Semi-Comprehensive ALR and Grey Screens Review - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Cryptic7
  • 1 Post By Dave in Green
post #1 of 6 Old 02-27-2020, 06:16 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 4
Hello
I have spent a good deal of time sampling various ALR and Grey materials, mostly in the budget category, but also including SI's Slate materials. I feel like I should share my thoughts and comparisons, and when I have time will post some pictures. I feel like this will help anyone looking for a screen as I have been. I will welcome questions here for people looking for a similar screen as I was.
As a background, I've been into Home Theater for a long time, but only have been able to afford a projector since 2016. At that time I bought an Epson 3000 and a Silver Ticket High Contrast. I sampled several screen materials from Elite and bought the HC sight unseen. It has been good but I always wondered what other materials would do at a higher price.
I recently moved and have been sampling materials for a new screen (smaller as per room needs). My needs for this room were wide viewing cone (to prevent hotspot due to my short throw), mild to moderate ALR, but low artifacting in the dark which is where I mostly watch movies.
I got samples from Elite (Cinegrey, Cinegrey 3D), SI (Slate 0.8, Slate 1.2), Seymour (Matinee Wide, Matinee Black, Glacier Grey), Silver Ticket (Grey, High Contrast, new ALR which is not the UST material, but a more expensive one).
Here are my thoughts on each, categorized by company.
Silver Ticket
High Contrast: my current screen material really surprised me. It compares very favorably to matinee wide. The viewing angle is slightly wider, and the on-axis gain is lower. It has mildly more texture artifact, but will probably hotspot less (can confirm from my full sized screen). While ST advertises as non-ALR and matte, it is absolutely mild ALR with pretty low angular gain, but the gain is there. I feel like it is the best compromise at the best price and will probably buy another one. The Matinee Wide is better but more than double the price.
Grey: Way too light, almost white. Washes out easily. Visible texture despite not being ALR. Definitely out.
ALR: WOW this screen material is amazing. And it had better be, because the price is way out of line with other ST screens. If you have high ambient light and a bright projector you owe it to yourself to check this out. It seems to be one-directional ALR (from above, not from sides) but it is aggressively black compared to overhead can lights. Because it doesn't fight side light, it has a very wide viewing cone and likely won't hotspot bad. It also has little to no visible texture. The main downside is that the on-axis gain is really low so the image will be darker, which is a negative with lights off. If this material wasn't SO expensive I would probably be buying this one. It compares favorably to Slate 0.8, it has lower bright colors, but also deeper blacks, and much much better viewing angle and texture. Very very impressive with lights on.
Elite
Cinegrey: matte grey does not fight ambient light very well. No clear texture, but the overall gain is too dark and the darkest of the grey screens I tested which makes it look bad with lights out (where the grey screen shine over ALR screens). This one is out of the running.
Cinegrey 3D: awful texture and shine, will be very prone to hotspot. Out for those reasons. If you need ALR this aggressive one of the others will be a better option anyway. I guess it's available because it's cheaper than those options. Probably similar to slate 1.2 but way worse texture.
Seymour
Matinee Black: Aggressively ALR. Very great contrast with lights on, the best of all the materials. But also has by far the worst texture and viewing angle. Unacceptably so. Very bright whites and very deep blacks.
Matinee Wide: Very similar to Silver Ticker HC. Noticeably less texture, brighter brights, but also slightly brighter blacks. Little bit narrower viewing cone. Might hotspot at my throw <1.4. This is a really really good material, but also >2x the HC price.
Glacier Grey: By far the best grey material I tested, but as it is matte, it also washes out. Best image with lights out, no viewing angle artifacting or texture. Very good material if you have full light control.
SI
Slate 1.2: Best image with lights on for bright subject matter. Very little texture artifacts, but the viewing angle is compressed. Main problem is cost here. Good for sports. Similar black level as matinee wide or ST HC, but brighter whites.
Slate 0.8: Probably best with lights on for dark subject matter. Still little texture, but more than 1.2. Viewing angle is further compressed, the worst here besides the Matinee Black. Also very expensive. Similar white level as matinee wide and ST HC, but deeper blacks.
ALR
In terms of ALR ability I would rank like below, but also depends on your content habits and how much light you usually have up. The Matinee Wide and HC screens still do a pretty decent ALR job despite being lower on the list, but also artifact way way less and also cost less than most of the alternatives.
1) Matinee Black
2) ST ALR / Slate 0.8
3) Slate 1.2
4) Cinegrey 3D
5) Matinee Wide / ST HC
6) Grey Screens
Artifacts
1) Grey screens have no artifacting, except ST has some texture
2) ST ALR
3) Matinee Wide
4) ST HC
5) Slate 1.2
6) Slate 0.8
7) Cinegrey 3D
8) Matinee Black
bdht likes this.
Cryptic7 is offline
post #2 of 6 Old 02-27-2020, 07:41 PM
bdht's Avatar
Quoted: 487 Post(s)
Liked: 201
Can you link to the specific ST ALR material? I'd like to get a sample
bdht is offline
post #3 of 6 Old 02-28-2020, 05:12 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 4
This is the ALR material
https://www.silverticketproducts.com...str-169100-alr
They don't directly sell samples of this one but I contacted them and they sent me one. I got the impression from the customer service that the product page may be updated about this one soon as the information currently is very minimal
Cryptic7 is offline
post #4 of 6 Old 02-28-2020, 07:00 AM
Dave in Green's Avatar
Quoted: 4007 Post(s)
Liked: 3176
Screen material comparisons are always welcome. The screen, projector and viewing environment work together as a system to create image quality. Assuming the environment is optimized and not subject to change the screen material and projector settings remain the only variables. For optimal comparisons the projector settings would be optimized to suit each different screen material. If projector settings are left the same for all screen materials then the image comparisons are only valid for those specific settings which may be more optimized for one type of screen than another.
For example, the main advantage of a <1.0 matte grey screen over a 1.0 gain matte white screen is that it's possible to increase the ratio of image light to cross reflected light washing out the image. So if projector settings are left the same the image on a 0.8 gain matte grey screen will appear 80% as bright as the image on a 1.0 gain matte grey screen. If projector settings are adjusted to throw more lumens at the 0.8 gain grey screen the image can be made just as bright as the one on the 1.0 gain white screen. However, any cross reflected light from the screen image onto room surfaces and back onto the screen will only have 80% of the washout effect on the 0.8 gain grey screen as on the 1.0 gain white screen.
It obviously gets a little more complex when throwing ALR screens into the equation. But the point is that comparing different screen materials with the same projector settings only tells which screen works best on those specific projector settings.
bud16415 likes this.
Dave in Green is offline
post #5 of 6 Old 02-28-2020, 07:08 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 4
I'm aware that the projector, throw, and room lighting all affect screen performance.
That doesn't negate the fact that the grey screen is in absolute terms better if you don't have any ambient light, and that the Slate won't work with a short throw. My intention wasn't to give absolute answers but just a relative comparison.
Cryptic7 is offline
post #6 of 6 Old 02-28-2020, 07:41 AM
Liked: 3176
Right, I thought it would be helpful to try to define that more clearly for the benefit of any less experienced folks reading the thread to help avoid anyone jumping to absolute conclusions from casual observations.
Reply Screens
