DreamScreen V6 UltraWeave AT Screen - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #31 of 246 Old 12-15-2016, 06:11 AM
Dirk44's Avatar
Quoted: 146 Post(s)
Liked: 47
I hope i find the time to replace the xd with the V6 at this weekend.
In the same time i go up from 14" to 19" curve in the my 150" screen
Dirk44 is offline
post #32 of 246 Old 12-15-2016, 06:18 AM
coolgeek's Avatar
Quoted: 1701 Post(s)
Liked: 947
Can't wait for your review on the difference between the XD and the V6
coolgeek is online now
post #33 of 246 Old 12-15-2016, 07:20 AM
Scott B's Avatar
Quoted: 35 Post(s)
Originally Posted by Lygren View Post
Frames are only available at dreamscreen.eu currently (for EU customers), but we are continously discussing if frames should be made available for US customers as well (via AVScience.com). However, if you really don't fancy the idea of either retrofitting your existing frame or DIY, please contact AVScience.com for a quote on any frame from DreamScreen.eu and we will certainly work with AVS in finding you a best possible price for the preferred frame! Motorised masking frames will be made available throught Q1 2017 by the way...
Very interested in finding out more about DreamScreens upcoming motorised masking screens. I have been wanting to invest in one for several years but the cost has always put me off. I almost pulled the trigger on a Carada motorised masking screen as their pricing was significantly less than other options, however, Carada is no longer offering masking screens.
Lygren likes this.
Scott B is offline
post #34 of 246 Old 12-15-2016, 11:13 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
Developing motorised masking that actually does not cost half a car while maintaining performance and connectivity is actually quite challenging. We have had several masking models up through, both (quite inexpensive) manual variants and motorised (quite expensive) ones, but we have yet to find the perfect "cost / performance" combo. Hopefully for our next revision we will succeed in doing so to a greater extent albeit the number of versions will be limited at first, starting off with a regular two way 16:9 -> 2.35:1 version. Controllable using IR, RS232 or cordless trigger.
Also, mr. @CINERAMAX is developing a Hi-End frame of his own that would accommodate the V6 material. Not much info yet in terms of availability, but I am sure this frame will be excellent both in terms of stability (Somfy motor ++) and craftsmanship (made in the US).
Proudly Representing DreamScreen.no // ScreenAcoustics.com // AT screens & more!
Founder AVforum.no // Norway´s leading AV community since 2002
Lygren is online now
post #35 of 246 Old 12-15-2016, 11:15 AM
CINERAMAX's Avatar
Quoted: 2273 Post(s)
Liked: 1292
Send a message via Skype™ to CINERAMAX
available right now but waiting for V6 Magnum.
CINERAMAX is offline
post #36 of 246 Old 12-15-2016, 11:22 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
AjAj Capt´n, it´s still in the works (and just for the record; it´s the "XL" version of the V6 he is referring to, 118 inches height instead of current 79 inch), hopefully ready sooner rather than later (ETA first samples in 2-3 weeks)...!
post #37 of 246 Old 12-15-2016, 11:36 AM
CINERAMAX's Avatar
Liked: 1292
It just happens that I have this 17 foot wide frame from My Old 2012 RealD 4k PH lab in Miami sitting at Alan's, synchronicity points to new lab in Miami for the Pimps of Immersive cinema during 2017 more and more.
post #38 of 246 Old 12-15-2016, 11:39 AM
Scott B's Avatar
Quoted: 35 Post(s)
Please keep this thread updated with new information regarding the masking screens when it becomes available. My current screen is a 120" wide 16:9 Screen Research CP2 screen that I have had for several years. Ideally I would like to replace it with a larger 140" wide 16:9 screen that offers masking with various stops down to 2.4:1.
