(light) grey screens - how to get white correct? - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #1 of 35 Old 09-24-2019, 01:27 AM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
Hi guys.
I am in the process of testing HD Progressive 0.9 (light grey) and HD Progressive 1.1 Contrast (more grey, but not dark grey) from Da-Lite.
One thing is that they are dimmer than the HD Progressive 1.1, but what annoys me it that white does not look white anymore. It looks more light grey. A bit like how white subtitles look like in the "Cinema Mode" with the lens aperture all closed down. This will - from what I know from using Photoshop Lightroom - affect other colors too.
So what is the "trick" to getting light screen like 0.9 HD Progressive to display white correctly?
So far I have set the Screen Adjust to fit the HD Progressive 0.9, but it is not enough https://de.jvc.com/microsite/de/dla-...tment.html#x30 - so what is the next thing to try?
Webmonkey is offline
post #2 of 35 Old 09-24-2019, 04:04 AM
Ftoast's Avatar
Quoted: 2688 Post(s)
Liked: 877
If you're currently comparing the lower-gain grey screen sample next to your white screen, then you'll always notice how that lower-gain screen is dimmer and more grey/dingy looking, BUT unless the difference is really big you typically won't notice this nearly as much (often not at all) once all of your image is on that slightly lower-gain grey screen. That duller white appearance should stop being noticeable once you are using a full screen OR if you black out all of the image except the part that falls onto the grey sample.
Now, if the screen was only 60% as bright as your previous screen, or if it had a visible tint to its color (for example, if it tinted your image blue/cold), then it is likely to always look different even at full-size.
Side-by-side comparison is a very good thing, but it does have this one specific "shortcoming" (feels like the wrong word to use) that you just noticed...it can make differences in gain/brightness that often appear small on their own become much more noticeable while they're directly compared.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 35 Old 09-24-2019, 05:19 AM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
Thanks for your input.
I was using Planet Earth Ice episodes. And that snow and those icebears just did not look as I wanted it to. I geuss there is a also a bias from being used to the old 1.3 gain screen.
The 1.1 HD Progressive definitely looks more white.
post #4 of 35 Old 09-24-2019, 05:39 AM
airscapes's Avatar
Quoted: 516 Post(s)
Liked: 428
So why are you looking to change to Grey? What are you trying to fix with the non white screen? If room environment is the issue, maybe fix the room rather than replace the screen?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is online now
post #5 of 35 Old 09-24-2019, 06:53 AM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
The HD 0.9 is only very light grey. My 1.3 was bought for a CRT back in the day. I do not need 1.3 gain anymore.
MY room is good, sidewalls are 45% grey and front, back wall and ceiling is 65% grey. Dark furniture and black out curtains. But there are still some light leaks under doors and around the curtain. So I am looking for that little pinch of salt that will complete the experience.
post #6 of 35 Old 09-24-2019, 06:59 AM
Dave in Green's Avatar
Quoted: 3792 Post(s)
Liked: 3009
A neutral matte grey screen can make whites just as bright as a matte white screen. You just have to increase projector lumens to account for any loss of gain. For example, given the same projector lumens a 0.8 gain matte grey screen will produce 80% as bright whites as a 1.0 gain matte white screen. However, increasing projector lumens by the correct percentage on the matte grey screen will make whites equally as bright as on the matte white screen.
Dave in Green is offline
post #7 of 35 Old 09-24-2019, 08:37 AM
bud16415's Avatar
Quoted: 2135 Post(s)
Liked: 1075
@Dave in Green and @Ftoast did a good job of explaining what is happening. The problem is not in the screen it is in your eyes when comparing A/B of Gray/White at the same time.
Your eyes each have an iris and it opens and closes to adjust to the average brightness of the image to allow you to get the best perceived contrast of any given image. Doing an A/B is asking your eyes to adjust two things at once and because the sample is likely small compared to the brighter screen your eyes are favoring the larger brighter image. then to compound the problem you can’t adjust your projectors brightness to two samples at once so you have it set to what is your normal brighter higher gain screen.
