Changing the aspect ratio of a screen. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-10-2020, 05:22 PM - Thread Starter
SpeedyTheTurtle's Avatar
I got a free ceiling mounted motorized DA-LITE screen because it has 2, 1/16" holes drilled into it accidentally. Besides the holes it is in great shape but the aspect ratio is wrong. The projection area measures 109" horizontally and 68.5" vertically. I am thinking that i can fix both the holes and the wrong aspect ratio with tape. I am thinking I can use 2 small pieces of white tape behind the screen to hide the holes better, they are already not super visible and I think this would hide them even better. I also want to use some black tape at the top of the screen to tape off some of the white section to change the aspect ratio to 16:9. I think I need to tape off 7.5" and I can change the stop point on the motor to not unroll that part too.
Do you think this will work?
Is their a better way to do this?
Do you have any recommended tape?
I am using this with a JVC DLA-X990 projector.
Thank for any help!
SpeedyTheTurtle is offline
post #2 of 4 Old 02-10-2020, 06:27 PM
bud16415's Avatar
Quoted: 2269 Post(s)
Liked: 1190
You can try tape some people have used hockey tape to make a black boarder others have masked and painted the boarder on.
The holes are only a problem if you see them and if it bothers you. I’m sure something white behind will help.
Another method is to hang a piece of black velvet down just in front of the screen and let the screen roll up behind it.
The price was right go for it.
Bud
bud16415 is online now
post #3 of 4 Old 02-10-2020, 08:45 PM
rekbones's Avatar
Quoted: 1213 Post(s)
Liked: 614
Come on really, you have a projector with an MSRP of $8000 and your too cheap to get a decent screen. I am a cheapskate myself but really that projector needs a decent screen.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #4 of 4 Old 02-11-2020, 01:50 AM
Liked: 2
I am currently doing some research to build a screen. And hockey tape seems to be a fine alternativ to the more expensiv velvet tape.
Thanks for the tip.
dkol is offline
Reply Screens
