Anyone have experience with Elite Aeon cinewhite? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Jrunr
  • 1 Post By subacabra
  • 1 Post By JPHCCFC
post #1 of 27 Old 07-01-2019, 05:34 PM - Thread Starter
qposner's Avatar
Quoted: 42 Post(s)
Ive searched and have found threads, but havent really found more recent reviews. Im considering replacing my basic 5 year old 100 inch Elite white screen with the 110 inch (cant go any bigger) borderless Aeon cinewhite screen. But Im not sure itll make a huge difference for me going the extra ten inches. I sit about 12 feet from the screen. I would also like the image to pop a bit more with my 5040ub and was hoping the cinewhite might help. Any input is appreciated.
qposner is offline
post #2 of 27 Old 07-08-2019, 01:24 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
+1.
I am looking at the same screen/size combo as well. I too max out at 110” and the border less design really helps.
Does anyone have any reviews on this screen?
Jrunr is offline
post #3 of 27 Old 07-21-2019, 11:47 AM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Just ordered this screen so hopefully it's going to impress
Sent from my Pixel 2 XL using Tapatalk
JPHCCFC is online now
post #4 of 27 Old 07-21-2019, 04:25 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
Excited to hear your thoughts!
Jrunr is offline
post #5 of 27 Old 07-25-2019, 04:47 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Hey Jrunr
Got the screen yesterday. Was a bit of a nightmare to setup but got there after about 5 hours of work!!! I have bought some additional led lights for the back of the screen too. First impressions are very good. I had a dalite 1.1 white gain pull down previously. I need to do some longer watching and may change some settings! Will take some photos as well.
post #6 of 27 Old 07-25-2019, 05:54 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
Originally Posted by JPHCCFC View Post
Hey Jrunr
Is there a difference between the Aeon and the dilate? Both or 1.1 gain, right?
I am also contemplating the cinewhite as well as the cinegray 3D... its going to be in a light controlled room, so i am not sure if it will be worth it to get the cinegray 3D, even though it has a gain of 1.2
Jrunr is offline
post #7 of 27 Old 07-25-2019, 08:08 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
No need to get the cinegrey in a light controlled room. The elite white is amazing. The dalite screen was fantastic.. Picture attached... But the elite screen is in a new league... Picture coming...
post #8 of 27 Old 07-26-2019, 03:03 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
Ok... following in your footsteps... I bought the Aeon Cinewite 120" and it should be here tomorrow.
JPHCCFC likes this.
Jrunr is offline
post #9 of 27 Old 07-27-2019, 03:24 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Couple of tips.....
Make sure you only put the corner springs in first then add the middle bar. Also ensure the corners are stretched over the frame corners otherwise you could have a corner wrinkle effect...you can stretch them a little bit and you can use extra springs if needed....learnt this the hard way by having to email then call support.
post #10 of 27 Old 07-27-2019, 03:48 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
Couple of tips.....
Awesome. Thank you for the tips.
Don't forget to post your pics!!!
Jrunr is offline
post #11 of 27 Old 07-27-2019, 04:22 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Here's a couple of pictures... Post yours too
post #12 of 27 Old 07-27-2019, 04:32 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
That looks awesome!!! maybe i should've gotten the LED lights...
Jrunr is offline
post #13 of 27 Old 07-27-2019, 04:36 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
50$ at Amazon and Alexa controlled
post #14 of 27 Old 07-27-2019, 04:38 PM
subacabra's Avatar
Quoted: 1638 Post(s)
Liked: 4749
That looks great! I'm rocking a 100" Akia zero edge in my bedroom setup. If anyone's interested in saving some money Akia Screens are made by Elite and are exactly the same.
JPHCCFC likes this.
subacabra is offline
post #15 of 27 Old 07-27-2019, 05:02 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Subcabra, I follow your updates on the HT3550....i currently have a W1070 and am contemplating the HT3550...what are your thoughts after having it for a decent amount of time.... worthy upgrade?
post #16 of 27 Old 07-27-2019, 05:13 PM
subacabra's Avatar
Liked: 4749
I really like the HT3550, and luckily mine has been relatively trouble free. The picture quality is just amazing, and it does a good job with hdr tone mapping. I still enjoy my 2050 but this blows it away imo. Just make sure you go with a quality fiber HDMI like a Ruipro.
post #17 of 27 Old 07-27-2019, 05:52 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Thanks Subcabra...i upgraded.the basement 2 years ago and channeled a 25ft monoprice HDMI 2.0 certified cable in prep for 4k upgrade...ummed and ahhed on the rupiro.... But went for the cheaper option... Hope i don't regret the decision as it was a nightmare to install and am definitely upgrading to a 4k projector very soon..
subacabra likes this.
post #18 of 27 Old 07-27-2019, 05:55 PM
subacabra's Avatar
Liked: 4749
I hope that cable works for you! I've seen people running into issues. I lucked out and caught the Ruipro on a flash sale on Amazon.
Keep me posted if/when you upgrade the pj!
Also any other questions feel free to ask away lol
post #19 of 27 Old 07-27-2019, 05:58 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Thanks... With what I've read to date i would of spent the extra 130 based on the effort to setup... Fingers crossed...
How are you finding gaming on the projector.... That's the only thing holding me back on pulling the trigger
post #20 of 27 Old 07-27-2019, 06:17 PM
subacabra's Avatar
Liked: 4749
It's actually not bad at all. If you play COD/fps competitively the lag may bother you(I didn't really notice) but for casual gaming it's beautiful. Far Cry 5, Forza, Call of Duty 4 all look incredible. I played the new zombies map yesterday for an hour or so and it was great!
post #21 of 27 Old 07-27-2019, 06:27 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Have you played any sports sims on it.. Does the lag impact them?
post #22 of 27 Old 07-27-2019, 06:33 PM
subacabra's Avatar
Liked: 4749
I haven't played any Madden or anything, just the 2019 PGA golf game which prob isn't affected by any lag.
post #23 of 27 Old 07-27-2019, 07:49 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
I would have gone that route but they only have 100" and 125".... So I went with the Elite.
Jrunr is offline
post #24 of 27 Old 07-27-2019, 07:50 PM
Jrunr's Avatar
Quoted: 164 Post(s)
Liked: 34
@JPHCCFC can you please provide a link? or PM me?
Also, I am running the BenQ HT5550. Love it so far!!
Jrunr is offline
post #25 of 27 Old 07-28-2019, 06:15 AM
JPHCCFC's Avatar
Quoted: 48 Post(s)
PMd link, description to search for is: LED Strip Lights 10M,Colohas WiFi Wireless Smart Phone Controlled Light Strip Kit 5050 Waterproof IP65 LED Lights,Working with Android and iOS System
post #26 of 27 Old 07-28-2019, 06:18 AM
JPHCCFC's Avatar
Quoted: 48 Post(s)
The 5550 looks good... Do you know what the input lag is for gaming?
post #27 of 27 Old 08-04-2019, 06:17 PM
JPHCCFC's Avatar
Quoted: 48 Post(s)
Did you get your Aeon screen up?
Reply Screens