Something to think about and if you have a light meter you can try. If you are sitting say in your kitchen with the lights on reading the paper you will feel it is a nice bright room. Now if you go outside to read on your deck and the sun is shining you will say it is also a nice bright setting and might guess it is even twice as bright. If you take your light meter and measure it you might find out it is 10 times as bright. That is because your eyes in a split second adjusted trying to keep it constant.
Eye adjustment is measured in f-stops just like old manual cameras had adjustments. Each f-stop doubles the light or halves the light depending on the direction you are going. The human eye can adjust 26 f-stops I’m told. So that would be numerical in terms of times brighter 1, 2, 4, 8, 16, 32, 64, 128, ….. 26 times if you want to keep going you will see the fantastic range the eye has. There are some drawbacks. At night we can see the stars as our iris is wide open. Those same stars are still up there during the day but we can’t see them as the iris is closed many f-stops because of the sun and to see those faint stars we would need the ability the wide iris give us but if it was that open the sun would be blinding bright. So we get a huge range but not all at once.
Front projection can work over a variety of iris f-stops. By design the best is when it is on the very dark end of the range with a very good projector making very good black levels and of course in a very good room. That’s how CRT projectors worked. Now there is a trend to go much brighter combating ambient light forcing our eyes iris open more and giving us perceived blacks.
It’s all about the eyes. I have a .5 gain neutral gray stealth screen wall and trust me my perceived whites look nothing like gray whites. I have double the lumens I would need for a white 1.0 screen and the result is the same in terms of whites.
Webmonkey likes this.
Bud
bud16415 is offline
post #8 of 35 Old 09-24-2019, 10:19 AM
bdht's Avatar
Quoted: 278 Post(s)
Liked: 108
Just like to add these fine gentlemen answered the same question for me last year refarding low gain neutral matte grey and dark grey with gain(alr) and yes once you are looking at the full image the duller white is only noticeable in direct comparisons.
Also, if the screen has a blue push you can adjust it out easily in the projectors white balance controls
bdht is online now
post #9 of 35 Old 09-24-2019, 10:36 AM
Quoted: 319 Post(s)
Liked: 92
noob00224 is online now
post #10 of 35 Old 09-24-2019, 12:56 PM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
Thanks for the clarification. Now - how about a positive gain grey screen? I am testing the HD Progressive 1.1 Contrast which is a darker grey than the light grey HD Progressive 0.9. - but still FAR from the dark grey of the HD Progressive 0.6
post #11 of 35 Old 09-25-2019, 02:14 AM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
btw - what do people think of grey screens for HDR material? Does it worsen or improve - or not affect the dynamic range??
post #12 of 35 Old 09-25-2019, 05:12 AM
Quoted: 319 Post(s)
Liked: 92
They don't.
For HDR the highest dynamic range is required (the deepest black/whitest white). Since projectors can't reach the nits value of HDR TV's, that usually means a bright projector/screen setup, that ideally can also display good blacks.
post #13 of 35 Old 09-25-2019, 06:27 AM
airscapes's Avatar
Quoted: 516 Post(s)
Liked: 428
Grey screens were used back in the day to try and increase the perceived black level of the digital projectors that were new to the market and did not cut the mustard compared to CRTs. For best possible image you want a white screen ,gain of 1, with no texture, no color shift, and artifacts in a dark room with no reflective surfaces and no other light source. Seems from your room description you are very close to having a good environment, other than the light under the door. Why mess with low gain non white screens when fixing the issue would eliminate the need for a grey screen?
Have you looked at this screen fabric report, it does not have every fabric but may be of some help
https://www.accucalav.com/wp-content...een_report.pdf
Doug
post #14 of 35 Old 09-25-2019, 07:02 AM
Liked: 3009
A matte screen with lambertian reflectance will have the same brightness when viewed from any angle of the viewing cone. By definition all matte (lambertian) grey screens must be <1.0 gain because only a white matte screen can have 1.0 gain. In addition to white and grey, screens can employ various means to achieve directional gain to direct more image light toward the center of the viewing cone where the prime seating is and less to the sides so people seated off center will see a dimmer image,.
