Safe to attach a drop-down screen to the top of bookshelves? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-03-2020, 07:45 PM - Thread Starter
rrskda's Avatar
Quoted: 81 Post(s)
Liked: 44
I'm starting to explore getting a projector and the biggest challenge right now is how to mount the screen at a decent height without having it hang way down from the ceiling, since it's 9ft high. I can't mount it to the wall the screen would be in front of, due to a pair of IKEA Billy bookshelves standing on either side of my 55" HDTV, which is already mounted to the wall. I'm looking at a screen like this: https://www.amazon.com/gp/product/B0...qh_dp_hza?th=1
Is there a way I could mount the screen to the top of the bookshelves? I was thinking of attaching L-shaped brackets to the top of the book shelves that line up with the screen's brackets, but don't know if the bookshelves are strong enough to manage the weight. Photo of where screen will go attached for reference.
rrskda is offline
post #2 of 6 Old 05-03-2020, 08:02 PM
genaccmiller's Avatar
Quoted: 881 Post(s)
Liked: 231
Why couldn't you do a clean slate by taking off the bookshelves and the TV, patching up any holes and then hang the screen?
Sent from my GM1917 using Tapatalk
Step by Step Theater Build - http://imgur.com/gallery/2tpaSru
My Theater Build Youtube Channel - https://www.youtube.com/channel/UCs_..._as=subscriber
My Theater Build Thread - https://www.avsforum.com/forum/19-de...ld-thread.html
genaccmiller is online now
post #3 of 6 Old 05-03-2020, 08:54 PM - Thread Starter
rrskda's Avatar
Quoted: 81 Post(s)
Liked: 44
It's still a family room, so the book shelves will need to stay. That and I will continue to use the TV for daytime use when it's too bright means I need a retractable screen.
rrskda is offline
post #4 of 6 Old 05-04-2020, 06:06 AM
rekbones's Avatar
Quoted: 1326 Post(s)
Liked: 671
Screens aren't that heavy but I would make sure the book shelves are anchored to the wall to be on the safe side.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #5 of 6 Old 05-04-2020, 06:25 AM
airscapes's Avatar
Quoted: 532 Post(s)
Liked: 449
You can order a screen with extra drop (black part of screen fabric above the screen) and mount the screen on the ceiling.. 9' ceiling would only need about a 1 foot extra drop..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #6 of 6 Old 05-05-2020, 12:52 PM - Thread Starter
rrskda's Avatar
Quoted: 81 Post(s)
Liked: 44
You're right--after measuring I realized the drop isn't as much as I'd feared. Only problem now is that I want to get a short-throw projector and just learned they are more sensitive to small warps, so looks like I'll need to plan to invest in a tab tensioned screen... easily 2x the price. Might do some sort of cheapie temp fixed screen solution until I can afford that.
Thanks all!
rrskda is offline
Reply Screens
