loose canvas - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By bud16415
  • 1 Post By andreasbratsche
post #1 of 3 Old 06-17-2019, 11:05 AM - Thread Starter
andreasbratsche's Avatar
Liked: 1
Question loose canvas
hello there,
Having mounted a second-hand 92" Optoma DS-9092PWC from the ceiling, after a few days, I noticed that both sides of the picture were equally ascew. Apparently, the lower part left and right were bulging inwards. Let it hang a few days to see if it would straighten out, but it only got worse, until noticing that the canvas actually was loose on one side. Does anyone know how a screen is attached to the lower bar and how to fix it?
best regards from Czech Republic, mirrormurr
ID:	2581156   Click image for larger version
andreasbratsche is offline
post #2 of 3 Old 06-17-2019, 12:05 PM
bud16415's Avatar
Quoted: 2012 Post(s)
Liked: 1019
My guess is the end cap comes off and then the material slides out the slot. There is most likely a welt on the bottom edge and it could have separated on the ends. The caps could be glued on.
andreasbratsche likes this.
Bud
bud16415 is offline
post #3 of 3 Old 06-18-2019, 03:45 AM - Thread Starter
Liked: 1
thanks a lot for the tip, Ill report back soon as I ve tried it out!
bud16415 likes this.
Reply Screens
ascew , retention-tab , screen loose
