Learn/Program Elite Screen IR remote into Universal Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-09-2017, 08:36 AM - Thread Starter
clhug's Avatar
Quoted: 31 Post(s)
Liked: 5
Has anyone been able to successfully do this? I just bought an Elite Screens Starling Tab Tension 2 electric screen. It comes with both an IR and RF remote. I have a universal IR remote already (old Philips Pronto TSU 7000, I know it's ancient but it works well for me).
I'm trying to learn the Elite Screen IR remote into my Pronto, but it just will not learn. The pronto software just comes back and says "Failed to learn the IR code". I can learn from other normal device remotes just fine. Is there something special about the Elite IR remote that makes it difficult or impossible to have a universal remote learn the codes?
clhug is offline
post #2 of 11 Old 03-09-2017, 09:08 PM
Quoted: 1938 Post(s)
Liked: 1131
Have you tried the various learning techniques?
1. Hold button down while learning - most common method
2. single quick press of button
3. Place you hand or something that blocks the Pronto from receiving the other remotes signal. Set the Pronto to learn. Press the button on the Elite remote and hold it down. While it is being held down remove tour hand or whatever is blocking the two remotes from seeing each other.
4. double tap
The Pronto does have a limited frequency range for IR and it is possible the other remote is out of its range. Try those methods I mentioned if you haven't already and see if it works.
Ellebob is offline
post #3 of 11 Old 09-08-2019, 05:45 PM
randman's Avatar
Quoted: 60 Post(s)
Sorry to revive this old thread, but I also just got an Elite Screens Starling Tab Tension 2. Can you post the Up, Down, and Stop codes if you got them to work? I have the Pronto TSU9400 that I'd like to use.
randman is offline
post #4 of 11 Old 09-09-2019, 06:41 PM
bluer101's Avatar
Quoted: 676 Post(s)
Liked: 931
I believe these are from when I had my pronto.
UP
0000 006D 0018 0000 0030 0011 0030 0011 0030 0011 0030 0011 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0030 0011 0010 053E 0030 0011 0030 0011 0030 0011 0030 0011 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0030 0011 0010 053E
STOP
0000 006D 0018 0000 0030 0011 0030 0011 0030 0011 0030 0011 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0030 051E 0030 0011 0030 0011 0030 0011 0030 0011 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0030 051E
DOWN
0000 006D 0018 0000 0030 0011 0030 0011 0030 0011 0030 0011 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0030 0011 0010 0031 0010 053E 0030 0011 0030 0011 0030 0011 0030 0011 0010 0031 0010 0031 0010 0031 0010 0031 0010 0031 0030 0011 0010 0031 0010 053E
bluer101 is online now
post #5 of 11 Old 09-10-2019, 05:13 PM - Thread Starter
clhug's Avatar
Quoted: 31 Post(s)
Liked: 5
I never did get it working by "learning". The "learn" failed every time I tried it. Thanks @bluer101 for the codes. I'll have to give that a try.
clhug is offline
post #6 of 11 Old 09-12-2019, 05:05 AM
evanft's Avatar
Quoted: 96 Post(s)
Liked: 43
I know this post was originally asking about a different remote, but the Elite screen remote is available in the Harmony database now. Up, down, stop all work great.
JVC RS-520, Elite Screens 16x9 100", XY Screen 2.4:1 115"
Klipsch RP-8000F, RP-450C, 2xRP-240S, 2xRP-402S, 2xSVS PB-1000
Denon AVR-X3200W/HDFury Linker/MiniDSP 2x4 HD
Panasonic UB820/PC/PS3/PS4 Pro/Switch/WiiU/Xbox One X/Original Xbox
Logitech Harmony Hub
evanft is offline
post #7 of 11 Old 10-20-2019, 12:00 PM
randman's Avatar
Quoted: 60 Post(s)
I just got an Elite Screens Starling Tab-Tension 2 Series CineGrey 5D screen. I tried the codes posted earlier in this thread (on my Pronto TSU9400), and they don't work.
I also have a Harmony hub & 950 remote. evanft - when adding the screen, what did you use for the manufacturer (I assume "Elite Screens")? What did you use for the model name?
FYI, I was able to teach my Pronto TSU9400 the Elite screen commands. The codes are very long, so maybe they're not a very clean "learn". But they do work reliably for me. The codes are below. If anyone has "cleaner" codes that they know work, please post them.
UP
