JVC NX7 - 150” 16:9 Screen Recommendation - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 3 Post By skylarlove1999
  • 2 Post By JonnyVee
  • 1 Post By Craig Peer
  • 1 Post By ProjectionHead
post #1 of 6 Old 06-22-2020, 11:54 AM - Thread Starter
Quoted: 22 Post(s)
Liked: 3
Hello, seeking your advice to pair up a nice screen under $3k with JVC RS2000/NX7.
Options am considering (some higher than my budget) are (ranked in high to low price am getting here in Canada):
1). Stewart Balon Edge with StudioTek 130 1.3 gain material
2). Elunevision Reference 4K NanoEdge
3). Severtson Cinema White 1.3
Please rank them in order of quality and what differences they have in quality?
kam.sanghera is offline
post #2 of 6 Old 06-22-2020, 12:05 PM
skylarlove1999's Avatar
Quoted: 2276 Post(s)
Liked: 2428
1. Stewart
2. Stewart
3. Stewart
In all seriousness with the price drop there isn't another screen that will give you the brightness without sparkles, hotspotting and artifacts like the Stewart. The new G4 material made Kris Deering switch from ST100 to ST130. That should say it all.
https://www.soundandvision.com/conte...-screen-review
Sent from my SM-G965U using Tapatalk
noob00224, JonnyVee and Azekecse like this.
skylarlove1999 is offline
post #3 of 6 Old 06-22-2020, 08:03 PM
rekbones's Avatar
Quoted: 1367 Post(s)
Liked: 703
The projector, screen and "ROOM" all need to work together. What is the type, size, seating distance and ambient/reflected light control of your room?
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #4 of 6 Old 06-23-2020, 03:47 AM
JonnyVee's Avatar
Quoted: 363 Post(s)
Liked: 286
And what is your budget and what is your throw? Either way, Stewart is the way to go if it fits your budget.
Projector and Screen: JVC x790 & 120" Silver Ticket screen (Incoming 120” Stuart WallScreen StudioTek 130 G4)
Audio: Denon x4400H 5.1.4 - Infinity R162 L/R, Infinity RC263 centre, Kef T101 surrounds, Kef Ci160er rear atmos, Energy V-Mini - front atmos, PSA v1512df (x2) & BOSS w/4 12” Subs
JonnyVee is offline
post #5 of 6 Old 06-23-2020, 07:01 PM
Craig Peer's Avatar
Quoted: 8050 Post(s)
Liked: 10611
The Cima Neve fits most people's budget if the ST 130 doesn't !
skylarlove1999 likes this.
Craig Peer is offline
post #6 of 6 Old 06-29-2020, 06:08 AM
ProjectionHead's Avatar
Quoted: 178 Post(s)
Liked: 233
Stewart Studiotek 130 G4 for the win! The only reason to go with anything else in a dedicated cinema room would be due to budget restrictions.
ProjectionHead is offline
Reply Screens
