Need to buy a PJ screen, grey or white? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-25-2019, 04:01 PM - Thread Starter
aoaaron's Avatar
Quoted: 144 Post(s)
I need a 92'' projector screen, HW40Es will be 2.8 throw distance.
I have a room with white walls and white ceiling. I have a blackout curtain on the left side of the room.
Light can be completely controlled during viewing if needed.
I'm not sure which screen to go for?
https://www.ebay.co.uk/itm/92-Premiu...y/192656408433
Would this be okay or should I go for a grey screen? any help would be much appreciated, thank you!
aoaaron is offline
post #2 of 12 Old 11-25-2019, 04:09 PM
skylarlove1999's Avatar
Quoted: 1295 Post(s)
Liked: 953
I would go for an ambient light rejecting screen. Those white walls and ceiling will reflect a good amount of light back onto your screen, washing out the image to some degree. You could consider a painted screen as found here.
@MississippiMan would be happy to work with you on a great painted ALR screen.
https://www.avsforum.com/forum/450-h...topics/2175641
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #3 of 12 Old 11-25-2019, 04:35 PM - Thread Starter
aoaaron's Avatar
Quoted: 144 Post(s)
Thanks. I'm based in the UK and will need a screen which will be ceiling mounted so I'm a bit stuck in regards to budget & experience. I can't afford to currently buy a tab tensioned pulldown screen AND buy some expensive paints with the risk of me wasting the paint and ruining the screen I'd LOVE to explore this option at some point for sure.
If there was someone in the UK willing to do this for me, I'd happily pay them.
I feel like I'm really stuck here
aoaaron is offline
post #4 of 12 Old 11-25-2019, 04:57 PM
Liked: 953
The paint goes right on the wall you don't paint the actual screen you paint your entire wall I would at least send a private message to Mississippi Man to ask him what he thinks
post #5 of 12 Old 11-25-2019, 05:02 PM - Thread Starter
aoaaron's Avatar
Quoted: 144 Post(s)
Yup, I understand. Sadly thats not an option as I have a 65'' TV wall mounted which will later on be a 77 inch OLED so ideally it'd have to be a spray-painted screen which can retract into the ceiling.
aoaaron is offline
post #6 of 12 Old 11-25-2019, 05:04 PM
Liked: 953
Thanks for clarifying now I completely understand your dilemma
post #7 of 12 Old 11-25-2019, 05:08 PM - Thread Starter
aoaaron's Avatar
Quoted: 144 Post(s)
Thanks. Sorry I wasn't clear before. Ideally in 6-12 months time [hopefully moving house], I'll have a dedicated home theatre room and a separate room for the TV, (if I'm convinced by the ALR properties that it doesn't need a TV for backup)
aoaaron is offline
post #8 of 12 Old 11-25-2019, 06:31 PM - Thread Starter
aoaaron's Avatar
Quoted: 144 Post(s)
Also, if I was to just buy a temporary screen and explore the ALR/DIY solutions at a later date.. any suggestions? Is tab tensioned really needed?
aoaaron is offline
post #9 of 12 Old 11-25-2019, 09:32 PM
rekbones's Avatar
Quoted: 1158 Post(s)
Liked: 592
With that small of a screen I would definitely go with a gray screen at least .8 gain. As far as tab tensioned it is the only way to be sure (but not guarantied as some have ripples anyway) the screen is flat. Ripples in the screen cause a distortion that some notice more then others and is most obvious with slow pans across the screen.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #10 of 12 Old 11-26-2019, 01:11 AM - Thread Starter
aoaaron's Avatar
Quoted: 144 Post(s)
Thanks and it won’t affect for instance 3D performance?
aoaaron is offline
post #11 of 12 Old 11-26-2019, 03:25 AM
rekbones's Avatar
Liked: 592
Of course it will effect it but in a white room you need to take what you can get. It's all a compromise.
rekbones is offline
post #12 of 12 Old 11-26-2019, 12:32 PM - Thread Starter
aoaaron's Avatar
Quoted: 144 Post(s)
Thanks, I was just wondering if it would effect is so adversely that the white would be better?
I'm excited to watch Frozen in 3D.
do u know of any stores which do white/grey screen samples?
aoaaron is offline
Reply Screens
