Any UST ALR screens larger than 120"?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-05-2019, 04:22 PM - Thread Starter
Liked: 0
Hi everyone,
I'm about to swap out my conventional long throw projector for an UST. I'm leaning toward the Epson, which officially supports 130", but I can't find an UST ALR screen that is greater than 120". Anyone run across one? I don't care if it's fixed or motorized. The closest I've come across is buying the screen material and DIY frame.
Cheers
Roo01 is offline
post #2 of 3 Old 11-05-2019, 09:50 PM
bix26's Avatar
Quoted: 754 Post(s)
Liked: 403
Originally Posted by Roo01 View Post
Hi everyone,
Cheers
I think some of the higher end brands do, but then your talking big money custom order upwards of $5,000 at least. As far as I know there isn’t any company that sells lenticular screen material. Regular non-lenticular ALR material won’t work, as it will treat off axis light coming from a UST as ambient light. Unless you have a lot of ambient light a standard screen would be an option too.
bix26 is online now
post #3 of 3 Old 11-06-2019, 11:32 AM - Thread Starter
Liked: 0
Hi bix26,
Thank you for your post. There are still a couple of months before the Epson goes on sale so hopefully there will be more options by then.
Cheers
Roo01 is offline
Reply Screens
