Screens with adjustable mounting brackets? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-08-2019, 08:21 AM - Thread Starter
bk
bk's Avatar
Question Screens with adjustable mounting brackets?
I currently have a Da-Lite Model C Hi-Power (older 2.8 gain style), and it's time for a new screen.
I'd like to go a little larger than my current screen, but if at all possible reuse the same mounting position. I've found the Grandview brand of screens have a channel on the back of the screen case with a floating mounting bracket that allows for adjustment of the mounting points.
Does anyone know of other brands that have adjustable mounting brackets?
TIA
bk is offline
post #2 of 3 Old 09-08-2019, 02:20 PM
ProjectionHead's Avatar
Quoted: 116 Post(s)
Liked: 173
TIA
Da-lite also has them on several models such as the Contour Electrol.
ProjectionHead is offline
post #3 of 3 Old 09-09-2019, 03:31 PM - Thread Starter
bk
bk's Avatar
Thanks for the tip. Turns out Model C has the floating mounting bracket as well.
bk is offline
Reply Screens
