Hotspotting at 9' Throw Distance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-13-2019, 03:17 PM - Thread Starter
bdht's Avatar
Quoted: 277 Post(s)
Liked: 107
How to get good uniformity at a 9' throw distance?
I currently have two 92" motorized tensioned screens and 2 projectors:
BenQ W1070, poor lense uniformity, 50%
JVC RS45U, excellent lense uniformity, 85-90%, but 3' lower than the minimum recommended throw distance of 12'
XY Screen Black Crystal 0.8 gain, 140° viewing angle
Elunevision 100EL, advertised as lambertian, probably similar to elites cinewhite but with no black backing
Both screens have similar gain aritfacts, maybe the black crystal is slightly more sparkly than the 100ELs sheen. The W1070 is ceiling mounted and the RS45U is on a shelf below the w1070.
Many of the projectors, the nx7, ht9060, vw695, etc., have throw distances of 12', or something like the theo z65 has a 4' min throw distance but poor lense uniformity around 60%.
I have samples of the Snomatte and Parallax but its difficult to tell if there's still hotspotting with small samples.
Will a better screen overcome hotspotting or is it necessary to have the projector at or further than the minimum throw distance? Are there any projectors with lower throw distance that won't hotspot?
bdht is online now
post #2 of 4 Old 09-15-2019, 09:03 PM
Craig Peer's Avatar
Quoted: 6984 Post(s)
Liked: 8260
Hotspotting is usually a result of the screen material requiring a minimum throw distance. For instance Stewart's Firehawk G5 requires 1.6X the screen width for the minimum throw -
https://www.stewartfilmscreen.com/en/materials
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #3 of 4 Old 09-15-2019, 09:09 PM - Thread Starter
bdht's Avatar
Quoted: 277 Post(s)
Liked: 107
So having the JVC at a 9' throw isnt causing any hotspotting or impacting uniformity? What is the minimum throw distance for then? I suppose I needa take those samples out and see if I can tell xD
bdht is online now
post #4 of 4 Old 09-15-2019, 09:51 PM
Craig Peer's Avatar
Liked: 8260
It's not necessarily the projector. Look up the specifications of whatever screen material you plan on using. Then run the math.
Reply Screens