FFFF 14E0 0100 0008 804B 505C 5608 0515 60F0 2640 5692 60F0 2540 56AB 604D 8540 FA8E 60F0 2640 56AC 604D 8540 FAA7 604D 8740 FAA7 604D 8740 FAA7 604D 8740 FA8E 60F0 2640 56AB 604D 8540 FAA7 604D 8840 F9DE 604D 874B 88FF 63D1 0B40 7B6A 604D 8640 F0F9 60E5 FD40 546B 60E5 FB40 5452 604D 8640 F0E0 604D 8840 F0E0 604D 8840 F0F9 60E5 FD40 5452 604D 8640 F190 604D 8740 F0E0 604D 8840 F0F9 60E5 FD40 546C 60E5 FA40 5453 604D 8540 F0FA 60E5 FC40 546C 60E5 FA40 546C 60E5 FB40 551B 60E5 FA40 546C 60E5 FA40 5453 604D 8540 F0E1 604D 8840 F0F9 60E5 FC40 5453 604D 8540 F0FA 60E5 FC40 546C 60E5 FA40 5502 604D 8640 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0DF 604D 8940 F0F8 60E5 FD40 5502 604D 8540 F0E1 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F18F 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0F8 60E5 FD40 5453 604D 8540 F0FA 60E5 FC40 546C 60E5 FA40 53EF 604D 864B 8786 6061 DC41 3756 612D 2340 6BC7 6061 DA41 3756 612D 2340 6BE0 612D 2140 6BDF 612D 2140 6BC7 6061 DA41 373D 6061 DC41 37ED 6061 DC41 373D 6061 DC41 373E 6061 DC41 3756 612D 2340 6BDF 612D 2140 6BE0 612D 2140 6BC6 6061 DA41 3757 612D 2240 6C76 6061 DA41 373E 6061 DC41 373D 6061 DC41 373D 6061 DD41 3756 612D 2340 6BDF 612D 2140 6BC7 6061 DA41 373D 6061 DC41 36D9 6061 DD4B 8721 60F0 2740 5692 60F0 2440 56AB 604D 8640 FA8D 60F0 2640 56AB 604D 8640 FAA6 604D 8840 FAA5 604D 8940 FAA5 604D 8840 FA8D 60F0 2640 56AB 604D 8640 FAA6 604D 8840 F9DD 604D 894B 88FC 63D1 0A40 7B69 604D 8740 F0F9 60E5 FC40 546B 60E5 FB40 5453 604D 8540 F0E0 604D 8840 F0E0 604D 8840 F0F8 60E5 FD40 5453 604D 8540 F18F 604D 8940 F0DF 604D 8840 F0F9 60E5 FC40 546C 60E5 FA40 5453 604D 8640 F0F9 60E5 FC40 546C 60E5 FA40 546C 60E5 FA40 551B 60E5 FA40 546C 60E5 FA40 5453 604D 8540 F0E0 604D 8840 F0F9 60E5 FC40 5453 604D 8540 F0FA 60E5 FC40 546C 60E5 FA40 5502 604D 8540 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0F8 60E5 FD40 5502 604D 8540 F0E0 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F18F 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0F9 60E5 FC40 5453 604D 8540 F0FA 60E5 FC40 546C 60E5 FA40 53EF 604D 854B 8785 6061 DC41 3756 612D 2240 6BC7 6061 DA41 3757 612D 2240 6BE0 612D 2040 6BE0 612D 2040 6BC7 6061 DA41 373E 6061 DB41 37ED 6061 DC41 373D 6061 DC41 373D 6061 DC41 3756 612D 2340 6BDF 612D 2140 6BE0 612D 2040 6BC7 6061 DA41 3756 612D 2240 6C76 6061 DA41 373E 6061 DC41 373D 6061 DC41 373D 6061 DC41 3756 612D 2240 6BE0 612D 2140 6BC7 6061 D941 373E 6061 DC41 36D9 6061 DC4B 8720 60F0 2640 5692 60F0 2540 56AB 604D 8540 FA8D 60F0 2640 56AC 604D 8540 FAA6 604D 8840 FAA5 604D 8840 FAA6 604D 8840 FA8C 60F0 2740 56AB 604D 8540 FAA6 604D 8840 F9DE 604D 884B 88FA 63D1 0A40 7B69 604D 8740 F0F8 60E5 FD40 546B 60E5 FB40 5452 604D 8640 F0E0 604D 8840 F0DF 604D 8840 F0F9 60E5 FC40 5453 604D 8540 F18F 604D 8840 F0E0 604D 8840 F0F8 60E5 FD40 546B 60E5 FB40 5452 604D 8640 F0F9 60E5 FC40 546C 60E5 FA40 546C 60E5 FA40 551A 60E5 FB40 546B 60E5 FA40 5453 604D 8540 F0E1 604D 8840 F0F8 60E5 FC40 5453 604D 8540 F0FA 60E5 FC40 546B 60E5 FA40 5502 604D 8640 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0E0 604D 8840 F0F8 60E5 FC40 5502 604D 8640 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F18F 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0F9 60E5 FC40 5453 604D 8540 F0F9 60E5 FC40 546C 60E5 FA40 53EF 604D 854B 8784 6061 DC41 3756 612D 2240 6BC7 6061 DA41 3756 612D 2240 6BE0 612D 2040 6BE0 612D 2040 6BC7 6061 DA41 373E 6061 DB41 37ED 6061 DB41 373E 6061 DB41 373E 6061 DB41 3757 612D 2240 6BE0 612D 2040 6BE0 612D 2040 6BC7 6061 D941 3757 612D 2240 6C76 6061 DA41 373D 6061 DC41 373D 6061 DC41 373D 6061 DC41 3756 612D 2240 6BE0 612D 2040 6BC7 6061 DA41 373E 6061 DB41 36DA 6061 DB4B 8783 60F0 2740 5692 60F0 2440 56AB 604D 8540 FA8D 60F0 2640 56AB 604D 8640 FAA6 604D 8840 FAA5 604D 8840 FAA6 604D 8740 FA8D 60F0 2640 56AB 604D 8640 FAA6 604D 8740 F9DE 604D 884B 88FA 63D1 0840 7B6A 604D 8640 F0F9 60E5 FC40 546C 60E5 FA40 5453 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0F9 60E5 FC40 5453 604D 8540 F18F 604D 8840 F0E0 604D 8840 F0F8 60E5 FC40 546C 60E5 FA40 5453 604D 8540 F0F9 60E5 FC40 546C 60E5 FA40 546C 60E5 FA40 551B 60E5 FA40 546B 60E5 FA40 5453 604D 8540 F0E0 604D 8840 F0F9 60E5 FC40 5453 604D 8540 F0F9 60E5 FC40 546C 60E5 FA40 5502 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0F9 60E5 FC40 5502 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F18E 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0F8 60E5 FC40 5453 604D 8540 F0F9 60E5 FD40 546B 60E5 FA40 53EF 604D 854B 8783 6061 DC41 3756 612D 2240 6BC7 6061 D941 3757 612D 2240 6BE0 612D 2040 6BE0 612D 2040 6BC6 6061 DA41 373E 6061 DB41 37ED 6061 DB41 373E 6061 DB41 373D 6061 DC41 3756 612D 2240 6BE0 612D 2040 6BE0 612D 2040 6BC7 6061 DA41 3756 612D 2240 6C76 6061 DA41 373D 6061 DC41 373D 6061 DC41 373D 6061 DC41 3756 612D 2240 6BE0 612D 2040 6BC7 6061 D941 373E 6061 DC41 36D8 6061 DC4B 871E 60F0 2740 5692 60F0 2440 56AB 604D 8640 FA8C 60F0 2640 56AB 604D 8640 FAA6 604D 8840 FAA5 604D 8840 FAA5 604D 8840 FA8C 60F0 2740 56AA 604D 8640 FAA6 604D 8840 F9DD 