Slate 1.2 vs Cinegrey 5D or 3D - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Ftoast
  • 1 Post By Hawkmarket
  • 1 Post By LumensLover
post #1 of 25 Old 11-26-2017, 04:21 PM - Thread Starter
Hawkmarket's Avatar
Quoted: 291 Post(s)
Liked: 113
What's the consensus of these materials by comparison. I'm looking at the samples of all 3 and to be perfectly honest the samples look VERY similar. The 5D looks like maybe it's slightly darker but it's pretty close. The Cinegrey 3D and Slate 1.2 look almost identical to my eyes. ALR samples are always challenging to make broad assumptions with so I wanted to check in with those who have seen the full screens of each and what their impressions are. SI is obviously much more proud of their screen so the question is does the extra money justify the performance. Based upon the sample the answer would be no but a full screen may tell a very different story.
Hawkmarket is offline
post #2 of 25 Old 11-26-2017, 05:54 PM
Quoted: 801 Post(s)
Liked: 463
I have owned all three. The Slate 1.2 rejects 65% of all ambient light coming from the sides and top. The Cinegrey 3D and 5D only will reject up to 65% of light coming from the above only. They will not do anything for light coming from the side. They also have a slightly wider viewing cone from my experience and the Cinegrey 5D was the brightest out of the bunch. However the Slate 1.2 is a very bright screen as well.
Slate 1.2 was the best in my opinion because it was a better all-around performer for rejecting light from sides and top. Most Elite Crooks screens will only reject light from the top only which limits their use in my opinion.
LumensLover is offline
post #3 of 25 Old 11-26-2017, 06:05 PM
rayan1910's Avatar
Quoted: 50 Post(s)
Does Carls ALR reject light from the side?
rayan1910 is offline
post #4 of 25 Old 11-26-2017, 08:01 PM - Thread Starter
Hawkmarket's Avatar
Quoted: 291 Post(s)
Liked: 113
So why do you no longer own the Slate?
post #5 of 25 Old 11-26-2017, 08:26 PM
Quoted: 801 Post(s)
Liked: 463
Wanted something for severe ambient light so I went with the Black Diamond. Though I've tried many more ALR screens since then. I've tried over 90% of the ALR screens available on the market today.
post #6 of 25 Old 11-27-2017, 01:39 AM
Ftoast's Avatar
Quoted: 2688 Post(s)
Liked: 877
My sample of Carl's ALR and slate1.2 perform basically like twins except that slate has a blue-ish tint and Carl's has a warmer tint by compare.
They both reject light from the sides and above/below, but their side rejection is a little weaker than their vertical rejection because it allows them a little wider viewing-cone.
rayan1910 likes this.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #7 of 25 Old 11-27-2017, 01:40 AM
rayan1910's Avatar
Quoted: 50 Post(s)
For the money is there anything better than Carl's ALR?
post #8 of 25 Old 11-27-2017, 02:00 AM
Ftoast's Avatar
Liked: 877
I believe the Elite CineGrey5D is a bit more aggressive (slightly darker-colored and slightly higher-gain from on-axis), while SilverTicket offers a more subtle light-grey (less aggressive but also more forgiving) and a brighter silver1.5 (although I've heard it can be sparkly looking).
For a much higher but still reasonable price, Seymour has a much darker-colored Matinee Black and a bright Matinee Silver.
There's also the DarkEnergy Abyss which is somewhat like a lower-gain and possibly darker-colored Matinee Black.
It's really hard to beat Carl's ALR (stretchy, not the 4k/pro) if it's characteristics are what works well in your situation..but there are some solid alternatives under $1000 if you have different needs that pair better with a different style of screen.
Ftoast is offline
post #9 of 25 Old 11-27-2017, 02:14 AM
rayan1910's Avatar
Quoted: 50 Post(s)
Out of all the materials, if you had white walls and little ambient light what would you choose under $500?
post #10 of 25 Old 11-27-2017, 09:14 AM - Thread Starter
Hawkmarket's Avatar
Quoted: 291 Post(s)
Liked: 113
Your favorite people over at Elite claim the Cinegrey works with both overhead and side lighting. Where did you get the info that it only helps with overhead lighting or was that just your perception?
