Screen position - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1 of 40 Old 02-26-2020, 11:10 PM - Thread Starter
CaptainChunk's Avatar
Quoted: 69 Post(s)
Liked: 25
Screen position
I'm trying to plan out our theater and I'm starting to look at screen position. Our walls in the basement are only 7' 1.5" tall.
Some questions.
  1. I have total light control in the room and am planning on making the walls as dark as possible. How close is too close to the ceiling and walls?
  2. Due to the short ceiling, I am considering one of the newer UST 4k laser projectors to avoid something hanging from our ceiling. Do these projectors work well with acoustically transparent screens?
  3. What are some good acoustically transparent screen materials for these UST 4k laser projectors?
  4. We watch a lot of old movies from all decades, would a 16x9 screen be the way to go?
Thanks for the help. Here is a potential layout of our room.
CaptainChunk is offline
post #2 of 40 Old 02-27-2020, 06:25 AM
rekbones's Avatar
Quoted: 1248 Post(s)
Liked: 630
I personally would lay that room out differently. With two rows you only have two good seats and two lousy seats. Put the screen opposite the bar and place four seats side by side and hang the projector over the bar so no one hits their head on it. UST will cost considerably more for the same performance as a standard throw projector. Another note with standard throw is power lens memory unavailable with UST would be a good option for a 2:35 screen as you are height limited. UST with an ALR screen that can't be AT is good in a more lighted environment.
skylarlove1999 likes this.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 40 Old 02-27-2020, 07:32 AM
bud16415's Avatar
Quoted: 2319 Post(s)
Liked: 1219
If you are just in the planning stages now I agree with @rekbones and look at changing the layout and sticking with a conventional throw projector. I would even go as far as moving the bar to the wall you have the screen on and then put bar top seating behind your single row of 4 seats.
As to your main question I’m a big fan of immersion and presentation and it is hard to advise others on what they may like. I like the suggestion of a projector and screen to do CIH constant image height with a 2.35:1 screen but I also sizing a 16:9 screen to also allow for the new IMAX sized movies and such.
I painted my whole wall to be a stealth screen and if your floor and ceiling are dark colors there is no reason you can’t project close to floor to ceiling height if you needed to. With two row seating that is harder to do as you have to have the image higher so the second row can see. Another reason a single main row and maybe a second row on bar stools would work better.
Bud
bud16415 is online now
post #4 of 40 Old 02-27-2020, 10:09 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
All good points. I hadn't thought much about changing the orientation of the room. If the bar is left in place, the seats would be much closer to the screen. I could build a nice hush box into the bar ceiling though. See a quick model I did in the next post.
Thanks for the idea of moving the bar. The bar is plumbed and has electrical run so it will be more complicated to move it. Check out the next post for another mockup.
post #5 of 40 Old 02-27-2020, 10:10 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
Another layout option thanks to suggestions.
Currently building the Quarterdeck Club
post #6 of 40 Old 02-27-2020, 10:21 AM
rekbones's Avatar
Liked: 630
I like that layout much better. Speaker placement will be difficult for 5.1 and beyond. Where do you plan on putting the AV equipment and what kind of audio do you plan?
rekbones is offline
post #7 of 40 Old 02-27-2020, 10:27 AM
bud16415's Avatar
Liked: 1219
I like it and the projector built into the bar ceiling would be good.
With today’s projectors its all about immersion. What size screen are you looking at and what would be the seating distance? What will the room be used for? Movies sports etc. Will viewers sometime be elsewhere in the room? If so you might want to think about sizing the screen for IMAX and at that size it would great within the whole room for sports etc.
Bud
post #8 of 40 Old 02-27-2020, 10:35 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
Oh no. I think this might be the best layout and probably the most expensive to do too. I should just stop modeling now.
rossandwendy likes this.
post #9 of 40 Old 02-27-2020, 10:38 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
I just did another layout. Scroll down this thread. I love audio more than video so I'd love to do 7.2.4 if possible. Check out my build thread for more info about the Quarterdeck Club.
I'd love to do an acoustically transparent screen to hide speakers behind. I'm open to the best screen size for my room. Check out my build thread for more info about the Quarterdeck Club.
post #10 of 40 Old 02-27-2020, 11:04 AM
bud16415's Avatar
Liked: 1219
I will check out the other thread. I like the bar there.
Bud
post #11 of 40 Old 02-27-2020, 11:11 AM
skylarlove1999's Avatar
Quoted: 1710 Post(s)
Liked: 1446
I like that layout much better as well
Sent from my SM-G965U using Tapatalk
Tristan Jones
skylarlove1999 is online now
post #12 of 40 Old 02-27-2020, 11:15 AM
Liked: 1446
This is the best layout except for maybe where the projector will go. In this layout is there a room on the wall opposite the screen behind the wall? Maybe your projector could go in that room along with your av equipment?
