AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Screens (https://www.avsforum.com/forum/23-screens/)
-   -   Can Screen Frame Overlap Speaker? 16:9 vs 2.35:1 (https://www.avsforum.com/forum/23-screens/3057456-can-screen-frame-overlap-speaker-16-9-vs-2-35-1-a.html)
rdscuba 03-19-2019 01:37 PM
1 Attachment(s)
My speakers are in transit and now I am trying to figure out the AT Screen. I've read lots and lots about 2.35:1 vs 16:9 and I am still undecided. The HT will be 75% movies and 25% TV/Sports.
Here are the screens I am considering at this moment:
142" 2.35:1
158" 2.35:1 (with stipulations)
150" 16:9
As you can see in the attached diagram, the frame (3.15" wide) will cover a the horn and 12" bass speaker - almost in the middle of each. I assume this is a No-No... If its not a huge deal then I would lean heavily toward the 158" 2.35:1 screen.
Low Profile 03-19-2019 04:16 PM
Place the left and right speakers behind the screen?
tqlla 03-19-2019 04:34 PM
Yeah, you definitely dont want to cover your tweeters with a metal bar.
I would say move the speakers behind your screen, then fix the wall. Shouldnt be that hard... hopefully.
rdscuba 03-19-2019 08:36 PM
Baffle wall is built. I wish it was that simple...
tqlla 03-19-2019 09:28 PM
Well you could go for a 200" 16:9. Or custom a ~170" 235:1.
Otherwise I would stick with the 150" It sounds like you spent a lot on audio. I wouldnt compromise it by putting a frame right over the tweeter.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