604D 884B 88F9 63D1 0940 7B69 604D 8640 F0F9 60E5 FC40 546C 60E5 FA40 5452 604D 8640 F0E0 604D 8840 F0DF 604D 8840 F0F8 60E5 FD40 5452 604D 8640 F18F 604D 8840 F0DF 604D 8840 F0F8 60E5 FD40 546B 60E5 FA40 5453 604D 8540 F0F9 60E5 FC40 546C 60E5 FA40 546B 60E5 FB40 551A 60E5 FA40 546C 60E5 FA40 5453 604D 8540 F0E0 604D 8840 F0F8 60E5 FC40 5453 604D 8540 F0F9 60E5 FC40 546C 60E5 FA40 5502 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F0F8 60E5 FC40 5502 604D 8640 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F18E 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0F9 60E5 FC40 5452 604D 8640 F0F9 60E5 FC40 546B 60E5 FA40 53EF 604D 854B 8782 6061 DC41 3756 612D 2240 6BC7 6061 DA41 3756 612D 2240 6BE0 612D 2040 6BE0 612D 2040 6BC6 6061 DA41 373D 6061 DC41 37EC 6061 DC41 373D 6061 DC41 373D 6061 DC41 3756 612D 2240 6BDF 612D 2140 6BDF 612D 2140 6BC6 6061 DA41 3756 612D 2240 6C76 6061 DA41 373D 6061 DC41 373D 6061 DC41 373D 6061 DB41 3756 612D 2240 6BE0 612D 2040 6BC7 6061 DA41 373D 6061 DC41 36D9 6061 DC4B 8704 60F0 2640 5692 60F0 2440 56AB 604D 8640 FA8C 60F0 2740 56AA 604D 8640 FAA6 604D 8840 FAA5 604D 8840 FAA5 604D 8840 FA8C 60F0 2640 56AB 604D 8640 FAA5 604D 8940 F9DC 604D 894B 88DF 63D1 0840 7B6A 604D 8640 F0F9 60E5 FC40 546B 60E5 FB40 5452 604D 8640 F0DF 604D 8840 F0DF 604D 8940 F0F8 60E5 FC40 5452 604D 8640 F18F 604D 8840 F0DF 604D 8840 F0F8 60E5 FD40 546B 60E5 FA40 5453 604D 8540 F0F9 60E5 FC40 546C 60E5 FA40 546B 60E5 FA40 551B 60E5 FA40 546B 60E5 FB40 5452 604D 8640 F0DF 604D 8840 F0F8 60E5 FD40 5452 604D 8640 F0F8 60E5 FD40 546B 60E5 FA40 5502 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8940 F0F8 60E5 FC40 5502 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F18E 604D 8840 F0DF 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0F8 60E5 FD40 5452 604D 8640 F0F8 60E5 FD40 546B 60E5 FA40 53EE 604D 864B 8768 6061 DC41 3756 612D 2240 6BC7 6061 DA41 3756 612D 2240 6BDF 612D 2140 6BDF 612D 2040 6BC7 6061 DA41 373D 6061 DC41 37EB 6061 DC41 373D 6061 DC41 373D 6061 DC41 3756 612D 2240 6BDF 612D 2140 6BDF 612D 2040 6BC7 6061 DA41 3756 612D 2240 6C75 6061 DA41 373D 6061 DC41 373D 6061 DC41 373D 6061 DC41 3756 612D 2240 6BDF 612D 2140 6BC6 6061 DA41 373D 6061 DC41 36D9 6061 DC4B 8767 60F0 2740 5692 60F0 2440 56AB 604D 8540 FA8D 60F0 2640 56AB 604D 8540 FAA6 604D 8840 FAA5 604D 8840 FAA5 604D 8840 FA8C 60F0 2640 56AB 604D 8640 FAA5 604D 8840 F9DD 604D 884B 88DF 63D1 0940 7B69 604D 8640 F0F9 60E5 FC40 546B 60E5 FB40 5452 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0F8 60E5 FD40 5452 604D 8640 F18E 604D 8840 F0E0 604D 8840 F0F8 60E5 FC40 546B 60E5 FB40 5452 604D 8640 F0F8 60E5 FD40 546B 60E5 FA40 546B 60E5 FB40 551A 60E5 FA40 546C 60E5 FA40 5452 604D 8640 F0DF 604D 8840 F0F8 60E5 FD40 5452 604D 8640 F0F8 60E5 FC40 546C 60E5 FA40 5501 604D 8640 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0F8 60E5 FC40 5502 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F18E 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0F8 60E5 FC40 5453 604D 8540 F0F9 60E5 FC40 546B 60E5 FB40 53EE 604D 854B 8768 6061 DC41 3756 612D 2240 6BC6 6061 DA41 3756 612D 2240 6BE0 612D 2040 6BE0 612D 2040 6BC6 6061 DA41 373D 6061 DC41 37EC 6061 DC41 373D 6061 DB41 373D 6061 DC41 3756 612D 2240 6BDF 612D 2140 6BDF 612D 2040 6BC7 6061 DA41 3756 612D 2240 6C75 6061 DA41 373D 6061 DC41 373D 6061 DC41 373D 6061 DB41 3756 612D 2240 6BE0 612D 2040 6BC6 6061 DA41 373D 6061 DC41 36D9 6061 DC4B 8703 60F0 2740 5691 60F0 2440 56AB 604D 8640 FA8C 60F0 2640 56AB 604D 8640 FAA5 604D 8840 FAA5 604D 8840 FAA5 604D 8840 FA8D 60F0 2640 56AA 604D 8640 FAA6 604D 8740 F9DE 604D 874B 88DF 63D1 0840 7B69 604D 8740 F0F8 60E5 FC40 546C 60E5 FA40 5452 604D 8640 F0E0 604D 8740 F0E0 604D 8840 F0F8 60E5 FC40 5452 604D 8640 F18F 604D 8840 F0DF 604D 8840 F0F8 60E5 FC40 546C 60E5 FA40 5452 604D 8640 F0F9 60E5 FC40 546B 60E5 FA40 546B 60E5 FB40 551A 60E5 FA40 546C 60E5 FA40 5452 604D 8540 F0E0 604D 8840 F0F8 60E5 FD40 5452 604D 8540 F0F9 60E5 FC40 546C 60E5 FA40 5501 604D 8640 F0DF 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0F9 60E5 FC40 5501 604D 8640 F0DF 604D 8840 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F18E 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0E0 604D 8840 F0F8 60E5 FC40 5452 604D 8640 F0F9 60E5 FC40 546B 60E5 FA40 53EF 604D 854B 8767 6061 DC41 3756 612D 2240 6BC7 6061 DA41 3756 612D 2240 6BDF 612D 2040 6BE0 612D 2040 6BC6 6061 DA41 373D 6061 DC41 37EC 6061 DC41 373D 6061 DB41 373D 6061 DC41 3756 612D 2240 6BDF 612D 2140 6BDF 612D 2040 6BC7 6061 DA41 3756 612D 2240 6C75 6061 DA41 373D 6061 DC41 373D 6061 DB41 373D 6061 DC41 3756 612D 2240 6BDF 