White/grey and matte/directional gain are two basic screen attributes that work together to define total image gain and where that gain can be seen within the viewing cone. Going from white to grey on a directional gain screen basically has the same effect as it does on a matte screen where gain is reduced to the degree of greyness. So, for example, adding 2.0 directional gain to a 0.5 gain grey screen will give you a 1.0 gain screen at the center of the viewing cone and increasingly <1.0 gain as you move out of the center of the viewing cone.
bud16415 likes this.
post #15 of 35 Old 09-25-2019, 07:35 AM
Liked: 3009
Think of it in simplest terms. A 0.5 gain matte grey screen reflects exactly half as much projector image light as a 1.0 gain matte white screen. Since the screen is a passive device it reflects all light equally, from darkest color to lightest. Going from a matte screen reflecting light equally across the viewing cone to one with directional gain simply redistributes the light within the viewing cone with equal reflectance for all colors from darkest to lightest. Confusion can creep in when we read some of the screen marketing claims that suggest performance attributes at odds with the science.
post #16 of 35 Old 09-26-2019, 06:13 AM
Quoted: 29 Post(s)
Liked: 4
I'm currently dealing with this same problem. I have samples of Seymour Glacier White and Gray and SilverTicket white and gray. When compared side by side I like the whites from the white and the blacks from the gray. I wonder if I should only compare one at a time, because side by side makes it very difficult to pick (see attached image). This is with a epson 5050ub on high with a 144" size from ~14ft (seating distance is ~10ft) so there should be plenty of fL to go around (~42fL based on projectorcentral). The room isn't light treated though so the walls are gray, but the room has a vaulted ceiling and plenty of space on the sides, but I still feel during bright scenes the room gets lit up from reflections. Is it possible to calibrate the projector so I can get the whites as bright on the gray screen as they are on the white or am I just being fooled by having them side by side and it isn't possible (but I probably wouldn't notice if they weren't side by side)?
escapeyourmind is offline
post #17 of 35 Old 09-26-2019, 06:39 AM
Quoted: 41 Post(s)
Liked: 9
I'm currently wrestling over whether to move to a higher gain screen due to my feelings that HDR is too often too dark. I was initially trying to make adjustments via calibrating with HCFR software and a colorometer. In the end I found that the source video along with the director's decisions made more difference than any adjustments I was making.
Modifying screen gain seemed to only nibble around the edges in a war between contrast loss and higher brightness (whiter whites). As an example watch HDR content on Netflix, "I - Land" which is shot in daylight and the tropics, it's always dull and purposely shot in shadow. A great example that HDR brightness isn't your equipment's fault is seen in two HDR series which are both shot in dark grimy, sooty, blackish environments. View Prime Video's Carnival Row which is over dark then watch season one episodes of Peaky Blinders and see how an almost identical dark environment is properly lit showing off HDR.
Peaky Blinder (first season) has the whole array of scenes from night, low lit rooms, smokey rooms with high contrast bright streaming sunlight including that dusty look and crystal clear day scenes. Watch similar scenes in Carnival Row and you bounce between simply too dark invisible details versus my god the contrast is horrible. Some other 4K HDR videos that got the lighting right are Netflix - Travelers and Prime's - Expanse (season 2-3 as season 1 has significant blue shift). Most of the other Netflix HDR videos have gone to the dark side. With Netflix's Marco Polo, I almost cried as the supreme effort in costumes and grand settings are primarily shrouded in smoky haze or unnecessary darkness which dulls colors.
I recently searched on why so many videos are over dark (not even HDR related) and found I'm not the only one complaining. It seems that more often than not it's the director's/producers decision and no AV equipment changes or adjustments are going to make up for their poor judgement. It's a trend from avanguard films of yesteryear.
I think these "artists" need to actually watch their dark content in ordinary people's viewing rooms and see how often their content can't be enjoyed or effectively communicate as they want to be known as "artists" rather than provide viewable entertainment. I've read much the same about imbalanced audio where you can't make out the dialogue due to whispering or background sounds. The producers of these shows need to wake up as the capabilities of the 4K HDR/Dolby Vision, multi speaker digital audio reveal how poor their "artistic" decisions really are. It's sad when the blank canvas so badly out strips the artists capabilities.
