4k Screen? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By Dave in Green
  • 1 Post By ProjectionHead
post #1 of 6 Old 09-10-2019, 06:46 PM - Thread Starter
bk
bk's Avatar
4k Screen?
What is the real effect of a "HD(1080p)" vs a "4k" screen with a 4k projector like the Epson 5050UB? What kind of artifacts/anomalies would I expect to see with the 1080p rated screen?
bk is offline
post #2 of 6 Old 09-10-2019, 09:28 PM
bdht's Avatar
Quoted: 245 Post(s)
Liked: 98
Texture/Gain artifacts impart a sparkly effect most noticeable in bright scenes, solid colors, and panning shots. With an artifact free screen like Stewarts Snomatte, the screen will be invisible. A screen labeled 4k may still have texture/gain artifacts, like elites cinewhite or silver tickets white.
bdht is offline
post #3 of 6 Old 09-11-2019, 01:13 PM
Dave in Green's Avatar
Quoted: 3732 Post(s)
Liked: 2962
There is no industry standard for projection screen resolution capability so marketing departments can say whatever they want. The better screen companies tend to be more honest about how well their various screen materials will handle increasingly finer resolution.
ProjectionHead and old corps like this.
Dave in Green is online now
post #4 of 6 Old 09-11-2019, 05:32 PM
ProjectionHead's Avatar
Quoted: 115 Post(s)
Liked: 172
You would see a distortion to the pixel's geometry due to the texture on the "non 4k" screen surface. Here is an infographic with some images and more detail:
https://www.projectorscreen.com/blog...aces-Explained
ProjectionHead is offline
post #5 of 6 Old 09-11-2019, 05:36 PM
Quoted: 115 Post(s)
Liked: 172
Unfortunately, that is the case
Here is a video produced by Da-lite which gets into detail on how they rate their surfaces at 16k. It references guidelines produced by the USAF regarding resolution of "line pairs":
They definitely did not dumb it down to make it easily digestible. Long story short, if they can resolve the required amount of line pairs then the surface can resolve the corresponding resolution. (6 line pairs per millimeter = 16k resolution if you have a 10' wide screen which would be necessary in order to fit the required amount of pixels)
Dave in Green likes this.
post #6 of 6 Old 09-12-2019, 03:58 AM - Thread Starter
bk
bk's Avatar
Thanks for all the really useful info.
bk is offline
Reply Screens
