Is Da-Lite HP an ALR tech? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By Dave in Green
post #1 of 5 Old 09-05-2019, 07:44 PM - Thread Starter
JackB's Avatar
Quoted: 1424 Post(s)
Liked: 350
I have a Da-Lite 2.8 HP screen in my living room. I'm thinking of using it for one of the new UST projectors. The HP is a retro-reflective screen which means it reflects the projected picture back towards it source. This works to a degree since the UST picture is coming from below. Does the HP also reject ambient light similar to the ALR screens that are said to be the only really good tech for the UST projector?
Jack
JackB is offline
post #2 of 5 Old 09-06-2019, 09:47 AM
Dave in Green's Avatar
Quoted: 3733 Post(s)
Liked: 2965
There are different types of ALR screens optimized for rejecting ambient light coming from different directions. Since a retroreflective screen reflects any light that hits it directly back at the source it could be considered to be ambient light rejecting for any ambient light that doesn't come from the general area where the viewers are seated. For example, if you have a lighted lamp sitting right next to you an HP screen would reflect the lamp's light directly back at it and those sitting next to the lamp would get a big dose of that reflected lamp light.
With the extreme projection angle of a UST projector viewers are going to be far from the center of the viewing cone. Hypothetically if the UST projector is projecting an image up 45 degrees from the bottom of the screen then those seated back from the center of the screen are going to be sitting 45 degrees out of the prime spot in the viewing cone and much of the HP screen gain would be lost. The floor immediately in front of the screen where the projector is sitting (or ceiling if the UST projector is ceiling mounted) would be the center of the viewing cone getting maximum screen image gain.
Essentially a UST projector and retroreflective screen would make a poor combination because they would light up the floor or ceiling where the projector is mounted, creating objectionable cross reflections back onto the screen. Specialized UST ALR screens are very different from retroreflective screens for good reason.
Dave in Green is offline
post #3 of 5 Old 09-06-2019, 10:24 AM - Thread Starter
JackB's Avatar
Liked: 350
Thanks for the informative reply.
Jack
JackB is offline
post #4 of 5 Old 09-06-2019, 04:03 PM
airscapes's Avatar
Quoted: 505 Post(s)
Liked: 425
The 2 tech are probably the worst possible match together :-(
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #5 of 5 Old Yesterday, 05:44 AM
Frank714's Avatar
Quoted: 967 Post(s)
Liked: 425
To answer the original question:
The difference is that the Da-Lite High Power 2.8 uses tiny, spherical glass beads under a transparent and protective layer while the ALR screens (XY-Screen etc.) - AFAIK - use heterogenous crystals melded onto the surface of the screen.
In combination with an HP 2.8 the best placement position of a front projector would be right next the eyes and at eye level for maximum gain performance, because the spherical glass beads reflect back to where the projection light comes from.
As stated by the others, with a UST front projector the most light would also be reflected back to the position where it came from, but that's hardly the spot you'll expect to find the viewer or spectator.
For UST front projection there are special screens that reflect the UST projection light towards the viewers.
Please make certain to announce your possible intent to part with your High Power 2.8 in the corresponding thread here at the AVS as there is still considerable demand...
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
Reply Screens
