Screen recommendation for Epson 5040UB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-12-2019, 12:18 PM - Thread Starter
Quoted: 113 Post(s)
Liked: 52
Hello,
I am looking for screen recommendations for the Epson 5040UB. This will be my first home theater. The space I'm using has only 1 window, which I plan on blacking out so light is not an issue.
I am looking for some acoustically transparent as I'm planning on putting my center behind the screen. 2.35/2.4 ratio.
Right now I'm looking at the Silver Ticket Acoustically transparent 2.35 125" screen from amazon for $440. Are there any better options for the price I can do?
I'm not wanting to spend a lot unless there's a compelling reason to do it. My audio and projector are stretching my budget as is!
Would love to hear your thoughts.
Brandon Smith is offline
post #2 of 6 Old 11-12-2019, 12:26 PM
skylarlove1999's Avatar
Quoted: 1107 Post(s)
Liked: 783
Originally Posted by Brandon Smith View Post
Hello,
If you are good with DIY, I would look into AT material from Seymour AV. Amazing screens. Way better than Silver Ticket.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #3 of 6 Old 11-12-2019, 12:37 PM - Thread Starter
Quoted: 113 Post(s)
Liked: 52
Thanks for the suggestion. They look nice.
post #4 of 6 Old 11-12-2019, 09:41 PM
rekbones's Avatar
Quoted: 1115 Post(s)
Liked: 574
The biggest factor after controlling the external ambient light is the reflected light from white/light colored surfaces as in a white ceiling. What color are all the surfaces in the room including furniture?
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #5 of 6 Old 11-13-2019, 05:45 PM - Thread Starter
Quoted: 113 Post(s)
Liked: 52
Good comment. I didn't even consider that.
The attached photos show the current colors, but we are most likely going to repaint soon. Don't think I'll be able to convince the wife to black it out, but we'll probably do a dark blue or maroon.
Any suggestions?
ID:	2640740   Click image for larger version
post #6 of 6 Old 11-17-2019, 04:08 PM - Thread Starter
Quoted: 113 Post(s)
Liked: 52
Will probably be placing my order tomorrow. Any other brands I should consider besides Seymour?
Reply Screens