Scott B is offline
post #39 of 246 Old 12-25-2016, 05:17 AM
Skylinestar's Avatar
Quoted: 1309 Post(s)
Liked: 268
Currently, I have the Draper Clarion frame. How do I glue the grip rails onto my frame? Is the glue included as well? I'm worried the screen tension will finally rip off the glue.
http://www.draperinc.com/projections...il/141/clarion
Skylinestar is offline
post #40 of 246 Old 12-25-2016, 05:49 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
@Skylinestar , you´d need to find a 14mm gap somewhere on the back of your frame, like on the second video here: http://dreamscreen.no/collections/pr...fit-all-system.
As for glue, we recommend Casco XtremeFix for our non US customers at 15 Euros per 300ml tube (Swedish company, glue can be purchased directly at DreamScreen.eu alongside the fabric), but if you´re located in the US I´m sure there is a lot of alternatives available that would work as well. I used this one last summer when I fitted some gutters to our Florida vacation home; http://www.homedepot.com/p/Gorilla-9...0003/206063265, it stuck quite well provided you give is some time to harden (10+ hours).
post #41 of 246 Old 01-28-2017, 08:42 AM - Thread Starter
Kain's Avatar
Quoted: 1976 Post(s)
Liked: 851
Would a 7-7.5 ft viewing distance be too close for a projection based setup even with a screen like the V6? Would screen and projector "artifacts" be too obvious?
Edit: What about with this projector: http://www.sony.com/electronics/projector/vpl-vz1000es
Kain is offline
post #42 of 246 Old 01-29-2017, 02:42 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
In my typical space constrainted room of about 12 x 20 feet in total I´m seated about 8 feet off of my 11 feet wide scope screen on the first row, currently using an Epson 10K laser projector. The fabric will reveal very little artifacts from such a close perimeter, but the content needs to be top notch and the projector a variant of LCOS or perhaps DLP to avoid screen door being visible... From my second "row" I am seated about 12 feets off of the 11 feet screen, and I guess that would be a more optimal distance if I did have more space to spare... So; you could be seated as close as 7-7,5 ft, but optimally - not primarily based on the screen fabric though - I guess some added distance would be beneficial if possible!
As for that Sony laser, never seen that generation of it, but the previous generation did look very cool. However, I have not studied what potential issues might be apparant on using such a lens, but I guess that´s a better topic for another thread...
post #43 of 246 Old 01-30-2017, 04:35 PM
GoCaboNow's Avatar
Quoted: 914 Post(s)
Liked: 813
At some point I would like to replace my 10' wide 2.8 high power screen with an 11' wide AT. What lumens are you getting from your Epson and what power do you have to run it at? Low, medium or high IIRC?
My first row is about 10.5' from the screen but I may have to come forward a foot or two to place the speakers behind the screen which would put my layout similar to yours.
Lygren likes this.
RS600, 133" 2.8 HP Screen, Panasonic UB-900
Marantz, 7702MKII, Emotiva XPA-1, XPA-2, XPA-100's
7.2.4 with 4pi JBL LCR's, Athena 100 surrounds and 4x Volt 10lx ceiling speakers.
4x FI 18" IB subwoofage with Behringer EP400 amp
Fabric walls, fabric posters, fabric under soffets. No reflections!!
GoCaboNow is offline
post #44 of 246 Old 01-31-2017, 02:46 PM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
The Epson 10k replaced a JVC x5000 (rs400), and I guess if it was not for the laser source I'd rather use the x5000 still... Have not had the time to calibrate or measure yet, but in my batcave light output is perfectly acceptable at medium laser, although the x5000 outputs significantly more light even at low lamp...
GoCaboNow likes this.
post #45 of 246 Old 02-01-2017, 01:26 AM
Quoted: 128 Post(s)
Liked: 38
Hey Lygren,
is it possible to order and ship a sample to India by any chance ?
Lygren likes this.
abinav555 is offline
post #46 of 246 Old 02-01-2017, 02:52 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
Originally Posted by abinav555 View Post
Hey Lygren,
Sure, samples of various sizes can be ordered directly from this page: http://dreamscreen.no/collections/fr...bric-a5-sample.
post #47 of 246 Old 05-23-2017, 01:58 PM - Thread Starter
Kain's Avatar
Liked: 851
Is it possible to make a stand for the UltraFrame so it can stand on its own in front of the speakers? If so, any recommendations/pointers on how to go about this?
