Clean - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By noob00224
post #1 of 6 Old 11-23-2019, 01:18 PM - Thread Starter
Quoted: 147 Post(s)
Liked: 32
Question Clean
Best way to clean a screen the right way ?
ng4ever is offline
post #2 of 6 Old 11-23-2019, 05:21 PM
Quoted: 1008 Post(s)
Liked: 285
What kind of screen?
Fabric?
ng4ever likes this.
noob00224 is offline
post #3 of 6 Old 11-24-2019, 06:49 AM - Thread Starter
Quoted: 147 Post(s)
Liked: 32
Fabric?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ng4ever is offline
post #4 of 6 Old 11-24-2019, 07:01 AM
eljaycanuck's Avatar
Quoted: 1994 Post(s)
Liked: 2832
Wipe the screen lightly and in straight lines with a soft, damp (but well wrung-out) cloth. When finished, wipe again lightly with a soft, dry cloth.
eljaycanuck is offline
post #5 of 6 Old 11-24-2019, 09:15 AM
Quoted: 138 Post(s)
Liked: 43
What he said above. If you have some real tough stuck on stuff you can also you mild soap with these elite screens. But normally the damp cloth does the job.
[email protected] is offline
post #6 of 6 Old 11-24-2019, 09:57 AM
Liked: 285
https://elitescreens.com/front/front...il/product/156
Fabric is:
https://elitescreens.com/front/front...il/product/290
Cleaning instructions as per the website:
https://elitescreens.com/images/down...Care_Sheet.pdf
1. Materials needed:two Lint-Free white cloths, Mild Soap (hand soap is suitable) and Water.
2. Take the Lint-Free cloth and submerge it in warm water for cleaning light dust and dirt. For stubborn stains or a sticky surface, a solution of mild dishwashing liquid diluted with warm water should be used.
3. Completely ring out cloth so it is lightly dampened, not drenched.
4. Using the damp cloth, lightly wipe in an up and down motion starting at the left of the screen moving to the right of the screen. DO NOT WIPE IN CIRCULAR MOTION.
5. Once you have completed wiping the entire screen with a dampened Lint-Free cloth, use the dry Lint-Free cloth to wipe off any excess water from the screen.
**If heavily soiled (marked permanently):
You may use alcohol with a Q-Tip to clean.
1. Dip one side of the Q-Tip in Alcohol
2. Gently wipe marked spot ONLY.
3. Use dry side of Q-Tip to go over mark to dry it.
4. You may wipe over with dry Lint-Free Cloth to finish
NEVER ALLOW ANY SOLVENTS TO DRY ON THE MATERIALS AS THEY WILL CREATE A STAIN THAT IS NON-REMOVABLE.**If Heavily soiled (marked permanently): Unfortunately you may NOT use any solution to clean the surface as it will damage the screen. If there is a mark, it is permanent.
Reply Screens