612D 2140 6BC6 6061 DA41 373D 6061 DC41 36D8 6061 DC4B 8703 60F0 2740 5691 60F0 2540 56AA 604D 8640 FA8C 60F0 2640 56AB 604D 8640 FAA5 604D 8840 FAA5 604D 8840 FAA5 604D 8840 FA8C 60F0 2740 56AA 604D 8640 FAA5 604D 8840 F9DD 604D 884B 88DE 63D1 0840 7B6A 604D 8640 F0F8 60E5 FD40 546B 60E5 FA40 5452 604D 8640 F0DF 604D 8940 F0DF 604D 8840 F0F8 60E5 FC40 5452 604D 8640 F18F 604D 8840 F0DF 604D 8840 F0F8 60E5 FC40 546B 60E5 FB40 5452 604D 8640 F0F8 60E5 FC40 546C 60E5 FA40 546B 60E5 FA40 551B 60E5 FA40 546B 60E5 FA40 5452 604D 8640 F0E0 604D 8840 F0F8 60E5 FC40 5452 604D 8640 F0F8 60E5 FD40 546B 60E5 FA40 5501 604D 8640 F0DF 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0F8 60E5 FD40 5501 604D 8640 F0DF 604D 8840 F0DF 604D 8940 F0DE 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F18F 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0F8 60E5 FD40 5452 604D 8540 F0F9 60E5 FC40 546B 60E5 FB40 53EE 604D 854B 8767 6061 DC41 3756 612D 2240 6BC6 6061 DA41 3756 612D 2240 6BE0 612D 2040 6BDF 612D 2140 6BC6 6061 DA41 373D 6061 DC41 37EB 6061 DC41 373D 6061 DC41 373C 6061 DC41 3756 612D 2240 6BDF 612D 2140 6BDF 612D 2040 6BC7 6061 DA41 3755 612D 2340 6C75 6061 DA41 373D 6061 DC41 373C 6061 DC41 373D 6061 DC41 3755 612D 2340 6BDF 612D 2040 6BC7 6061 D941 373D 6061 DC41 36D9 6061 DC4B 8766 60F0 2740 5691 60F0 2540 56AA 604D 8640 FA8C 60F0 2740 56AA 604D 8640 FAA5 604D 8840 FAA5 604D 8840 FAA5 604D 8840 FA8C 60F0 2640 56AB 604D 8640 FAA5 604D 8840 F9DD 604D 884B 88DE 63D1 0840 7B69 604D 8640 F0F9 60E5 FC40 546B 60E5 FA40 5452 604D 8640 F0E0 604D 8840 F0DF 604D 8840 F0F8 60E5 FC40 5452 604D 8640 F18F 604D 8840 F0DF 604D 8840 F0F8 60E5 FC40 546B 60E5 FB40 5452 604D 8540 F0F9 60E5 FC40 546B 60E5 FA40 546C 60E5 FA40 551A 60E5 FA40 546C 60E5 FA40 5452 604D 8640 F0DF 604D 8840 F0F8 60E5 FD40 5452 604D 8540 F0F9 60E5 FC40 546B 60E5 FA40 5502 604D 8540 F0E0 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8940 F0DE 604D 8940 F0F8 60E5 FC40 5501 604D 8640 F0DF 604D 8940 F0DE 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F18E 604D 8940 F0DF 604D 8840 F0DF 604D 8840 F0DF 604D 8840 F0F8 60E5 FC40 5453 604D 8540 F0F9 60E5 FC40 546B 60E5 FA40 53EF 604D 854B 8767 6061 DC41 3755 612D 2240 6BC7 6061 DA41 3756 612D 2240 6BDF 612D 2040 6BDF 612D 2140 6BC6 6061 DA41 373D 6061 DC41 37EB 6061 DC41 373D 6061 DC41 373D 6061 DC41 3755 612D 2240 6BDF 612D 2140 6BDF 612D 2040 6BC7 6061 DA41 3755 612D 2240 6C76 6061 DA41 373D 6061 DC41 373C 6061 DC41 373D 6061 DC41 3755 612D 2240 6BE0 612D 2040 6BC6 6061 DA41 373D 6061 DC41 36D8 6061 DC4B 871C 60F0 2640 5692 60F0 2440 56AB 604D 8540 FA8D 60F0 2640 56AA 604D 8640 FAA5 604D 8840 FAA5 604D 8840 FAA5 604D 8840 FA8C 60F0 2640 56AB 604D 8640 FAA5 604D 8840 F9DD 604D 884B 88F6 63D1 0840 7B69 604D 8740 F0F8 60E5 FC40 546C 60E5 FA40 5452 604D 8640 F0DF 604D 8840 F0DF
DOWN
FFFF 1517 0100 0008 505C 5A08 0515 60F0 2640 5693 60F0 2540 56AC 604D 8540 FA8F 60F0 2640 56AC 604D 8540 FAA9 604D 8640 FA8F 60F0 2740 56AC 604D 8540 FAA8 604D 8740 FAA8 604D 8740 FAA8 604D 8740 F9DF 604D 874B 8909 63D1 0D40 7B6A 604D 8640 F0FB 60E5 FD40 546C 60E5 FB40 5453 604D 8540 F0E2 604D 8840 F0E1 604D 8840 F0FA 60E5 FD40 5453 604D 8540 F191 604D 8840 F0E1 604D 8840 F0F9 60E5 FE40 546C 60E5 FB40 5453 604D 8540 F0FB 60E5 FD40 546C 60E5 FB40 546C 60E5 FB40 551B 60E5 FB40 546C 60E5 FB40 5453 604D 8640 F0E1 604D 8840 F0FA 60E5 FD40 5453 604D 8640 F0FA 60E5 FD40 546C 60E5 FB40 5502 604D 8640 F0E1 604D 8840 F0E1 604D 8840 F0E0 604D 8840 F0E1 604D 8840 F0E1 604D 8840 F0E1 604D 8840 F0F9 60E5 FE40 5502 604D 8540 F0E1 604D 8940 F0E0 604D 8840 F0E1 604D 8840 F0E1 604D 8840 F0E0 604D 8940 F0E0 604D 8840 F0E1 604D 8840 F190 604D 8840 F0FA 60E5 FD40 5453 604D 8540 F0E1 604D 8840 F0E1 604D 8840 F0E1 604D 8840 F0FA 60E5 FD40 546C 60E5 FB40 53EE 604D 864B 878F 6061 DC41 3758 612D 2340 6BC7 6061 DA41 3758 612D 2340 6BE0 612D 2240 6BE0 612D 2140 6BC8 6061 D941 373F 6061 DC41 37EE 6061 DC41 373F 6061 DB41 373F 6061 DC41 3758 612D 2340 6BE0 612D 2140 6BE1 612D 2140 6BC7 6061 DA41 3758 612D 2340 6C90 612D 2140 6BE0 612D 2140 6BC8 6061 D941 3740 6061 DB41 373F 6061 DC41 373F 6061 DB41 373F 6061 DC41 373F 6061 DC41 36DB 6061 DB4B 872B 60F0 2740 5692 60F0 2540 56AB 604D 8640 FA8E 60F0 2740 56AB 604D 8640 FAA7 604D 8840 FA8E 60F0 2640 56AC 604D 8540 FAA7 604D 8840 FAA7 604D 8840 FAA7 604D 8740 F9DF 604D 884B 8905 63D1 0C40 7B6A 604D 8640 F0FB 60E5 FC40 546C 60E5 FB40 5453 604D 8640 F0E1 604D 8740 F0E2 604D 8740 F0FA 60E5 FD40 5453 604D 8540 F191 604D 8840 F0E1 604D 8740 F0FA 60E5 FD40 546C 60E5 FB40 5453 604D 8540 F0FB 60E5 FC40 546C 60E5 FB40 546C 60E5 FB40 551B 60E5 FB40 546C 60E5 FB40 