Elunevision screen wrinkles fix? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-19-2020, 05:25 PM - Thread Starter
TyKelowna's Avatar
In 2012 I ordered a custom Elunevision 2:35 screen with the following specs:
120" x 51"
Reference Screen 1.0 Material
Tab Tensioned
36" of drop
Motorized
It has served me very well, except for one problem: screen wrinkles. They originally started out quite small. I was able to let the screen hang for a few days or carefully use a hair dryer from a distance to get them out. But they would always return.
Eventually I gave up, as they are only noticeable during winter scenes or similar. In the pictures you can see, they have gotten pretty bad over time which you can see in the pics.
In the past I have tried:
-Tightening the wires on the side (doesn't so much)
-Sliding the material on the bottom weighted bar outwards (does't seem to adjust at all)
Any ideas on how to fix this? Thanks!
ID:	2699768   Click image for larger version
ID:	2699770   Click image for larger version
TyKelowna is offline
Reply Screens
