Replace screen material or buy new screen jvc rs1000/nx5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-30-2019, 05:48 PM - Thread Starter
alex014's Avatar
Quoted: 20 Post(s)
Hi. I recently purchased the new jvc RS 1000 and I am considering upgrading my screen . It is a dalite cinema contour from approximately 2006 . So I am wondering if I should upgrade the material or just buy a new screen. My initial thought was to buy either hd progressive material in either the .9 or 1.1 gain. The other alternative is to purchase a new screen completely possibly a different brand. It seems to be much more cost effective to replace the material but Are dalite screens a good screen I have seen posts that there are sparkles on bright scenes . I don’t want to be penny wise and pound foolish . Also in a light controlled room with a 106” diagonal should I get a .9 or 1.1 gain screen . Sorry for the rambling post and thank u for any help
alex014 is offline
post #2 of 4 Old 10-30-2019, 06:08 PM
skylarlove1999's Avatar
Quoted: 1043 Post(s)
Liked: 724
I would watch some familiar material with the new projector and old screen. See how you like it. Are your room conditions dark colors and minimal ambient light?
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #3 of 4 Old 10-30-2019, 06:24 PM
andyng's Avatar
Quoted: 38 Post(s)
I'm in the exactly same dilemma. Got a new NX5 and trying to see if I can replace the old 106" Silver Ticket or just buy a new, bigger, better, more expensive Stewart or Screen Innovations.
One one hand, replacing the materials is the cheapest solution since the frame is pretty solid. I just don't want to find glue and hack the materials together. The other choice is to put down 1-2K for a new screen.
andyng is online now
post #4 of 4 Old 10-31-2019, 09:14 AM - Thread Starter
alex014's Avatar
Quoted: 20 Post(s)
Thanks for the info. Yes the room is dark colors , black ceiling and light controlled . The only time we have light on is when we are eating and generally I use two wall sconces that r dimmable
alex014 is offline
Reply Screens
