Acousticaly transparent black velvet // - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By HerbertThePervert
post #1 of 17 Old 06-14-2018, 11:21 AM - Thread Starter
Quoted: 242 Post(s)
Liked: 25
In what way is regular black velvet (like the ones you can buy on Amazon) acoustically transparent? Or would I need specific fabric for that?
Thanks for the input
Droogne is offline
post #2 of 17 Old 06-14-2018, 02:37 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 4151 Post(s)
Liked: 2002
That doesn't exist....but you could do nicely using a Matte Black Spandex
MississippiMan is offline
post #3 of 17 Old 06-14-2018, 11:38 PM - Thread Starter
Quoted: 242 Post(s)
Liked: 25
Do you mean spandex would me more transparent? Looks like it could do the same so I'm good for both . Just want to look for a fabric that wont distort my sound too much.
Droogne is offline
post #4 of 17 Old 06-15-2018, 04:48 AM
Liked: 2002
Spandex is actually as good as the most effective (...and costly...)Mfg AT Cloth available, and really better than almost all others.
It is being used extensively as Acoustic Transparent Screen material, (2 Layers are as effective as 1 layer of Mfg AT cloth...) so you'll have no issues at all.
Is your intended use to cover/shield R & L Speaker arrays?
post #5 of 17 Old 06-15-2018, 05:29 AM - Thread Starter
Quoted: 242 Post(s)
Liked: 25
Exactly Trying some things out in preparation of my projector + large AT screen.
I'm interested in the use as a AT screen though! Seems like a pretty good way to make something I can easily attach and detach when necessary. Maybe build a wooden frame with a lot of anchorpoints and springs attached to the spandex? Not sure what you mean by "Mfg" though.
Droogne is offline
post #6 of 17 Old 06-15-2018, 07:59 AM
Quoted: 22 Post(s)
WROOOONG
Not sure what you have and do not have in the US, but here in germany we have Stretch Velvet which is nearly acousticly transparent. It is even blacker than TBV which i have samples of.
Here is a measurement of it compared to Devore: (Source: Heimkinoverein.de)
Blue is Devore, Purple is the Stretch Velvet.
This stuff is wideley availible as it is a China import. Made of: 92% plastic stuff (poly.. whatever) 8% elastic stuff (Elastan)
Herb
HerbertThePervert is offline
post #7 of 17 Old 06-20-2018, 12:12 AM
Nima's Avatar
Quoted: 262 Post(s)
Liked: 142
@HerbertThePervert , I send you a PM regarding this Stretch Velvet in Germany.
TIA
Nima is offline
post #8 of 17 Old 06-20-2018, 02:23 AM
Ftoast's Avatar
Quoted: 2781 Post(s)
Liked: 934
Does anyone know if this Morex, stretchy, velvet-like material is the same stuff..or at least really similar?
Originally Posted by unretarded View Post
If budget is a consideration, I used Morex crushed panne velour as it is 2.50 a yard, has velvet like performance and is as stretchy as spandex....it is also 60 inches wide, which stretches out even more. It is easily installed with thumb tacks and does not sag...well has not in the last year anyway.
It made a huge difference in picture quality and was under 100 bucks for 30 yards delivered and is way better than any black paint and does better than most black material due to the velvet pile/opposed to fabric with no pile height.
http://www.morexfabrics.com/crushed-...k-width-58-60/
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #9 of 17 Old 06-20-2018, 05:23 AM
Quoted: 22 Post(s)
If that is what i think it is it is not suitable. I do know "Pannesamt" (crushed velvet) and it reflects alot of light and looks really really cheap... Like something a prostitute would wear.
Herb
ScottAvery likes this.
post #10 of 17 Old 06-21-2018, 12:55 AM - Thread Starter
Quoted: 242 Post(s)
Liked: 25
Originally Posted by HerbertThePervert View Post
WROOOONG
Herb
Hey
Can you maybe link me the shop where to buy it from? I'm located in Belgium, so pretty close to Germany
Droogne is offline
post #11 of 17 Old 06-26-2018, 08:27 AM
roxiedog13's Avatar
Quoted: 2845 Post(s)
Liked: 1510
Hey
I'd like to know what is this fabric as well please . A link , manufacturer, product name or part number would be fantastic.
Dedicated Theater: Sony VPL VW5000 , Panamorph DCR & ISCO III L Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 134" diagonal curved , Denon AVR-X8500 , 9.2.6 Atmos, Panasonic UB900, Oppo 203, Lumagen Pro 4440 , (3) Paradigm CI Elite E7-L+C+R fronts, , (2) CI Pro P80-IW Rear, (2) Paradigm SA-ADP In-wall Surround, (6) SIG-1.5R-30 v.3 In-Ceiling, Subwoofers: (2) SVS SB-16 Ultra , (1) SVS PC13-Ultra .
roxiedog13 is offline
post #12 of 17 Old 10-12-2018, 08:34 AM - Thread Starter
Quoted: 242 Post(s)
Liked: 25
Anyone else any suggestion?
Droogne is offline
post #13 of 17 Old 01-26-2019, 09:55 PM
JMAX2016's Avatar
Quoted: 92 Post(s)
Did you find any acoustically transparent velvet?
Yamaha Aventage 3060, 7.2.4
Goldenear Triton 1's, Supercenter XXL, 4-MPX, 4-652
2-SVS PB-16's
JVC RS500 Pro, Panasonic DP-UB820 UHD Blu-Ray Player
137" wide 16:9 V6 AT Screen
JMAX2016 is offline
post #14 of 17 Old 07-11-2019, 12:45 PM
LJG
LJG's Avatar
Quoted: 825 Post(s)
Liked: 549
WROOOONG
Herb
Interested in this fabric also, anyone find the source/name
LJG is online now
post #15 of 17 Old 07-11-2019, 02:02 PM
ScottAvery's Avatar
Quoted: 856 Post(s)
Liked: 246
Possibly Whaley's Devore as linked by Arrow AV here:
https://www.avsforum.com/forum/24-di...l#post58185028
This one is stated to be AT and darker than Fidelio (but directional, where Fidelio is not)
ScottAvery is offline
post #16 of 17 Old 07-11-2019, 04:06 PM
LJG
LJG's Avatar
Quoted: 825 Post(s)
Liked: 549
Thanks for the link!!
LJG is online now
post #17 of 17 Old 03-11-2020, 11:56 AM
DerekV333's Avatar
Quoted: 21 Post(s)
So any sources or named product in Europe found?
DerekV333 is offline
Reply Screens
