How to remove creases from Cinegrey 5D ALR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-26-2020, 11:35 AM - Thread Starter
cgott42's Avatar
Quoted: 260 Post(s)
Liked: 30
I have a Cinegrey 5D ALR Elitescreens motorized screen that I'm trying out.
Very impressed, much better than I expected
However it has some creases.
How do I remove them?
cgott42 is offline
post #2 of 4 Old 03-05-2020, 08:42 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 4150 Post(s)
Liked: 2002
Hair Dryer on Low and at a distance of 12"+.....use from the rear....take you time for the material to "gradually warm....that should help unless the creases are actually "set" and have a sharp edge. If so you might be SOOL.
If it came that way it should go "back" that way.
MississippiMan is online now
post #3 of 4 Old 03-05-2020, 09:38 AM - Thread Starter
cgott42's Avatar
Quoted: 260 Post(s)
Liked: 30
I should have updated - I ended up just letting it hang for about a day (i.e. rolled down) and they went away
cgott42 is offline
post #4 of 4 Old 03-06-2020, 05:16 AM
Liked: 2002
That is good news!
All too often that is not the case.
Reply Screens
