Elunevision or other? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By ProjectionHead
  • 1 Post By Thrillho
post #1 of 6 Old 01-13-2016, 05:50 AM - Thread Starter
Pedro6's Avatar
I'm looking to purchase a motorized tab-tensioned screen to be paired with a Benq ht2050. Since I am in Canada, I have been looking at the Elunevision models. This is my first projector/screen setup which will be installed in a dark basement living room. Is there a great difference between a Elunevision Titan Tab-Tension vs the Elunevision Reference Studio 4k Tab Tension for roughly $400 more? Does anyone recommend any other manufacturer other than Elunevision without spending more than $1200? I am shopping in the 106" to 112" range.
Pedro6 is offline
post #2 of 6 Old 02-29-2016, 11:31 AM
Liked: 0
hey pedro6,
did you order an elunevision titan screen and if you did how do you like it? I'm looking at the titan 120" cinemawhite
lord humungous is offline
post #3 of 6 Old 03-05-2016, 04:50 AM - Thread Starter
Pedro6's Avatar
Originally Posted by lord humungous View Post
hey pedro6,
I have not ordered my screen yet. I am however heavily leaning toward the Reference Studio 4K.
Pedro6 is offline
post #4 of 6 Old 03-14-2016, 02:55 PM
ProjectionHead's Avatar
Quoted: 153 Post(s)
Liked: 213
The reference 4k surfaces are the way to go with Elunevision. If you are in Canada, Eastporters.com are the (awesome) guys to contact for Elunevision.
If you are here in the states, I am your man . Let me know if you have any questions!
Pedro6 likes this.
ProjectionHead is offline
post #5 of 6 Old 07-05-2016, 01:32 PM
busybe's Avatar
Quoted: 185 Post(s)
Hello @Pedro6 and @lord humungous
Kindly share your experience if you ordered this screen. I am interested as well. Thanks a lot.
hey pedro6,
busybe is offline
post #6 of 6 Old 07-22-2016, 11:52 AM
Thrillho's Avatar
Quoted: 24 Post(s)
Liked: 36
I owned the Titan (106", White) and did not like it very much. It had a very defined texture and made the pixels stand out as well as sparkles on high brightness scenes. EluneVision/Eastporters had extremely good customer service and allowed me to upgrade to the Reference Studio 4k (108", white, fixed frame) and the difference was huge. The Reference fixed every issue I had with the Titan and provides a perfectly smooth, crisp image. Knowing what I know now, I would recommend skipping the Titan and going straight to the Reference Studio. Unless my room/lighting needs change, I cannot envision a scenario where I would ever need a screen upgrade.
busybe likes this.
Thrillho is offline
Reply Screens
