Display not Working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-10-2020, 01:04 PM - Thread Starter
Rod Stewart II's Avatar
Liked: 0
Display not Working
I recently moved my vizio M 70 upstairs and it was dropped. Now the edge lighting is working and tv responds to volume and input (lighting in specific areas) but the display isn’t working. I looked at boards and it all looks fine. Anyone have any ideas or advice.
I don’t want to part with the tv and if cost is right I will fix it.
Rod Stewart II is offline
post #2 of 3 Old 02-10-2020, 08:52 PM
rekbones's Avatar
Quoted: 1213 Post(s)
Liked: 614
This forum is for projector screens, You need to post in the LCD TV section and most likely there is a thread just for your model. Good luck but I suspect your issue is most likely terminal.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 3 Old 02-12-2020, 10:13 PM
augiedoggy's Avatar
it is repairable but the bonding tabs will need to be removed from one side of the lcd panel as one is likely damaged and the tcon board replacedI have the same model 70" in my bar I got from our local recycling drop off center... had this same very common issue with the larger sharp panels used in vizio tvs.
augiedoggy is offline
Reply Screens
