Seymour Screen Excellence Trim Motorized Masking Screen at CEDIA 2018 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 75Likes
post #61 of 67 Old 01-27-2020, 09:15 AM
Craig Peer's Avatar
Quoted: 7632 Post(s)
Liked: 9447
Originally Posted by blake View Post
Do I even need masking ?
My tentative plan is SSE Trim-L 140” wide (or perhaps 130”) 2.40:1 scope screen (CIH). Material: Enlightor Neo (need an AT screen, MLP/front row is 9 feet away). The projector is JVC RS4500 (on high laser 2500 calibrated lumens). Room is totally light controlled.
If I instead went with a larger fixed screen “canvas” (same material) for greater aspect ratio flexibility (and cost saving!), will I even see screen material without masking ? The blacks are very good with this projector.
Perhaps any projected letterbox or pillar will appear just as black as the masking material itself ?
Masking makes all the difference in the world picture wise, as far as I'm concerned. No projector has black bars as black as masking - except maybe the Christie Eclipse !
Craig Peer is online now
post #62 of 67 Old 01-28-2020, 09:16 AM
avsBuddy's Avatar
Quoted: 196 Post(s)
Liked: 115
What about built-in masking in new JVC projectors? Wouldn't that essentially block any light in the black bar area from reaching screen?
avsBuddy is offline
post #63 of 67 Old 01-28-2020, 09:56 AM
sor
sor's Avatar
Quoted: 162 Post(s)
Liked: 170
I think it’s more to do with the fact that a totally unlit white screen will never be as black as a mask, unless you have zero light in the room. Even scatter from reflected light on the rest of the screen will light up the room somewhat. How bothersome this is, is up to the individual.
Low Profile and rossandwendy like this.
sor is online now
post #64 of 67 Old 01-28-2020, 10:06 AM
rossandwendy's Avatar
Quoted: 277 Post(s)
Liked: 327
Exactly. I've been projecting on a 175" diag. screen and I don't use the full width for 16:9, and even with triple black velvet on the front walls, ceiling, and floor and no lighting it is still easy to see the white screen outside the image. To me masking enables the best immersion in the film, and without it I am distracted.
Ross
Low Profile and bobof like this.
DISPLAY: JVC RS540, 160" Stewart WallScreen ST130 G4
SPEAKERS/SUBS: Chane A5.4/A2.4/A1.4, Rythmik FV18 x 2
POWER: Outlaw 5000 5-channel, Denon AVR-X3300W
SOURCE: multi-region Oppo BDP-103D & BDP-83
rossandwendy is online now
post #65 of 67 Old 01-28-2020, 10:48 AM
aka jfinnie
Quoted: 3105 Post(s)
Liked: 2237
It isn't an optical mask that results in all light being blocked, it is a digital mask, so it is no different to the black bars themselves in well authored content. The masking function is only useful for masking areas of the image when a different aspect screen is used.
And even if it was an optical mask (which it isn't), in all but a perfect black hole room (doesn't exist!) you'll still have reflected light lighting up unused areas of screen during some scenes versus the dark black velvet screen edges far away.
bobof is online now
post #66 of 67 Old 02-02-2020, 10:36 PM
blake's Avatar
Quoted: 533 Post(s)
Liked: 65
Can the TRIM system be setup to automatically mask the picture to a corresponding JVC installation mode (2:40 vs 16:9) based on the AR of the source content ? I will be using a RS4500 with a Crestron system.
Or do you need a Lumagen Radiance pro to do this ?
blake is online now
post #67 of 67 Old 02-04-2020, 10:24 AM
chriscmore's Avatar
Quoted: 283 Post(s)
Liked: 343
The Lumagen can certainly send out aspect ratio information and you can program a RS-232 control to go to the corresponding ratio. I'm not sure if the RS4500 can by itself but the projectors that I've had that will do it will have programmable trigger outputs. This can automate between two ratios, but not intermediate.
Chiefs,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
Reply Screens
cedia 2018 , motorized masking screen , seymour screen excellence
