Help with Retractable screen (tight on height) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-16-2019, 05:50 AM - Thread Starter
Bill97Z's Avatar
Quoted: 141 Post(s)
Liked: 40
I am looking for a cost effective retractable screen (good for 4K) for my setup (manual or motorized ok).
- 120" to fill the width between the windows
- The TV (63" shown in picture, now 82") will be wall mounted
- Speakers will be pulled to the sides out of the way
- Screen will be mounted under the crown molding and stand off so it pulls down in front of the TV
- I only have 73" from the crown molding to the TV console (less if I get a center channel, est 6.5" high which would yield 67")
- Screen would need to be able to pull down partially as most 120" screens fully extended advertise overall heights in the 80"s (but I don't need all that black area above the screen).
Any suggestions?
Bill97Z is offline
post #2 of 4 Old 07-16-2019, 07:55 PM
rekbones's Avatar
Quoted: 989 Post(s)
Liked: 512
My suggestion is to lose the console. It's a much cleaner look with a wall mounted TV and drop screen. Put the components elsewhere in the room preferable hidden. The AV equipment in the front of the room under the screen is very old school way of thinking and no long practical.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is online now
post #3 of 4 Old 07-17-2019, 05:38 AM - Thread Starter
Bill97Z's Avatar
Quoted: 141 Post(s)
Liked: 40
I guess I can look into that which would meaning fishing the wires through the walls. What about the speakers? center channel?
Bill97Z is offline
post #4 of 4 Old 07-17-2019, 07:18 AM
rekbones's Avatar
Quoted: 989 Post(s)
Liked: 512
Of course the LCR speakers need to be up front but it's a lot easier to hide speaker wire and it's inexpensive compared to HDMI. The TV will still need a cable so maybe a place somewhere equal distance from projector and TV for shorter cable runs. Center can be on a small stand or mounted on a small shelf under the TV.
Reply Screens
