Elunevision Reference Studio 4K material question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-08-2019, 01:28 PM - Thread Starter
dfarina's Avatar
Quoted: 26 Post(s)
Can someone please let me know which side of this material faces the viewer?There is a smooth side with a slight shine and on the other side there is a Matt finish that has a slight texture to it.Thanks in advance
dfarina is online now
post #2 of 3 Old 10-10-2019, 04:36 AM
asharma's Avatar
Quoted: 1841 Post(s)
Liked: 581
Your better off to ask Elunevision but my gut tells me matt finish with slight texture is the side facing the projector if using front projection...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is online now
post #3 of 3 Old 10-10-2019, 03:15 PM - Thread Starter
dfarina's Avatar
Quoted: 26 Post(s)
Thanks,yea it's a front projector and you are correct about which side faces the projector.I was looking for a quick answer and was not able to get a hold of Elunevision at the time,but all is good now.
Reply Screens
