Does anyone use a motorized xyscreens EC2 with IR remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-26-2019, 01:33 PM - Thread Starter
Quoted: 33 Post(s)
Liked: 1
I have just received my XYscreens EC2 and it seems excellent for the price.
Unfortunately, I forgot to specify an IR remote, so it has come with an RF one instead.
Does anyone use one of these screens with IR?
Ultimately, I'd like to use it with my Logitech Harmony remote. Could anyone answer the following?
1. Is the IR capability automatically built in? It looks as though I can just plug in a receiver, but I'm not sure it will be enabled on my screen as I didn't specify it.
2. Are the codes known for these screens, so that I could just plug them into Harmony?
If not, I'll buy the IR remote and use it to teach Harmony the codes, but I guess that would be quite expensive to ship from China.
Any advice appreciated!
daveb975 is offline
post #2 of 2 Old 12-04-2019, 12:23 PM
Heimhenge's Avatar
Liked: 0
Is this what you're looking for? From the XYscreen website:
A、Rs485 control
  1. Baud rate: 2400
  2. Parameter length: 8
  3. Odd-even check: N
  4. Start position: 1
  5. Stop position: 1
B、Control code
  1. Up code: 0xFF 0xAA 0xEE 0xEE 0xDD
  2. Stop code: 0xFF 0xAA 0xEE 0xEE 0xCC
  3. Down code: 0xFF 0xAA 0xEE 0xEE 0xEE
C、Function control
  1. Up code: motor up
  2. Stop code: motor stop
  3. Down code: motor down
Heimhenge is offline
Reply Screens
