Drop down screen in the middle of the room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-18-2020, 02:04 AM - Thread Starter
Liked: 0
Hi there, I'm planning to get myself a projector & screen for the first time. Pretty excited, but I want to get it right.
I'd like to have a drop down screen attached to the ceiling more or less in the middle of the room, cause I don't have a free wall to put it next to. What should I look out for? How can I make sure that the screen won't be wiggling? Are there stiffer variants that don't move too much, how are they called?
brunochre is offline
post #2 of 7 Old 05-18-2020, 09:27 PM
rekbones's Avatar
Quoted: 1340 Post(s)
Liked: 683
Movement of the screen not likely an issue as all drop screens hang freely. For a quality drop screen Tab Tensioned is what is desired and is designed to keep the screen from curling/rippling so you get a distortion free image.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 7 Old 05-19-2020, 01:46 AM - Thread Starter
Liked: 0
Thanks for the input. I've looked into those tab tensioned screens and they look great but they're quite over my budget, it doesn't sound sensible to spend as much in the projector as in the screen
What should I look out for in a <100$ drop down screen?
post #4 of 7 Old 05-19-2020, 08:24 AM
Craig Peer's Avatar
Quoted: 7966 Post(s)
Liked: 10355
You are probably looking at a manual pull down like this - https://www.legrandav.com/en/product...creens/model_b
Craig Peer is offline
post #5 of 7 Old 05-21-2020, 12:03 AM - Thread Starter
Liked: 0
Would something like this be good enough or would quality suffer much? eltec.pl/PROJEKTORY-I-EKRANY-PROJEKCYJNE/Ekrany-projekcyjne/Ekran-projekcyjny-260x150cm-169-manualny-scienny-sufitowy.html
post #6 of 7 Old 05-21-2020, 01:26 AM - Thread Starter
Liked: 0
To clarify, I plan to use the projector & screen to watch films, from bluray or DVD.
post #7 of 7 Old 05-21-2020, 06:11 AM
rekbones's Avatar
Liked: 683
You get what you pay for, it's up to you to decide if it's good enough. Waves in the screen cause both shadows and distortion especially in slow pans across the screen, some barely notice, others can't stand them.
rekbones is offline
Reply Screens
