Does having two centers (1 above screen, 1 below) address voices being off-center? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-19-2019, 08:42 PM - Thread Starter
Quoted: 145 Post(s)
One advantage I've seen about having an AT screen is that the voices come directly from the center of the screen, which is great. If you don't have an AT screen you need to have a speaker below or above the screen, and the voices come from the floor or the ceiling, which is annoying.
Would have two center speakers, one above and one below the screen, address this issue? Would this make the voices seemingly come from dead center? I'm hoping to have the benefits of a non-AT screen while still having the voices from from the middle.
Snoochers is offline
post #2 of 10 Old 10-19-2019, 08:57 PM
Shadowed's Avatar
Quoted: 962 Post(s)
Liked: 925
Shadowed is offline
post #3 of 10 Old 10-19-2019, 09:00 PM - Thread Starter
Quoted: 145 Post(s)
Originally Posted by Shadowed View Post
Oh sorry, for some reason none of the threads come up. Maybe because I’m on my phone and search doesn’t seem to work effectively. I’ll try on my PC tomorrow. If there’s a particular thread that stands out and you can spare a few seconds I’d appreciate you sharing it.
post #4 of 10 Old 10-19-2019, 09:10 PM
Shadowed's Avatar
Quoted: 962 Post(s)
Liked: 925
Generally, there is a big potential for comb filtering when using 2 speakers with the exact same signal.
Some claim it is a terrible idea and others say it is not so bad.
Shadowed is offline
post #5 of 10 Old 10-19-2019, 09:14 PM - Thread Starter
Quoted: 145 Post(s)
Thanks. The fact some people say it’s terrible is provably a good enough reason for me to drop the idea for now.
post #6 of 10 Old 10-20-2019, 12:31 AM
edfowler's Avatar
Quoted: 325 Post(s)
Liked: 170
I used top run an acoustically transparent screen then switched to a solid one. I didn't notice that he dialogue was coming from underneath.
I did, however, just install a new to me avr that raises the perceived dialogue up to the center of the screen very effectively.
Sent from my SM-G950U using Tapatalk
Chad B calibrated JVC RS600, 112" 2.35 DaLite 2.8 High Power Screen (395 calibrated nits baby!!), 7.5.4 Marantz AV7702,Yamaha RX-A3050, Yamaha RX-Z9, Aerial Acoustics Model 6, Model 5, CC3, Def Tech UIWBP/A, 4-15" Infinite Baffle Sub + 15" Velodyne Sub Near-field, OPPO 203, Panasonic UC420, Geek Pulse DAC, NVidia Shield
edfowler is online now
post #7 of 10 Old 10-20-2019, 06:56 AM
bud16415's Avatar
Quoted: 2164 Post(s)
Liked: 1084
Most AVR have a setting for a phantom center. It takes the center channel and adds it into the RL. If you sit near the center of the seating I find it works very well. I keep my center off most of the time as we sit in the two center seats. When I get a larger group of people I turn on my lower mounted center that is angled up. I find lower is better than upper as lower is closer to ear level.
I have never tried one above and one below.
Bud
bud16415 is offline
post #8 of 10 Old 10-20-2019, 07:09 AM
Mike Johnson 3's Avatar
Quoted: 72 Post(s)
Liked: 61
BAD idea, as you've already concluded.
1 channel --> 1 speaker
JVC NX7, Paladin DCR, 125" 2.40:1 Seymour Center Stage XD
(previous: JVC 540/790, Epson 5040UBe,+more)
Sony 75XZ9D, 75X900E, 65X850C, 800E, Panny 4K, Plasma, & more...
(Previous: 65" 930E, 940D, LG 65" C7, 65" 900E, Samsungs, etc...)
speakers: Dynaudio M1's, M3A's, BM15A's, NS10's, dozens of Bryston amps
Mike Johnson 3 is offline
post #9 of 10 Old 10-20-2019, 05:20 PM
Dave in Green's Avatar
Quoted: 3830 Post(s)
Liked: 3030
The ventriloquism effect satisfies most people with a center speaker properly mounted either immediately above or below the screen and aimed at viewers ears. We see someone's lips moving near the vertical center of the screen and our brain processes the sound coming from above or below and tricks us into believing the sound is coming from the lips. Some people don't properly process the ventriloquism effect and are more aware of the conflict in visual and audio. Others simply obsess about seeing a speaker above or below the screen and can't get it out of their heads that it isn't located exactly where the dialog is coming from. Since we're all wired a little differently we need to try for ourselves and see what works for us. Each case can vary. I tried both below and above and in my setup and for my personal preference above the screen sounded better.
Dave in Green is offline
post #10 of 10 Old 10-21-2019, 11:49 AM
Craig Peer's Avatar
Quoted: 7093 Post(s)
Liked: 8423
Running Audyssey ( or other room correction software ) more or less eliminates this problem.
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is offline
Reply Screens
