Upgrade my screen? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By noob00224
post #1 of 2 Old 06-28-2020, 01:07 PM - Thread Starter
Guest
Liked: 1
Upgrade my screen?
In the display section you guys helped me decide to keep my Sony 40es for now. 5 years ago when I built this room I saved money by buying a silver ticket 110" white material screen.
Since Im not upgrading my projector for the time being I have some funds available for other upgrades.
Is there another screen I should invest in that will improve upon my picture?
Im a 100% light controlled room with dark walls and ceiling sitting 13' and 16' away (two rows).
Thank you!!
Oh, is there any maintenance I should do with my current screen? Clean it?
kujayhawk20637 is offline
post #2 of 2 Old 06-29-2020, 03:06 AM
Quoted: 2013 Post(s)
Liked: 646
Thank you!!
I would not spend the money on a better screen, which would be substantially more expensive than the Silver Ticket.
If you're not going to upgrade the projector then use the money for something else.
Some people do clean the screen, but if it's not dirty I would not. If you're going to do that check the instructions on how to clean it.
kujayhawk20637 likes this.
noob00224 is offline
Reply Screens
