Samsung Smart tv - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By fourhour
post #1 of 4 Old 05-11-2020, 04:39 PM - Thread Starter
fourhour's Avatar
Liked: 1
Samsung Smart tv
Been a long time since I've participated here but the time has come to revisit and seek some help. If this is the wrong place to ask these questions could someone please redirect me to the appropriate section?
I'm having a horrible time with my Samsung Smart 55 inch curve. Whenever I do any kind of search for the answers, none of them match what happens when I try to correct it. This has got me thinking that maybe I need to reset the tv to the original settings or maybe it needs to be updated.
So here are my questions. Could I possibly gain anything from seeking an update, or if I do a reset, will I lose all of my apps, such as Netflix, Youtubetv, Amazon, etc, and the OTA channels?
Thanks for your consideration in advance.
fourhour is offline
post #2 of 4 Old 05-11-2020, 06:50 PM
iraqgsm's Avatar
I had few Samsung TVs, if you update almost all your settings and many of the login info for the smart apps remain, but if you reset you will still have the apps but you need to re-enter all your login info.
iraqgsm is offline
post #3 of 4 Old 05-11-2020, 08:30 PM
rossandwendy's Avatar
Quoted: 303 Post(s)
Liked: 365
You have posted in the projector screens forum. The LCD flat panel forum is here:
https://www.avsforum.com/forum/166-l...anel-displays/
Perhaps a moderator can move your thread.
DISPLAY: JVC RS540, 160" Stewart WallScreen ST130 G4
SPEAKERS/SUBS: Chane A5.4/A2.4/A1.4, Rythmik FV18 x 2
POWER: Outlaw 5000 5-channel, Denon AVR-X3300W
SOURCE: multi-region Oppo BDP-103D & BDP-83
rossandwendy is offline
post #4 of 4 Old 05-12-2020, 12:09 PM - Thread Starter
fourhour's Avatar
Liked: 1
Thank you. I think I'll give this a go.
Thank you. I hope it can be moved for broader visibility.
rossandwendy likes this.
fourhour is offline
Reply Screens