Lygren likes this.
Kain is offline
post #48 of 246 Old 05-24-2017, 01:09 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
Sure, we can make out custom stands that would allow you to place the frame in front of the speakers.
However, our clear recommendation would be to rather have a look at our new FlexiBaffle v2 system. Using a flexible steel stud system in combination with our ProSilence line of decoupling clips and U-boats it enables you to make out a completely decoupled front baffle wall at any size and depth. There are numerous advantages with these baffle walls both acoustically and visually. We expect the first shipment of these new studs in 6-8 weeks and we will go ahead and make installation videos as soon as they arrive.
Also, we´re still working on the motorised masking systems. In our past experience we have found that a modular approach, allowing the customer to purchase and install masking and frame separately would be the best solution. As such, our first solution will most likely be a 1-way 16:9->2.40:1 top down masking that would also allow you to close the masking all the way down to protect the screen when not in use. We are also working on a 2.40:1->16:9 2-way system based on the same principles. These items, however, might take some time to get to market but we certainly hope to have them ready for sale by the end of 2017. The current UltraFrame is, however, a very nice frame too, but will not accommodate masking.
I have included some 3D renders as well as some photos of our prototype FlexiBaffle installation here at our headquarters!
Name:	BaffleWall_V2_alcons_lightup(no scene)_2017-05-24_0954.jpg
ID:	2152666   Click image for larger version
ID:	2152674   Click image for larger version
ID:	2152682   Click image for larger version
Name:	Screen Shot 2017-05-23 at 18.05.50.png
ID:	2152690   Click image for larger version
Name:	Screen Shot 2017-05-23 at 18.05.37.jpg
ID:	2152706   Click image for larger version
Name:	Screen Shot 2017-05-18 at 12.32.11.jpg
ID:	2152714   Click image for larger version
Name:	Screen Shot 2017-05-18 at 12.31.54.jpg
ID:	2152722   Click image for larger version
Name:	Screen Shot 2017-05-18 at 12.32.02.jpg
Dirk44 likes this.
post #49 of 246 Old 05-26-2017, 03:18 PM - Thread Starter
Kain's Avatar
Liked: 851
Not too sure about the baffle wall for my room. My room is quite small (about 15 ft long x 12 ft wide x 9.5 ft high) and has the entrance door on one of the side walls right next the screen (adjacent to the screen). I'm planning on moving the screen out of the way when not in use in order to avoid obstructing the door too much. Could you highlight some of the details on the custom stand you mentioned? What will its feet look like? Something like this? I will require feet that are not too long.
Kain is offline
post #50 of 246 Old 05-26-2017, 03:52 PM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
OK, get it, not the atypical batcave installation, but still I´m sure this will end up quite nicely Kain! Sure, such a stand is possible to custom make, albeit not with the short throw fixture as part of the stand I´m afraid. I´m also tempted to advice you to rather have a look at in-ceiling types of tensioned screens. We´re currently not supplying such a solution using our AT fabrics, but it is certainly something we will be looking into later on for these types of installations...
So; stand is "supplyable", the short throw projection section is not. 15 feet length will limit you in terms of throw and screen size using a regular projector, an alternative might be the Sony short throw laser @ 25K, but that might be out of budget? I´ve seen this particular Sony at the IFA show and I have to say it does throw a very impressive image at a very short throw, native 4K and laser powered. Just wish the price tag was a bit friendlier...
I guess you could say we´ve been mainly occupied with developing and producing the AT screen materials thus far. Going forward we will try to accommodate more framing as well as tensioned solutions using our AT material though, but first priority will be motorised masking for framed screens and as such designing solutions that are easily serviceable and modular.