5453 604D 8640 F0E1 604D 8840 F0F9 60E5 FD40 5453 604D 8640 F0FA 60E5 FD40 546C 60E5 FB40 5502 604D 8540 F0E1 604D 8840 F0E1 604D 8840 F0E0 604D 8940 F0E0 604D 8840 F0E1 604D 8840 F0E0 604D 8940 F0F9 60E5 FD40 5502 604D 8640 F0E1 604D 8840 F0E0 604D 8840 F0E1 604D 8840 F0E1 604D 8840 F0E0 604D 8840 F0E1 604D 8840 F0E0 604D 8840 F190 604D 8840 F0FA 60E5 FC40 5454 604D 8540 F0E1 604D 8840 F0E1 604D 8740 F0E1 604D 8840 F0FA 60E5 FC40 546D 60E5 FA40 53F0 604D 844B 878F 6061 DA41 375A 608F 9540 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 406B C960 61D8 4137 5A60 8A81 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 406B E360 5298 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D1 4003 D140 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 6BE3 6066 EB40 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 406B CA60 61D7 4137 4260 61D8 4137 F260 61D8 4137 4260 61D8 4137 4260 57AE 4003 D040 03D0 4137 5C60 57AD 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 406B E460 486E 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 6BE4 6034 1940 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 406B CB60 29EF 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D141 375C 6052 9840 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D2 4003 D240 03D2 4003 D240 03D2 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 406C 9460 29EF 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 6BE4 601F C540 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 406B CC60 2F03 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4137 4460 4359 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4137 4460 392F 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4137 4460 392E 4003 D040 03D0 4003 D040 03D0 4003 D040 03D1 4003 D140 03D1 4137 4460 4359 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 4137 4460 341A 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D041 36E0 602F 0440 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D14B 872E 603E 4440 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D340 03D3 4003 D240 03D2 4003 D340 03D3 4056 9860 1085 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4056 B060 0B70 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D2 4003 D240 FA94 6039 2E40 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D2 4003 D340 03D2 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 56B1 601A AF40 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 FAAD 602F 0440 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 FA93 6039 2E40 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 56B1 601A AF40 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 FAAD 6029 EF40 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 40FA AC60 3419 4003 D040 03D0 4003 D040 03D1 4003 D140 FAAC 6034 1A40 03D0 4003 D040 03D0 4003 D040 03D1 40F9 E560 29EF 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D04B 8909 6034 1A40 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 7B70 601A AF40 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 F100 601F C540 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4054 7140 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D440 03D4 4003 D440 03D4 4003 D440 03D4 4003 D440 03D4 4054 5940 03CF 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 40F0 E760 1FC5 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D240 F0E7 6024 DA40 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 F100 6024 DA40 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D240 03D3 4003 D340 03D3 4003 D440 03D3 4003 D440 03D4 4003 D440 03D4 4003 D440 5459 600B 6F40 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D2 4003 D240 03D2 40F1 9660 1AB0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 40F0 E760 29EF 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 F100 601A B040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D140 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 5471 4003 D040 03D0 4003 D040 03D0 4003 D040 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D240 03D3 4003 D340 03D3 4003 D340 03D3 4003 D440 03D4 4003 D440 03D4 4003 D440 03D4 4003 D440 03D4 4003 D440 03D4 4003 D440 03D4 4003 D440 5459 600B 6F40 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D2 4003 D240 03D2 40F1 0060 1FC5 4003 D040 03D0 4003 D040 03D0 4003 D040 03D0 4003 D040 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D340 03D3 4003 D340 03D4 4003 D440 03D4 4003 D440 03D4 4003 D440 03D4 4003 D440 5472 600B 7040 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4054 7240 03CF 4003 D040 03D0 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D1 4003 D140 03D2 4003 D240 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4055 2140 03CF 4003 D040 03D0 4003 D040 03D1 4003 D140 03D1 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D240 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4003 D340 03D3 4054 7140 03D0 4003 D040 03D0 4003 D040 03D0 4003 D140 03D1 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D2 4003 D240 03D3 4003 D340 03D3 4003 D340 03D4 4003 D340 03D4 4003 D4