3DSammy is offline
post #18 of 35 Old 09-26-2019, 04:11 PM
Liked: 3009
Originally Posted by escapeyourmind View Post
... Is it possible to calibrate the projector so I can get the whites as bright on the gray screen as they are on the white or am I just being fooled by having them side by side and it isn't possible (but I probably wouldn't notice if they weren't side by side)?
You obviously haven't read the previous posts in this thread that already answered the question you just asked.
post #19 of 35 Old 09-26-2019, 05:34 PM
DavidHir's Avatar
Quoted: 2576 Post(s)
Liked: 2258
Hi guys.
Your projector will need to be properly calibrated to the screen.
I've owned the HD Pro 1.1, 0.9, and now own the Stewart ST100. All of them can be calibrated to 6500K.
If you with the 0.9, you need to have a pretty good room.
DavidHir is offline
post #20 of 35 Old 09-27-2019, 01:45 AM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
Is there a guide "out there" to calibrating JVCs with HD Progressive?
post #21 of 35 Old 09-27-2019, 09:53 AM
bdht's Avatar
Quoted: 278 Post(s)
Liked: 108
http://www.curtpalme.com/forum/viewtopic.php?t=10457
bdht is online now
post #22 of 35 Old 09-28-2019, 06:10 AM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
Great. I already have the DVE disc, a tripod and an X-rite i1 PRO :-)
post #23 of 35 Old 09-30-2019, 07:12 AM
Quoted: 29 Post(s)
Liked: 4
Ok I get that they can look the same with more lumens and calibration, and side by side can be misleading. I guess phrased another way, what can I look for to help decide between a white 1.0 gain screen and a gray 0.8 gain screen without calibration equipment?
Would you find a high contrast scene, adjust brightness/contrast for that scene for one sample, watch some content/make some notes. Then switch to the other sample, adjust brightness/contrast for the same scene again, watch more content/more notes?
Is there another aspect to choosing between white and gray when they can really look exactly the same when calibrated + more lumens and it really only comes down to your environment?
In which case if I some ambient light from reflected surfaces (walls etc) even when watching at night with no other sources of light other than projector/reflected (and not willing/able to paint the walls), is it an easy "gray screen would be better" response?
post #24 of 35 Old 09-30-2019, 12:23 PM
Liked: 3009
First of all, most people do not have their projectors professionally calibrated. Projectors in general have become more color accurate from the factory over the years and most people find the factory image perfectly acceptable. As for matte white and matte grey screens, as long as both are color neutral there really isn't much calibration involved other than going to a brighter setting on the projector. to compensate for the lower gain screen. In simplest terms a neutral matte grey screen could be considered a "darker white."
You can try back-to-back testing but it's not always reliable. The differences can be fairly subtle and it's hard to remember exactly what the first one looked like after time spent setting up the second one. In fact unless it's a blind test where someone else does the setup and you don't know which one you're viewing, any preconceptions you might have can subtly influence your opinion of the differences you're seeing.
The main advantage of a matte grey screen over a matte white one when illuminated to the same level by adjusting projector lumens is that the grey screen will reflect less ambient light and appear slightly less washed out. Again, in simplest terms, you're increasing projector light while ambient light stays the same so you're increasing the proportion of image light to ambient light (including cross reflections from the screen onto room surfaces and back onto the screen).
So, with the one potential disadvantage that your projector must be capable of producing enough lumens to properly illuminate the screen to a level that's satisfactory to you, a neutral matte grey screen will always have at least a small advantage over a neutral matte white screen in lessening the effects of ambient light. For example a 0.8 gain matte grey screen will reduce the effects of ambient light by ~20% over a 1.0 gain matte white screen. While a 20% difference may not be dramatic even that much can be useful to those who are most sensitive to screen image washout from ambient light (including cross reflections).
post #25 of 35 Old 09-30-2019, 02:02 PM
bud16415's Avatar
Liked: 1075
Here is an example done years ago by a member. It is a side by side comparing a mild neutral gray to a white. The samples were painted one with a flat white paint the other with a flat neutral gray in around the .7-.8 gain range.
One photo is taken with a dark theater setting and the other had some ambient light turned on in the room.
Draw your own conclusions there were no trick settings to the camera and I believe the poster to be honest and he said the photo closely showed what his eyes saw.
