Cleaning a Da Lite High power screen - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By airscapes
  • 1 Post By Bellaseni
post #1 of 9 Old 04-29-2020, 06:25 PM - Thread Starter
Quoted: 86 Post(s)
Anyone have any tips?
It only shows real bad on white screen.
Definitely do not want to take the chance of ruining it .
Bellaseni is offline
post #2 of 9 Old 04-29-2020, 07:57 PM
airscapes's Avatar
Quoted: 532 Post(s)
Liked: 453
I posted detailed instruction and I think video. Do some searches of this forum was a couple years ago.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #3 of 9 Old 04-30-2020, 08:44 AM - Thread Starter
Quoted: 86 Post(s)
Going to look through your old posts now 🙂
post #4 of 9 Old 04-30-2020, 11:57 AM
airscapes's Avatar
Quoted: 532 Post(s)
Liked: 453
This is one of them https://www.avsforum.com/forum/23-sc...in-screen.html
I think I fixed the video so it will play but they are mine so not sure if others can see them.. let me know if not.
Azekecse likes this.
Doug
post #5 of 9 Old 04-30-2020, 12:39 PM
Azekecse's Avatar
Quoted: 249 Post(s)
Liked: 244
I just did this last week, I wish I would have seen your post ^^^...Anyway, I used distilled water, micro fibre cloths (one wet, one dry), moving the cloth lightly from left to right. I'm going to try one more wipe with isopropyl alcohol/distilled water as suggested by Da-Lite, but it looks much better than before.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is online now
post #6 of 9 Old 04-30-2020, 05:00 PM - Thread Starter
Quoted: 86 Post(s)
Thanks for the guide and vids.
I don’t have any bug or dirt spots it’s mostly just just light dust from over the years. Hoping this helps
post #7 of 9 Old 04-30-2020, 08:00 PM
airscapes's Avatar
Quoted: 532 Post(s)
Liked: 453
It will, and you will be surprised at how dirty it really is once it is clean
Doug
post #8 of 9 Old 05-20-2020, 05:15 PM
covsound1's Avatar
Quoted: 144 Post(s)
Liked: 98
HELLO i just cleaned mine with a damp micro towel just water. I notice even though my black level went up the color of black is more cool than warm. Day light in movies looks more like real sun maybe that is cooler too ? Contrast has jumped a good margin as my room has less light bonce. Also reds really pop that looks a lot more natural and all colors in general. Conclusion if you clean be ready for a much different picture. I am still missing what the dirt 2.8 combo did but also like what a clean 2.8 brings!
covsound1 is online now
post #9 of 9 Old 05-21-2020, 04:22 PM - Thread Starter
Quoted: 86 Post(s)
Cleaned with distilled water and cloth. Came out great! Did not use soap!!!
covsound1 likes this.
Reply Screens
