Yovanxer ALR Screens for standard throw projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-11-2020, 09:05 AM - Thread Starter
Liked: 2
Has anyone heard of Yovanxer screens?
I found the screen on aliexpress. The specs looks very interesting:
https://www.aliexpress.com/item/3301...27092e0e2GWzvV
Material: PVC
Model Number: ALR-CGS080-150
Type: ALR projector Screen
Gain: 1.2-1.6
Viewing angle: 160
Price: 100 inch screen material costs USD 185
The screen consist of multilayer optical structure wich includes fresnel and cylindrical lens layer among others.
Apparently the ALR screen is suitable for short throw projector(focal length more than 1.5m), Medium and Long focus projector.
Does anyone know something similar? Is a screen with the above specs even possible?
dkol is offline
post #2 of 8 Old 02-11-2020, 09:42 AM
Quoted: 1095 Post(s)
Liked: 315
The smallest screen is 80". The throw ratio from 1.5m would be 0.84x. I don't believe any ALR screen can be used with a throw ratio that small.
For that cost better buy some Elite/Carl's ALR and mount it on a wooden frame. At least you know what you're getting.
Gain 1.2-1.6? So they have different versions?
noob00224 is offline
post #3 of 8 Old 02-11-2020, 09:47 AM - Thread Starter
Liked: 2
I think the gain value will change slightly in dependency to the viewing angle, which is quite normal for ALR.
dkol is offline
post #4 of 8 Old 02-11-2020, 10:04 AM
Liked: 315
No that's not normal.
The way ALR fabrics are measured in gain and presented are either with a half gain value, total viewing angle, or with a graph. The half gain angle is the angle that screen brightness is half from what it is when viewed from central axis.
This screen has neither. It just says:
post #5 of 8 Old 02-11-2020, 10:47 AM
bdht's Avatar
Quoted: 416 Post(s)
Liked: 176
If it has fresnel/lenticular layers it should completely reject these overhead lights.
bdht is online now
post #6 of 8 Old 02-12-2020, 01:36 AM - Thread Starter
Liked: 2
Thanks for the clarification. I am quite new to this topic.
dkol is offline
post #7 of 8 Old 02-12-2020, 01:37 AM - Thread Starter
Liked: 2
This makes sense.
dkol is offline
post #8 of 8 Old 02-14-2020, 10:31 PM
augiedoggy's Avatar
Quoted: 18 Post(s)
I just bought one of these screens for $44 a few days ago..
https://www.luxinishop.com/products/...#targetreviews
I got a shipping notification today. I'll post my results when I get it and my new jvc setup.
augiedoggy is offline
Reply Screens