Sorry for not being able to present you with a better suited solution for your particular room Kain, your challenge for getting a good image would also be the fact that most short throw projectors, with the exception if the particular Sony I mentioned, will not provide a very good image quality either. Perhaps you should consider a regular front projection system after all and rather move down in size somewhat? The JVC DLA-X5000 / 7000 / 9000-series, for example, throws an superior picture, but will be limited to about 120" diagonal (about 270cm image width) in your particular setting. That would still be an impressive size in your room in my opinion and allows you to get at least the short throw projector out of the equation... Still, in your particular case you might also want to consider placing the speakers on each side of the screen and rather use an in-ceiling casing with the very best non-AT material there is; my suggestion being the Stewart Studiotek 100 - my personal favourite for non-AT screens by a huge margin... Good luck!!
post #51 of 246 Old 05-26-2017, 04:17 PM - Thread Starter
Kain's Avatar
Liked: 851
Thanks again.
I posted that picture to show the stand, not the short throw projection section. The projector will be at the back of the room on the back wall. I actually will require an AT screen as I am quite sure I'll end up with three JBL M2s as LCR. The screen size I am looking at is around 100" (diagonal) 16:9.
Lygren likes this.
Kain is offline
post #52 of 246 Old 05-27-2017, 12:45 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
Thanks again.
Ah, then I take back everything I said... M2s are great speakers, and if you do want to use an AT screen, the UltraWeave V6 has basically been designed with the performance of my favourite non-AT fabric, the Studiotek 100, as a guideline (well, not as a product as such I should probably add, the UltraWeave is totally different in terms of overall buildup, but in terms of its non-speckled, D65 neutral, finely structural and gain neutral appearance), and in my humble (I am almost tempted to say unbiased, but I guess that´s a hard sell... ) opinion the current very best AT fabric available out there. I do see a number of competitors trying now to compensate for the structural issue of regular weave jumping fence to knit / spandex. Although knit has some very nice features, the problem is its softening of the image. This was why we - at our 3. gen - moved from knit to weave - and on our 5. gen found the now patented method of combining these fabrics. Another advantage with the UltraWeave is that AT is at reference levels, which is certainly an important factor when using speakers at the level you are considering. Please also remember that AT is reduced at lower SPL. This is a fact that we will place more emphasis on for future measurements of AT. Especially relevant in terms of comparing to regularly perfed (nano or micro) PVC fabrics, but also in comparison to other weaved fabrics as some alternatives tend to try to increase their gain at the cost of AT which might measure a drop of 4dB @ 20KHz @ 90dB, but at 70dB the drop might double, thus stealing micro details at a far more excessive level than one would originally think based on specs. By other words, the AT level is a very very important part of an acoustical transparent fabric design and should be as low as possible. In terms of AT, spandex, as long as it is not too heavy, is quite good in that regards. We have made out our "spandex" / knit portion of the fabric in a very special manner to further improve both gain and AT. We use a more open mesh facing audio and closer mesh facing video, improving AT at each layer by about 0,1-0,2dB @ 90dB as well as improving gain and sharpness even further.
Also, in comparison to other alternatives, please also notice the integrated black backing. This is really an important part of the design too; leaving even a slight gap of 1/10 of a mm, it will cause light bleed and as such reduced sharpness as well as halo - especially important in highly contrasted objects in dark scenes. Dropping the black backing is neither a good choice unless the fabric is very thick, as it washes out contrast - even when the backing compartment is totally black.
Probably enough technical talk for now - albeit I do feel it is important to try to explain the advantages of the UltraWeave V6 rather too often than too seldom as a lot of people seems to tend to forget about some of the arguments that we did spend so much time and effort working into this fabric...
So, yes, the stand is certainly possible to make for you, not sure if we can get the wheels on it, but we´ll try. Please send an e-mail to info @ dreamscreen . no for further details.
DavidK442 likes this.
post #53 of 246 Old 05-27-2017, 01:09 PM - Thread Starter
Kain's Avatar
Liked: 851
Awesome. Thanks a lot for all the info.