Ftoast likes this.
post #11 of 25 Old 11-27-2017, 10:10 AM
Quoted: 801 Post(s)
Liked: 463
Forgot to edit that post. Meant to say that the Star Bright material and Dark Star material reject light from above only.
However with that being said the Cinegrey 5D material sucked at rejecting light from the side. You would have to step up to at least the PolarStar material for solid light rejecting from the side. None of the low end alr materials from Silver ticket, Elite Crooks, or Carl have acceptable off axis ambient light rejection in my opinion.
post #12 of 25 Old 11-27-2017, 01:53 PM - Thread Starter
Hawkmarket's Avatar
Quoted: 291 Post(s)
Liked: 113
I explored a few of the other options you mentioned but they don't make a 150" 16:9. I also have a Carl's ALR sample and it appears significantly darker than the both the SI Slate 1.2 and Elite Cinegrey 3D and 5D. I wasn't particularly impressed with it.
post #13 of 25 Old 11-27-2017, 02:29 PM
Ftoast's Avatar
Liked: 877
I know the Elite CineGrey DesignerCutSeries is only available at 135", but do you happen to remember which screens/brands aren't available at 150" 16:9?
I think I remember you mentioning Carl's ALR being significantly darker than Slate1.2 and CineGrey3D before which is still weird to me since my samples of slate1.2 and ALR are nearly twins (except the cold VS warm tint) and other posts I've seen comparing ALR with CineGrey3D both describe and picture them appearing very similar. I don't know if there's that much variation between rolls of materials or if there's something else different I could be misunderstanding.
Is your Carl's ALR the soft, stretchy version that's slightly glossy on one side and more matte-finish on the other?
Do you remember if your samples were recent enough that Carl's had the ShortThrow material available and maybe they mixed up what they sent to you...though I don't know if their ShortThrow ALR is similar or not.
Ftoast is offline
post #14 of 25 Old 11-27-2017, 02:41 PM
Ftoast's Avatar
Liked: 877
Out of all the materials, if you had white walls and little ambient light what would you choose under $500.
There's a lot of these inexpensive screens that I haven't personally seen (including the SilverTicket materials), so their grey or someone else's may be an even better option, but I do really like how Carl's ALR looks..I think it's a nice balance between brightness and light/reflection-fighting aggressiveness at a lower price than most.
But, if your projector is too close and your seating-arrangement is too wide, something lighter-colored and lower-gain (like CineGrey Classic DesignerCutSeries, SilverTicket Grey, Carl's FlexiGrey) could be a better overall option for an even lower price.
Ftoast is offline
post #15 of 25 Old 11-27-2017, 03:56 PM
rayan1910's Avatar
Quoted: 50 Post(s)
Cars ALR or ULTRA ALR for 4k? My projector is about 12 3/8 feet from the screen and a super narrow viewing cone. Sorry OP for stealing thread
post #16 of 25 Old 11-27-2017, 04:39 PM
Shermstead's Avatar
Quoted: 54 Post(s)
Liked: 24
Obviously you’ve tried many screens, but have you owned or observed full screens of the most recent three entries into ALR - two of which have large budgets, lots of experience and technolgy: Stewart’s HALR, Da-Lites Parallax and DES Abyss?
Shermstead is offline
post #17 of 25 Old 11-27-2017, 04:45 PM
Quoted: 801 Post(s)
Liked: 463
I've seen the Da-Lite Parallax screen. It shows a refined, artifact free image however alr rejection off axis was decent but not great. It would be a good screen for a dedicated HT room with low levels of light.
I have not have the pleasure of seeing the Stewart HALR screen or the Dark Energy Abyss screen.
Though I will admit I am done with negative gain ALR screen. The Elunevision Aurora looks like a winner. The Draper Tecvision CS1200X seems promising as well.
maglito likes this.
post #18 of 25 Old 11-28-2017, 12:40 AM
Ftoast's Avatar
Liked: 877
I've heard the ultra/4K version of the ALR screen weirdly has a significant amount of physical texture..I'm guessing because the stiff/Ultra4K version is likely made onto the same textured surface as the ProWhite/ProGrey surface.
The flexible/stretchy regular version ALR is nicely smooth...so I'd go with that instead of the ultra/4K ALR.
