21:9 4K 120 inch viewing width suggestions - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Mocs123
post #1 of 13 Old 06-03-2020, 08:26 AM - Thread Starter
Quoted: 106 Post(s)
Liked: 2
hello can anyone recommend a good 4K screen for 120 inch viewing width? installing into dark room . bright lighting will not be an issue
how easy is it to build my own frame? seems like the frame is usually more expensive than the typical screen material nowadays.
anything located in Canada would be a Bonus at this point !
thanks,
dirkdigs is offline
post #2 of 13 Old 06-03-2020, 09:00 AM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 410
If budget is a concern, I would look into building your own frame out of Poplar and using either Milliskin Spandex or SeymourAV Center Stage material for the screen itself.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is online now
post #3 of 13 Old 06-03-2020, 09:07 AM
jeahrens's Avatar
Quoted: 2424 Post(s)
Liked: 1707
https://www.amazon.com/STC-115-Silve...13&sr=8-3&th=1
That would be pretty close. In home theater, screen ARs are generally expressed in theatrical ratios, so 2.35:1/2.40:1 are going to be the equivalent to a PC 21:9.
jeahrens is offline
post #4 of 13 Old 06-03-2020, 09:12 AM
bud16415's Avatar
Quoted: 2470 Post(s)
Liked: 1329
Is the OP looking to use an A-lens?
Bud
bud16415 is online now
post #5 of 13 Old 06-03-2020, 09:15 AM
jeahrens's Avatar
Liked: 1707
I don't see any detail either way. The majority use lens memory/zoom though.
jeahrens is offline
post #6 of 13 Old 06-03-2020, 09:18 AM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 410
I think he is saying that because a curved screen is generally for use with A-lenses.
bud16415 likes this.
post #7 of 13 Old 06-03-2020, 09:22 AM
jeahrens's Avatar
Liked: 1707
I guess I missed that this was curved.
jeahrens is offline
post #8 of 13 Old 06-03-2020, 12:24 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 2
OK n00b question but what the heck is A-lens lol
dirkdigs is offline
post #9 of 13 Old 06-03-2020, 12:34 PM
skylarlove1999's Avatar
Quoted: 2276 Post(s)
Liked: 2427
Anamorphic lens
https://www.panamorph.com/?gclid=EAI...iAAEgJwe_D_BwE
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #10 of 13 Old 06-03-2020, 01:25 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 2
Originally Posted by skylarlove1999 View Post
Anamorphic lens
ya I'm looking at the BENQ HT3550 or similar so no A-lens for me.
dirkdigs is offline
post #11 of 13 Old 06-03-2020, 01:26 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 2
any build instructions for this type of thing ? wouldn't know where to begin .
dirkdigs is offline
post #12 of 13 Old 06-03-2020, 01:43 PM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 410
Here's a pretty good thread from the DIY screen section:
https://www.avsforum.com/forum/110-d...tructions.html
post #13 of 13 Old 06-04-2020, 04:50 PM
bud16415's Avatar
Liked: 1329
Before getting into a scope screen setup you need to understand all that entails. 21:9 or scope 2.4:1 need a projector capable of doing CIH presentation. That happens with using an A-lens or with doing it with a projector that has programmable zoom, shift and focus and the projector you mentioned I don’t think will do that. There is also IMAX movies now like Dunkirk and many others that are as wide as scope only taller. That may or may not be something for you to think about once you get a projector that can do what you want.
Most people do CIW constant image width and use a 16:9 screen.
Bud
Reply Screens