Tristan Jones
post #13 of 40 Old 02-27-2020, 11:21 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
There is a large laundry room next to this one where it would be easy to place a projector on the other side of the wall. That would eliminate noise from the projector as well as maintain the ceiling height.
post #14 of 40 Old 02-27-2020, 11:25 AM
Quoted: 21 Post(s)
Liked: 1
Some questions.
What program are you using to do the layout of your room?
Bigc05 is offline
post #15 of 40 Old 02-27-2020, 11:25 AM
bud16415's Avatar
Liked: 1219
Moving the bar would not be too bad with the ceiling unit even. Relocating the wet bar and plumbing would be a little more tricky though.
It doesn’t look bad though leaving the bar where it is. Might be a little congested if you are planning bar stools though. As a walk up bar it would work fine.
Down on the end looks great though.
Bud
post #16 of 40 Old 02-27-2020, 11:30 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
I've been using the free online version of Sketch Up. It took me a good 4-5 hours of struggling to learn it before it started to make sense to me. Now I love it.
post #17 of 40 Old 02-27-2020, 11:33 AM
Liked: 1446
I like the idea of the projector not being in the room to eliminate noise and from someone bumping into it. I am not a big fan of UST projectors. Is the laundry room finished? My only concern about placing the projector in there would be dust if that space is not finished.
Tristan Jones
post #18 of 40 Old 02-27-2020, 11:42 AM
Quoted: 1385 Post(s)
Liked: 404
If the room's walls are treated with dark paint an alr is not required.
Is that fireplace going to be on while the projector is running?
Any light coming from the stairwell?
What's the budget?
noob00224 is online now
post #19 of 40 Old 02-27-2020, 12:00 PM
Craig Peer's Avatar
Quoted: 7798 Post(s)
Liked: 9871
One row is better in this room. In fact, that's what I did. Click my theater link. Also, why even have a bar in your theater ?
Craig Peer is offline
post #20 of 40 Old 02-27-2020, 12:22 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
I've got a carpenter coming over tonight to bounce some ideas off of. I agree that the bar would work best on the south end of the room.
post #21 of 40 Old 02-27-2020, 12:24 PM
David Ortiz's Avatar
Quoted: 76 Post(s)
Liked: 60
I'm puzzled. You mention an AT screen, but none of your layouts show space behind the screen.
David Ortiz is offline
post #22 of 40 Old 02-27-2020, 12:24 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
The laundry room is finished and very nice. I would like to figure out a way to get the equipment in there if possible.
post #23 of 40 Old 02-27-2020, 12:29 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
What's the budget?
The room will be painted very dark. No light from the stairwell. The room should be 100% dark.
Fireplace will be on sometimes. The wife likes to be warm.
Budget is TBD. I should probably talk to my wife about that. She is completely onboard with this project.
post #24 of 40 Old 02-27-2020, 12:31 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
We have to have a bar somewhere in our house. It is either in the basement or in the attic where we have a second, full kitchen. The basement is much better for having friends over and hanging out. The attic is two floors away and we'd have to bring friends through our more personal spaces.
post #25 of 40 Old 02-27-2020, 12:33 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
Good catch. I haven't got that far yet. How much room is typically reserved behind the screen? Depends on speakers to some degree. I was thinking about going with DIYSG speakers.
post #26 of 40 Old 02-27-2020, 12:44 PM
Liked: 1446
I think that is a great idea. Adds more expense but worth it in my opinion.
Tristan Jones
post #27 of 40 Old 02-27-2020, 12:49 PM
Liked: 1446
Actually is more dependent on the AT screen than the speakers. Some screen manufacturers say as little as 3 inches . You need to pick a screen and a projector first to make sure they would be a good match. Most AT screens you need to be back at least 10 ft or more so you don't see the weave or micro perforation pattern. Have to make sure your projector will project the size you want from your throw distance. So I would make sure my screen and projector are chosen before you begin construction. Nothing worse than having to change things up later on and waste money.
Tristan Jones
post #28 of 40 Old 02-27-2020, 12:51 PM
Craig Peer's Avatar
Liked: 9871
Well, I do have a wine cellar, so I get it. Just not in my theater.
post #29 of 40 Old 02-27-2020, 12:57 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
For our last theater, I built a spandex screen. Sat about 10' from that and loved it.
No construction will start until the entire theater room is planned out, top to bottom.
post #30 of 40 Old 02-27-2020, 12:59 PM - Thread Starter
Quoted: 69 Post(s)
Liked: 25
We've got about 130 bottles to find storage for plus all of my bartending stuff.
Reply Screens