STOP
FFFF 105A 0100 0008 8057 505C 2A08 0512 60EF B040 5668 60EF AD40 5681 604D 5F40 FA12 60EF B040 5681 604D 5E40 FA2C 604D 6140 FA2B 604D 6140 FA12 60EF AF40 5681 604D 5F40 FA2C 604D 6040 FA2C 604D 6040 F964 604D 614B 834F 63CF 2740 7B2E 604D 5F40 F083 60E5 8A40 5443 60E5 8940 5429 604D 5F40 F06B 604D 6040 F06A 604D 6140 F083 60E5 8A40 542A 604D 5F40 F119 604D 6040 F06B 604D 6040 F084 60E5 8A40 5443 60E5 8840 542A 604D 5E40 F084 60E5 8A40 5443 60E5 8840 5443 60E5 8840 54F2 60E5 8840 5443 60E5 8840 542A 604D 5E40 F06B 604D 6040 F084 60E5 8A40 5429 604D 5F40 F084 60E5 8A40 5442 60E5 8940 54D8 604D 5F40 F06A 604D 6140 F06A 604D 6040 F06B 604D 6040 F06B 604D 6040 F06B 604D 6040 F06A 604D 6140 F083 60E5 8A40 54D9 604D 5E40 F06B 604D 6040 F06B 604D 6040 F06A 604D 6140 F06A 604D 6140 F06A 604D 6040 F06B 604D 6040 F06B 604D 6040 F119 604D 6140 F06A 604D 6040 F084 60E5 8A40 542A 604D 5E40 F06B 604D 6040 F06A 604D 6140 F083 60E5 8A40 5443 60E5 8840 53C6 604D 5E4B 81D8 6061 AA41 36BF 612C 8C40 6B93 6061 A841 36BF 612C 8D40 6BAB 612C 8B40 6BAC 612C 8B40 6B92 6061 A941 36A6 6061 AA41 3754 6061 AA41 36A5 6061 AB41 36A5 6061 AA41 36BF 612C 8C40 6BAC 612C 8B40 6BAB 612C 8C40 6B92 6061 A941 36BE 612C 8D40 6C41 6061 A941 36A5 6061 AA41 36BE 612C 8D40 6BAC 612C 8B40 6B92 6061 A941 36A5 6061 AA41 36A6 6061 AA41 36A5 6061 AB41 3641 6061 AA4B 8173 60EF AF40 5668 60EF AD40 5681 604D 5F40 FA12 60EF AF40 5681 604D 5F40 FA2B 604D 6140 FA2B 604D 6040 FA13 60EF AE40 5681 604D 5F40 FA2B 604D 6140 FA2B 604D 6140 F963 604D 604B 834D 63CF 2640 7B2E 604D 5F40 F083 60E5 8A40 5443 60E5 8840 542A 604D 5E40 F06A 604D 6140 F06A 604D 6040 F084 60E5 8940 542A 604D 5F40 F119 604D 6040 F06A 604D 6140 F083 60E5 8A40 5442 60E5 8940 5429 604D 5F40 F083 60E5 8A40 5443 60E5 8840 5442 60E5 8940 54F1 60E5 8840 5443 60E5 8840 542A 604D 5E40 F06A 604D 6140 F083 60E5 8A40 5429 604D 5F40 F083 60E5 8A40 5443 60E5 8840 54D8 604D 5F40 F06A 604D 6140 F06A 604D 6040 F06A 604D 6140 F06A 604D 6040 F06A 604D 6140 F06A 604D 6040 F083 60E5 8A40 54D9 604D 5E40 F06A 604D 6140 F06A 604D 6040 F06B 604D 6040 F06A 604D 6140 F06A 604D 6040 F06A 604D 6140 F06A 604D 6040 F119 604D 6040 F06A 604D 6140 F083 60E5 8A40 542A 604D 5E40 F06A 604D 6140 F06A 604D 6040 F083 60E5 8A40 5443 60E5 8840 53C6 604D 5E4B 81D5 6061 AB41 36BE 612C 8C40 6B92 6061 A941 36BE 612C 8D40 6BAB 612C 8B40 6BAB 612C 8B40 6B93 6061 A841 36A5 6061 AB41 3754 6061 AA41 36A5 6061 AA41 36A5 6061 AA41 36BE 612C 8D40 6BAB 612C 8B40 6BAB 612C 8C40 6B92 6061 A841 36BE 612C 8D40 6C41 6061 A941 36A5 6061 AA41 36BE 612C 8D40 6BAB 612C 8B40 6B92 6061 A941 36A5 6061 AA41 36A5 6061 AA41 36A5 6061 AB41 3641 6061 AA4B 8170 60EF AF40 5668 60EF AD40 5681 604D 5F40 FA12 60EF AF40 5681 604D 5E40 FA2B 604D 6140 FA2B 604D 6040 FA12 60EF AF40 5681 604D 5F40 FA2B 604D 6040 FA2B 604D 6140 F963 604D 604B 834B 63CF 2640 7B2D 604D 5F40 F083 60E5 8A40 5443 60E5 8840 5429 604D 5F40 F06A 604D 6040 F06A 604D 6140 F083 60E5 8940 542A 604D 5E40 F119 604D 6140 F06A 604D 6040 F083 60E5 8A40 5442 60E5 8840 542A 604D 5E40 F084 60E5 8940 5443 60E5 8840 5443 60E5 8840 54F1 60E5 8840 5443 60E5 8840 5429 604D 5F40 F06A 604D 6040 F083 60E5 8A40 5429 604D 5F40 F083 60E5 8A40 5442 60E5 8840 54D9 604D 5E40 F06A 604D 6140 F06A 604D 6040 F06A 604D 6040 F06A 604D 6140 F06A 604D 6040 F06A 604D 6140 F082 60E5 8A40 54D9 604D 5E40 F06A 604D 6140 F06A 604D 6040 F06A 604D 6040 F06A 604D 6140 F06A 604D 6040 F06A 604D 6040 F06A 604D 6140 F118 604D 6140 F06A 604D 6040 F083 60E5 8A40 5429 604D 5F40 F06A 604D 6040 F06A 604D 6140 F083 60E5 8940 5443 60E5 8840 53C6 604D 5E4B 81D3 6061 AB41 36BE 612C 8C40 6B92 6061 A941 36BE 612C 8C40 6BAB 612C 8B40 6BAB 612C 8B40 6B93 6061 A841 36A5 6061 AA41 3754 6061 AA41 36A5 6061 AA41 36A5 6061 AA41 36BE 612C 8C40 6BAC 612C 8B40 6BAB 612C 8B40 6B92 6061 A841 36BE 612C 8D40 6C41 6061 A841 36A5 6061 AA41 36BE 612C 8D40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AB41 36A4 6061 AB41 36A4 6061 AB41 3641 6061 AA4B 81D3 60EF AF40 5667 60EF AD40 5681 604D 5F40 FA12 60EF AE40 5681 604D 5F40 FA2B 604D 6040 FA2B 604D 6140 FA12 60EF AE40 5681 604D 5E40 FA2C 604D 6040 FA2B 604D 6040 F963 604D 614B 8349 63CF 2540 7B2D 604D 5F40 F084 60E5 8940 5443 60E5 8840 5429 604D 5E40 F06B 604D 