Ftoast is offline
post #19 of 25 Old 12-27-2017, 06:36 PM
Quoted: 364 Post(s)
Liked: 251
I really have been impressed by my Elite Cinegrey 3D. Does a great job with ambient light, is fairly neutral for an alr, and has little to no hotspotting. Is it a slate 1.2 no but is it amazing for the $429 I paid for my 100” absolutely yes.
The top pic shows the true amount of light in the room and the 2nd is representative of the picture I am seeing with that level of ambient light. iPhone camera couldn’t capture both effectively in the same picture.
OrcusVaruna is offline
post #20 of 25 Old 01-04-2018, 06:31 PM
Liked: 0
I'm in the market right now for a big boy screen. It will be a multiuse room above my garage. I'm planning on getting the Epson 4000 projector and I was looking at the cinetension2 cinegrey screen.
Is this screen an ALR screen or do I need the 3d or 5d? It said somewhere to only buy this screen if contrast was 2000:1 or lower.
Half of the time it will be totally light controlled but the other half the kids may be playing in there or watching cartoons with one light on which would be approx 4ft above the screen half way between screen and seating. 10ft ceiling.
Has anybody seen the cinegrey in action?
Sent from my SM-G930W8 using Tapatalk
hvacrookie1113 is offline
post #21 of 25 Old 01-04-2018, 07:32 PM
Quoted: 364 Post(s)
Liked: 251
Cinegrey non 3D/5D is just a standard matte grey 1.0 gain screen material. Thus it does not have any ALR properties whatsoever. I recently switched from a 1.0 gain silver ticket grey screen to a Cinegrey 3D and the difference is night and day if you have any ambient light in the room. For lights out viewing I find it significantly improves perceived contrast by boosting peak white while maintaining the same black floor as the projector had on my previous screen. The one negative I have found is the Cinegrey 3D introduces a pretty significant color shift that you must calibrate the projector to handle.
post #22 of 25 Old 12-13-2018, 04:56 AM
Curamrda's Avatar
Quoted: 38 Post(s)
any updates here? I am standing between the same decision. But I have probably problem, coz I will have window directly oposite of the screen. And I dont like the small view angle
Curamrda is offline
post #23 of 25 Old 07-18-2019, 10:45 AM
Jrunr's Avatar
Quoted: 177 Post(s)
Liked: 37
@LumensLover
Just want to bump this to the top as I am trying to figure out a 120" screen for my lights controlled room.
Will the 1.2 gain of the 3D brighten up the image more that a 1.1 gain white screen? I am looking at the elite brand to be paid with my BenQ HT5550 projector. I will be sitting 12.5' away from the screen.
@Ftoast
Jrunr is offline
post #24 of 25 Old 09-18-2019, 07:08 PM
Ftoast's Avatar
Liked: 877
Originally Posted by Jrunr View Post
@LumensLover
@Ftoast
A grey screen is going to have a slightly more directional brightness than a 1.1gain white screen, so even though a part of the image will likely be a hair brighter at 1.2gain VS 1.1gain, the 1.1gain white screen will have brighter edges and will hold it's overall brightness better for anyone seated off toward the sides rather than the center. Plus the difference between 1.1gain and 1.2gain is small enough to be practically indistiguishable.
If your room had light-colored walls/floor/ceiling near the screen or some lights off toward the sides to be fought then the 1.2gain grey screen could help fight those reflections or lights while still keeping your image nicely bright, but in a nicely light-controlled room I'd prefer a nice white screen practically every time.
Ftoast is offline
post #25 of 25 Old 10-13-2019, 03:43 AM
Luminated67's Avatar
Quoted: 683 Post(s)
Liked: 382
I have been debating a similar dilemma only in my case I have a fully light controlled room complete with black velour walls and ceiling but there’s occasions when you want to have some light in the room especially when watching a sporting event with mates or just general TV channels. I have already made to decision I want to switch to a cinemaScope screen and luckily the Epson caters for this with a memory motorised lens.
My question is two fold, will a simply screen material like Carl’s FlexiGrey or would I be best getting the ALR version give enough light rejection to watch whilst not crushing the image in complete darkness. And is this the best option for improving blacks without ditching my Epson and getting a JVC which would be more than I’m willing to go at the moment?
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is online now
Reply Screens
