet / flooring contractor - residential or commercial if need be. I picked the darkest least reflective carpet he could find ( might have been Shaw Carpeting ).
The acoustic panels are 2' x 4' from GIK. https://www.gikacoustics.com/
post #57 of 106 Old 08-19-2019, 01:18 PM
Webmonkey's Avatar
Quoted: 175 Post(s)
Liked: 47
What do I do, if I am not able to get samples and not able to demo it in-store.?
post #58 of 106 Old 08-19-2019, 02:19 PM
Craig Peer's Avatar
Liked: 8442
There are no Stewart dealers in Denmark ?
post #59 of 106 Old 09-25-2019, 07:53 AM
Webmonkey's Avatar
Quoted: 175 Post(s)
Liked: 47
How much daylight leaks through or around your curtains?
post #60 of 106 Old 09-25-2019, 08:00 AM
Craig Peer's Avatar
Liked: 8442
Almost zero. I have foam board cut to fit the window openings, plastic slat blinds and the drapes over each window.
Reply Screens