ID:	2621884   Click image for larger version
Bud
bud16415 is offline
post #26 of 35 Old 10-01-2019, 03:33 AM - Thread Starter
Webmonkey's Avatar
Quoted: 166 Post(s)
Liked: 45
I do not know if it is just my monitor, but with the lights of, the black levels look identical on these 2.
post #27 of 35 Old 10-01-2019, 05:49 AM
bud16415's Avatar
Liked: 1075
You can trust that they are not the same. A gray screen will lower the black floor and peak whites the exact same amount and it will show up in photos. Of course like a projector can’t be adjusted for two screens at once a camera can’t also. At least they didn’t used to be able to until digital cameras came up with HDR settings not to be confused with video HDR.
Year ago we used to make special images as still frames to use as test photos and many had ether a mirror image folded down the middle or a repeat image one on each side. Some were real images and some just test images. The idea was to do an A/B and then take a photo. You could then go in with a color picker tool and check the photo and that’s where you could measure say a white and black twice and see what happened between sides of the photo. We had all kinds of people saying they came up with a screen that would darken blacks and brighten whites at the same time. There was an advantage with the ambient light examples in preserving CR but not improving over what the projector could do on its own, as you would suspect.
We even got more complex than that and made test slides that had blank windows in them that would let thru the full white light the projector was capable of making and at those areas on the screen we would hang Munsell test cards of exactly the same color or gray scale so we could measure them in the photo and adjust the photo image in an attempt to remove the photo bias within the same photo.
None of this convinced some people that trusted their eyes and saw what they saw and liked what they liked.
I’m a long time fan of simple dark neutral gray screens mine now is a .5 gain. I also don’t have a huge screen 110” and a pretty bright projector and all that works well together. My image isn’t much different in the dark than having a white screen and less lumens as my room is very good at controlling light. It is much better IMO than a white screen when I turn some well angled task lighting on for sports or family TV viewing.
The photos I posted are not a perfect example but kind of relate the idea of what is going on with lowering the black floor and letting your eyes fool you on the rest. Black can never be any darker than what the screen looks like with whatever light is on in the room as projectors don’t send out black they try and send out nothing.
Dave in Green likes this.
Bud
bud16415 is offline
post #28 of 35 Old 10-01-2019, 06:07 AM
Quoted: 29 Post(s)
Liked: 4
Thanks Dave and Bud! I think this has helped focus the decision of a white and gray screen. Side-by-side and back-to-back testing both didn't seem to work for me due to the things mentioned above (side-by-side you can't set lumens for both at the same time, and back-to-back you can't really remember what each looked like after switching). So it does pretty much come down to environment and projector, either have a light cannon and gray screen if you don't have full control (painted walls, etc), or a white screen and a fully controlled room. Provided the screens you are comparing are both neutral.
In my case because I am not willing/able to paint all the walls and thus will have some reflected light it makes sense to go with the .8 gain gray screen. From the example Bud posted I do tend to prefer the gray sample both with the lights on and off in that example. Which in my own testing the washing out of some color and blacks is far more noticeable to me than whites that aren't as bright (when using the same lumens). It has made it slightly difficult to test the white screen sample as my walls are a similar light gray so it am always comparing it to that so it may not be completely fair as the white always looked washed out. But it sounds like due to my reflected light the gray just makes more sense all else being equal.
post #29 of 35 Old 10-01-2019, 06:25 AM
bud16415's Avatar
Liked: 1075
Keep in mind there are also more advanced options that get into using angular gain and or gain plus gray to help with specific problems where ambient light, introduced or reflected is coming in at angles unlike the projectors beam.
These screen come with advantages and also cons.
If you want to keep it simple and go with a screen that has wide viewing angle, then white/gray is the way to go and I think you have a good handle on that.
Bud
bud16415 is offline
post #30 of 35 Old 10-01-2019, 06:38 AM
Quoted: 29 Post(s)
Liked: 4
Yep, I also grabbed some samples of some ALR grays and knew right away that it wasn't for me. The viewing angle was too narrow (I have fairly wide seating), and minor moving caused pretty noticeable changes in the image. So I dropped those almost immediately and stuck to just white or gray. I think I'm pretty settled on the Seymour Glacier Gray now!
Reply Screens