6040 F06A 604D 6040 F083 60E5 8A40 5429 604D 5F40 F119 604D 6040 F06A 604D 6040 F083 60E5 8A40 5442 60E5 8840 542A 604D 5E40 F083 60E5 8A40 5442 60E5 8840 5443 60E5 8840 54F1 60E5 8840 5443 60E5 8740 542A 604D 5E40 F06A 604D 6140 F083 60E5 8940 542A 604D 5E40 F083 60E5 8A40 5442 60E5 8840 54D9 604D 5E40 F06A 604D 6040 F06A 604D 6140 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F083 60E5 8A40 54D8 604D 5F40 F06A 604D 6040 F06A 604D 6040 F06A 604D 6140 F069 604D 6140 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F119 604D 6040 F06A 604D 6140 F082 60E5 8A40 542A 604D 5E40 F06A 604D 6040 F06A 604D 6140 F082 60E5 8A40 5443 60E5 8740 53C6 604D 5E4B 81D3 6061 AA41 36BE 612C 8C40 6B92 6061 A941 36BE 612C 8C40 6BAB 612C 8B40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 3754 6061 AA41 36A5 6061 AA41 36A5 6061 AA41 36BD 612C 8D40 6BAB 612C 8B40 6BAB 612C 8B40 6B92 6061 A841 36BE 612C 8C40 6C41 6061 A941 36A5 6061 AA41 36BD 612C 8D40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 36A5 6061 AA41 36A5 6061 AA41 3641 6061 AA4B 816E 60EF AF40 5667 60EF AD40 5681 604D 5E40 FA13 60EF AE40 5681 604D 5E40 FA2B 604D 6140 FA2B 604D 6040 FA12 60EF AE40 5681 604D 5E40 FA2C 604D 6040 FA2B 604D 6040 F963 604D 604B 8349 63CF 2440 7B2E 604D 5F40 F083 60E5 8940 5443 60E5 8740 542A 604D 5E40 F06A 604D 6140 F06A 604D 6040 F083 60E5 8940 542A 604D 5E40 F119 604D 6040 F06A 604D 6040 F083 60E5 8A40 5442 60E5 8840 542A 604D 5E40 F083 60E5 8940 5443 60E5 8840 5442 60E5 8840 54F1 60E5 8840 5443 60E5 8740 542A 604D 5E40 F06A 604D 6140 F082 60E5 8A40 542A 604D 5E40 F083 60E5 8940 5443 60E5 8840 54D8 604D 5E40 F06A 604D 6140 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F083 60E5 8940 54D9 604D 5E40 F06A 604D 6040 F06A 604D 6040 F06A 604D 6140 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F119 604D 6040 F06A 604D 6040 F083 60E5 8940 542A 604D 5E40 F06A 604D 6040 F06A 604D 6140 F082 60E5 8A40 5443 60E5 8740 53C6 604D 5E4B 81D1 6061 AA41 36BE 612C 8C40 6B93 6061 A841 36BE 612C 8C40 6BAB 612C 8B40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 3754 6061 A941 36A5 6061 AA41 36A5 6061 AA41 36BE 612C 8C40 6BAB 612C 8B40 6BAB 612C 8A40 6B93 6061 A841 36BE 612C 8C40 6C41 6061 A841 36A5 6061 AA41 36BE 612C 8C40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 36A5 6061 AA41 36A5 6061 AA41 3640 6061 AA4B 8155 60EF AE40 5668 60EF AD40 5681 604D 5E40 FA12 60EF AE40 5681 604D 5E40 FA2C 604D 6040 FA2B 604D 6040 FA12 60EF AE40 5681 604D 5E40 FA2B 604D 6140 FA2A 604D 6140 F963 604D 604B 832E 63CF 2540 7B2D 604D 5F40 F083 60E5 8940 5443 60E5 8740 542A 604D 5E40 F06A 604D 6040 F06A 604D 6040 F083 60E5 8A40 5429 604D 5E40 F119 604D 6140 F069 604D 6140 F082 60E5 8A40 5442 60E5 8840 542A 604D 5E40 F083 60E5 8940 5443 60E5 8840 5442 60E5 8840 54F1 60E5 8840 5442 60E5 8840 542A 604D 5E40 F06A 604D 6040 F083 60E5 8940 542A 604D 5E40 F083 60E5 8A40 5442 60E5 8840 54D8 604D 5E40 F06B 604D 6040 F069 604D 6140 F069 604D 6140 F069 604D 6140 F069 604D 6140 F069 604D 6140 F082 60E5 8A40 54D8 604D 5E40 F06B 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F118 604D 6040 F06A 604D 6040 F083 60E5 8A40 5429 604D 5E40 F06B 604D 6040 F06A 604D 6040 F083 60E5 8940 5442 60E5 8840 53C6 604D 5E4B 81B8 6061 A941 36BE 612C 8C40 6B92 6061 A941 36BE 612C 8C40 6BAB 612C 8A40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 3754 6061 AA41 36A4 6061 AA41 36A5 6061 AA41 36BE 612C 8C40 6BAB 612C 8A40 6BAB 612C 8B40 6B92 6061 A841 36BE 612C 8C40 6C41 6061 A841 36A5 6061 AA41 36BE 612C 8C40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 36A5 6061 A941 36A5 6061 AA41 3641 6061 AA4B 81B7 60EF AF40 5667 60EF AD40 5681 604D 5E40 FA12 60EF AF40 5680 604D 5F40 FA2B 604D 6040 FA2B 604D 6040 FA12 60EF AE40 5681 604D 5E40 FA2B 604D 6040 FA2B 604D 6040 F963 604D 614B 832D 63CF 2440 7B2E 604D 5E40 F083 60E5 8A40 5442 60E5 8840 5429 604D 5F40 F06A 604D 6040 F06A 604D 6040 F083 60E5 8940 5429 604D 5F40 F118 604D 6140 F069 604D 6040 F083 60E5 8A40 5442 60E5 8840 5429 604D 5F40 F083 60E5 8940 5442 60E5 8840 5443 60E5 8740 54F2 60E5 8740 5443 60E5 8740 542A 604D 5E40 F06A 604D 6040 F083 60E5 8940 542A 604D 5E40 F083 60E5 8940 5443 60E5 8840 54D8 604D 5E40 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F083 60E5 8940 54D8 604D 5F40 F06A 604D 6040 F06A 604D 6040 F069 604D 6140 F069 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F119 604D 6040 F06A 604D 6040 F083 60E5 8940 542A 604D 5E40 F06A 604D 6040 F06A 604D 6040 F083 60E5 8940 5443 60E5 8740 53C6 604D 5E4B 81B7 6061 AA41 36BD 612C 8C40 6B93 6061 A841 36BE 612C 8C40 6BAB 612C 8A40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 3753 6061 