150" AT screen 1.3g that compets with XD - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 4 Post By chriscmore
  • 1 Post By Craig Peer
  • 1 Post By gil393
  • 1 Post By rossandwendy
post #1 of 14 Old 01-09-2020, 04:11 PM - Thread Starter
Schurter's Avatar
Quoted: 56 Post(s)
looking to do AT 150" screen.
Something with a true 1 plus gain.
Seating 15-17 ft from screen.
Projector
5050
Jvc nx3
Ht5550
Open to options
Is HDR 100% needed
Schurter is offline
post #2 of 14 Old 01-15-2020, 08:49 AM
timgrady's Avatar
Quoted: 26 Post(s)
Liked: 38
Severtson SAT-4K for woven- rated for 1.18 gain.
http://severtsonscreens.com/material/SAT4K/22
or
Stewart ST130 G4 for microperf.
https://www.stewartfilmscreen.com/en...udiotek-130-g4
Seymour XD is probably your next best option, but it's lower gain than the two above.
I'm debating Seymour XD vs. Svertson SAT-4K for mine. Planning 150" wide 16:9 screen with masking for CIA + IMAX. My last screen was a SeymourAV XD at 130" wide and 2.07:1 AR with CIA masking panels.
Tim
timgrady is offline
post #3 of 14 Old 01-21-2020, 10:40 AM
chriscmore's Avatar
Quoted: 280 Post(s)
Liked: 340
or
Tim
The Severtson SAT-4K, Screen Innovation's Gamma Maestro HD and Dragonfly/Snap AV whatever are the most inaccurate gain ratings for a white screens in the industry. It's because of them that we have to publish both unbenchmarked gain ratings (for calculations and actual science) and benchmarked gain ratings, where we roughly compare it with the basket of lying weasels out there.
Here is a picture of the SAT-4K next to the Stewart Studiotek 100. It's not color balanced, so don't judge the tones of either screen. This picture is just to show the obvious LOWER gain of the SAT-4K than the 1.0 gain Studiotek. In this rough comparison and controlled testing, I've found the ACTUAL gain of the SAT-4K to be 0.87, which is actually very good for a single-layer uncoated-thread woven screen. They didn't have to resort to the detail and contrast-blurring multiple layer trick, either. They should also know that gain isn't awesomeness and highlight that this screen reduces black levels by 13% and would offer a theoretical 25% reduction in room splash contamination resistance.
No woven screen can ever have that high a gain. For coated-thread woven screens we've maxed out the reflectivity in the Center Stage XD by increasing the retro-reflective powder in the pvc coating as high as it can go for both chemical and visual reasons, which is a patented formulation. If you must go higher gain than the XD, then the only options are coated films such as the microperfed Stewart materials.
Cheers,
Chris
Name:	Severtson vs ST100.jpg
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #4 of 14 Old 01-22-2020, 10:49 AM
Craig Peer's Avatar
Quoted: 7599 Post(s)
Liked: 9370
Cheers,
Chris
Add projector contrast and sometimes lumen ratings to that.
chriscmore likes this.
Craig Peer is online now
post #5 of 14 Old 01-23-2020, 02:47 PM
serith's Avatar
Quoted: 860 Post(s)
Liked: 948
i have a 155" 16:9 diy at-screen using white over black rosebrand spandex and i'm not happy with it. i can see the weave of the material and there are visual defects as well. i think i'm going to try spandexworld's 120" white material next.
here is the defect with the material. company would not do a refund because i had already cut the material. there are feint streaks in the top right corner of the screen that are highly visible in bright scenes.
serith is offline
post #6 of 14 Old 01-23-2020, 03:16 PM
gil393's Avatar
Quoted: 97 Post(s)
Liked: 67
I'd try posting about spandex in the diy screen sub-section. They are experts at spandex. Off of the top of my head other than a defect in the material is the possibility that it got stretched too tight somewhere along the line.
gil393 is offline
post #7 of 14 Old 01-23-2020, 03:37 PM
serith's Avatar
Quoted: 860 Post(s)
Liked: 948
this is my 3rd constructed spandex screen. the 60" wide matte milliskin material from spandexworld that everyone raves about was excellent and had no visual defects, however it could not stretch to 155" 16:9 (i was using with a 147" 2.39 scope setup prior). this material looked strange before i attached it to the frame and once on my suspicion was correct. with a flashlight you can see up close that the material is almost like stained or thinner in those streak areas. over-stretching is a different problem where you open up the weave and you end up with a sparkle effect. given rosebrands's reluctance to do anything to help me i'm going to try another vendor's material when i get around to it.
serith is offline
post #8 of 14 Old 01-26-2020, 01:31 PM
gil393's Avatar
Quoted: 97 Post(s)
Liked: 67
I used the 120" spandexworld Milliskin to do a 200" 16:9. Worked great but not enough gain so I switched to XD.
serith likes this.
gil393 is offline
post #9 of 14 Old 01-26-2020, 01:36 PM
serith's Avatar
Quoted: 860 Post(s)
Liked: 948
i figure for $80 it's worth trying the 120" spandexworld material. just placed the order the other day, should have it tomorrow. will report back here or elsewhere how it differs from the rosebrand material.
serith is offline
post #10 of 14 Old 01-28-2020, 10:57 PM
serith's Avatar
Quoted: 860 Post(s)
Liked: 948
for anyone that finds this thread and wonders how this all turned out...
i removed the rosebrand white spandex material that has caused me nothing but grief and installed the 120" wide white spandexworld material and the difference is hard to put into words. while the new material has almost no stretch when installed, visibly it's perfect and i couldn't be happier. my front row of seating from a 156" 16:9 screen @ 12' distance can not see the material weave/pattern, and there are no visible defects like before. best $80 i've spent in a long time!
serith is offline
post #11 of 14 Old 01-28-2020, 11:11 PM
rossandwendy's Avatar
Quoted: 263 Post(s)
Liked: 315
Can't beat the price! Glad it worked out. Those defects on your previous material were bad
Ross
serith likes this.
DISPLAY: JVC RS540, upgrading soon to 150" Stewart or Seymour screen
SPEAKERS/SUBS: Chane A5.4/A2.4/A1.4, Rythmik FV18 x 2
POWER: Outlaw 5000 5-channel amp, Denon AVR-X3300W
SOURCE: multi-region Oppo BDP-103D & BDP-83
rossandwendy is online now
post #12 of 14 Old 01-29-2020, 04:04 PM - Thread Starter
Schurter's Avatar
Quoted: 56 Post(s)
Thanks for the feedback.
I am going to order a large sample of the XD.
is it true the XD screen is closer to .9 gain not 1.2 ?
Schurter is offline
post #13 of 14 Old 01-29-2020, 06:41 PM
Quoted: 263 Post(s)
Liked: 315
AccuCal measured the XD gain at .94
https://www.accucalav.com/wp-content...een_report.pdf
post #14 of 14 Old 02-06-2020, 09:58 PM
JamesVG81's Avatar
Quoted: 111 Post(s)
Liked: 67
Let me know how you like the XD . I’m about to build a new room. Currently I have an Elite screen 138 inch 2.35 AT screen. I’m actually perfectly happy with the screen. The new room I need to go a little bit bigger to fit my new speakers. Front row will be about 11 foot back and Im not sure that will be enough for a 144inch wide screen of XD. Then every one is also all about the spandex screens. I’m doing a DIY screen either way just going to order the material. I have a JVC RS620.
JamesVG81 is offline
Reply Screens