I agree with you that if I were to get a solid/non-AT screen, my top choice would be the StudioTek 100. Good to know it was the "standard" or basis for the V6 to match. I will send you guys an email when I am closer to purchasing the screen. By the way, I won't require wheels for the stand.
Lygren likes this.
Kain is offline
post #54 of 246 Old 05-31-2017, 09:51 AM
Mike Garrett's Avatar
Quoted: 12333 Post(s)
Liked: 9959
I always like playing with an Erector Set as a kid. https://en.wikipedia.org/wiki/Erector_Set
This looks like it would be fun to do.
Lygren likes this.
Mike Garrett is offline
post #55 of 246 Old 06-03-2017, 02:30 PM - Thread Starter
Kain's Avatar
Liked: 851
@Lygren
This one might be more complex but will it also be possible for you guys to make a retractable version of the V6? I would prefer motorized but it could be manually operated/pulled-down as well. This will allow me to have a larger screen than if I went with a stand-mounted screen and I won't have to move the screen out of the way when not in use due to the room layout (as I'll just have to retract/pull-up the screen).
Lygren likes this.
Kain is offline
post #56 of 246 Old 06-04-2017, 03:19 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
@Kain ; unfortunately not right now, but it's certainly not an impossibility, just a matter of where to place the resources right now... The V6 material, being bonded and including the black backing as part of the buildup, is actually very suited for a motorised / tensioned setup...
post #57 of 246 Old 06-06-2017, 09:31 AM
Quoted: 21 Post(s)
Liked: 3
Hi, I just ordered a sample of the V6 Dreamscreen and am looking for a ~160-180 2.35:1 screen. But I could not find any of the masking solutions on the website. Are there any manual or automatic 2.35:1 -> 1.78:1 masking solutions for the V6 Dreamscreen UltraFrame available yet?
Lygren likes this.
landonin is offline
post #58 of 246 Old 06-06-2017, 10:08 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
Hi landonin, and thanks for ordering that sample. Customers located in the US should rather contact the US distributor directly for samples; www.avscience.com. We'll halt your sample shipment until further notice, just send us an e-mail info AT dreamscreen . no if AVS is out of samples (we'll resupply them shortly in such case)!
As for the masking screens, these are currently not available, hopefully by Q4 this year we will be able to supply them to US customers (through AVScience). These are motorised at first (Somfy RTS motors), we might offer a manual version later on. 1-way 16:9 -> 2.40:1 AT masking that can be rolled all the way down when screen is not in use, or 2-way 2.40:1->16:9 dual motor system (also Somfy). Modular system allowing for frame / fabric purchase first, then masking whenever later on...
Still, please remember that AVS is also able to supply universal grip rails that would fit basically any frame out there; perhaps you can find a nice used multi masking frame online and rather retrofit the V6 fabric using the grip rails for example?
post #59 of 246 Old 06-10-2017, 02:12 AM
jaychatbonneau's Avatar
Quoted: 302 Post(s)
Liked: 75
What kind of extinction ratio did you achieve with this material?
jaychatbonneau is offline
post #60 of 246 Old 07-21-2017, 05:06 PM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
We will be showing the new MotoMask V2 masking system at CEDIA 2017 in San Diego 7.-9. of September for anyone interested, in combination with the new PRO XXL revision of the UltraWeave V6. The frame will be a 16:9 native, 1-way masked screen that enables both 2.40:1 masking as well as totally closing down the masking fabric to protect the screen when not in use. Image size is about 15 1/2 feet wide... More info coming soon!
Please see a short video from our initial 3D-printed prototype here:
. The frame displayed at the show will be our first solid steel made prototype, but based on our testing thus far it should work wonders!
So, again, modular system, you can purchase and install the frame + fabric first and later on install the masking roller system. Somfy top grade motor that allows control through just about any system out there (Crestron etc.), but a basic Somfy RF (RTS) remote is included that would allow you to set top, 2.40:1 and shut.
Reply Screens