AA41 36A5 6061 AA41 36A4 6061 AA41 36BE 612C 8C40 6BAB 612C 8A40 6BAC 612C 8A40 6B92 6061 A841 36BE 612C 8C40 6C41 6061 A841 36A5 6061 AA41 36BE 612C 8C40 6BAB 612C 8A40 6B92 6061 A841 36A5 6061 AA41 36A5 6061 AA41 36A4 6061 AA41 3641 6061 AA4B 8153 60EF AE40 5668 60EF AC40 5681 604D 5E40 FA13 60EF AE40 5681 604D 5E40 FA2B 604D 6040 FA2B 604D 6040 FA12 60EF AE40 5681 604D 5E40 FA2B 604D 6040 FA2B 604D 6040 F963 604D 604B 832D 63CF 2440 7B2D 604D 5F40 F083 60E5 8940 5443 60E5 8740 542A 604D 5E40 F06A 604D 6040 F06A 604D 6040 F083 60E5 8940 542A 604D 5E40 F119 604D 6040 F06A 604D 6040 F082 60E5 8A40 5442 60E5 8840 5429 604D 5E40 F084 60E5 8940 5442 60E5 8840 5442 60E5 8840 54F1 60E5 8840 5442 60E5 8840 5429 604D 5F40 F06A 604D 6040 F082 60E5 8A40 5429 604D 5E40 F083 60E5 8A40 5442 60E5 8840 54D8 604D 5E40 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F082 60E5 8A40 54D8 604D 5E40 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F06A 604D 6040 F069 604D 6040 F119 604D 6040 F06A 604D 6040 F083 60E5 8940 542A 604D 5E40 F06A 604D 6040 F06A 604D 6040 F082 60E5 8A40 5442 60E5 8840 53C5 604D 5F4B 81B6 6061 AA41 36BD 612C 8C40 6B92 6061 A941 36BD 612C 8C40 6BAB 612C 8B40 6BAB 612C 8A40 6B92 6061 A941 36A4 6061 AA41 3754 6061 A941 36A5 6061 AA41 36A5 6061 A941 36BE 612C 8C40 6BAB 612C 8A40 6BAB 612C 8B40 6B92 6061 A841 36BE 612C 8C40 6C41 6061 A841 36A5 6061 AA41 36BD 612C 8C40 6BAB 612C 8B40 6B92 6061 A841 36A5 6061 AA41 36A4 6061 AA41 36A5 6061 A941 3641
randman is offline
post #8 of 11 Old 11-03-2019, 07:57 AM - Thread Starter
clhug's Avatar
Quoted: 31 Post(s)
Liked: 5
Thanks for trying, but none of these codes from either post work with my TSU7000.
The first set of, shorter, codes paste in but just don't work.
The second set of long codes crash my Pronto NG software when I paste them in and click either Test or click OK to try to save it.
clhug is offline
post #9 of 11 Old 05-09-2020, 02:06 AM
Liked: 0
Codes inside !
hello all,
happy owner of a 2019 Screen Elite Sakler tab screen, the Elite Screen IR remote started acting yesterday evening.
I found this post, was happy to see codes to use in my Pronto but ... they didnt work for me.
Luckily, i've (re) changed batteries in the original ES IR remote, and sometimes the UP button works .... The 2 other buttons do work fine, so I assume sh*** remote (model: ZSP-IR-W, version 3.0).
I will have worked fine only a year of moderate and careful usage so... not great.
So... I've happily scanned the codes with the Pronto, and tested them and they work !!
Here they are below, hopping they will help some of us
Up:
0000 006F 0040 0020 002F 0012 002E 0012 002E 0012 002E 0012 0011 002E 0011 002E 0011 002E 0011 002F 0011 002E 0011 002E 002E 0012 0011 002E 0011 002E 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 0011 002E 002E 0012 0011 002E 002E 0012 0011 002E 0011 002E 002E 0459 002E 0012 002E 0012 002E 0012 002E 0012 0011 002E 0011 002E 0011 002E 0011 002F 0011 002E 0011 002E 002E 0012 0011 002E 0011 002E 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 0011 002E 002E 0012 0011 002E 002E 0012 0011 002E 0011 002E 002E 0459 002E 0012 002E 0012 002E 0012 002E 0012 0011 002E 0011 002E 0011 002E 0011 002F 0011 002E 0011 002E 002E 0012 0011 002E 0011 002E 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 0011 002E 002E 0012 0011 002E 002E 0012 0011 002E 0011 002E 002E 175E
Down:
0000 006F 0000 0020 002E 0012 002E 0012 002E 0012 002E 0012 0011 002E 0011 002E 0011 002E 0011 002E 0011 002E 002E 0012 0011 002E 0011 002E 0011 002E 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 002E 0012 002E 0012 0011 002E 0011 002E 002E 0012 0011 002E 0011 002E 002E 0459
Stop:
0000 006F 0000 0020 002E 0012 002E 0012 002E 0012 002E 0012 0011 002E 0011 002E 0011 002E 0011 002E 0011 002E 0011 002E 0011 002E 002E 0012 0011 002E 002E 0012 0011 002E 002E 0012 002E 0012 002E 0012 0011 002E 0011 002E 002E 0012 002E 0012 0011 002E 0011 002E 0011 002E 002E 0012 002E 0012 002E 0012 002E 0012 0011 002E 0011 002E 0011 0475
I have no idea why the "UP" code is 3x longer than the 2 others ... but they work !
enjoy
Chris - sad that Philips stopped with the Pronto ... sad that Oppo stopped their BR /DVD /CD players ...
christosal is offline
post #10 of 11 Old 05-10-2020, 12:14 PM - Thread Starter
clhug's Avatar
Quoted: 31 Post(s)
Liked: 5
Originally Posted by christosal View Post
hello all,
Up:
Down:
Stop:
enjoy
@christosal , what model is your Pronto?
These codes still don't work for my TSU7000.
clhug is offline
post #11 of 11 Old 05-10-2020, 11:04 PM
Liked: 0
Hi Clhug, its a 9400...
But i dont know if that would impact the codes...
Reply Screens
