Paint black border on existing screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-05-2019, 05:00 PM - Thread Starter
Rockokma's Avatar
Quoted: 46 Post(s)
I have a 159" screen that I used for a theater I had to take down years ago. Current room is smaller, and the throw distance will only allow for 140" screen.
Possible to paint black borders around the Da-lite screen to make the screen smaller? I do not want to cut and frame as I have windows (blacked out) behind the screen and I do not want them to show. The screen is just wide enough to cover the windows.
Any other options?
Rockokma is offline
post #2 of 5 Old 05-05-2019, 05:27 PM
bud16415's Avatar
Quoted: 2164 Post(s)
Liked: 1088
It can be done with paint or black tape or even black velvet attached to the screen.
I would go with the black velvet myself.
Bud
bud16415 is offline
post #3 of 5 Old 05-05-2019, 06:06 PM - Thread Starter
Rockokma's Avatar
Quoted: 46 Post(s)
Thank you. Would the black velvet tape come off easily if we ever wanted to remove it years down the line?
Rockokma is offline
post #4 of 5 Old 05-05-2019, 08:06 PM
bud16415's Avatar
Liked: 1088
That I don't know. I know painting is for good.
Bud
bud16415 is offline
post #5 of 5 Old 05-05-2019, 09:11 PM
airscapes's Avatar
Quoted: 518 Post(s)
Liked: 431
I would do 1/4" plywood covered in velvet.. be creative..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
Reply Screens
