Motorized drop down screen stability - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By humbland
post #1 of 5 Old 06-28-2020, 04:01 PM - Thread Starter
nconnella's Avatar
Sorry if this has been answered but I couldn't find anything using the search tool.
I have an Elite Saker 110" motorized drop screen with an extra 24" drop because my loft has super high ceilings. There is almost always an air draft that's even wors if the AC is on, which causes the screen to sway when dangling, giving it a waterlike distortion when watching movies.
I'm looking for creative solutions such as a bracket or additional weight that can be added that will hold it firmly in place so it doesn't sway. Also I find that every time the screen comes down it's in a slightly different position from the wall so I have to constantly adjust the projector's keystone. Considering returning for the tension version. This is in the living room so the wife will not allow a fixed screen or projector wall paint.
Picture below of setup in progress.
Thoughts and ideas are greatly appreciated!!
Name:	Screen Shot 2020-06-28 at 4.00.33 PM.png
nconnella is offline
post #2 of 5 Old 06-28-2020, 04:24 PM
humbland's Avatar
Quoted: 1173 Post(s)
Liked: 373
I have had good luck with Elite CS. They have helped me solve some issues with their Cinatension2 electric drop. Why reinvent the wheel? If it were me, I would cut to the chase and call them...
My $.02
humbland is online now
post #3 of 5 Old 06-28-2020, 04:34 PM - Thread Starter
nconnella's Avatar
My $.02
This is great to hear. I will call them first thing Monday. Thank you!!
post #4 of 5 Old 06-29-2020, 11:34 AM
noah katz's Avatar
Quoted: 2623 Post(s)
Liked: 988
I'm not sure Elite can help with a draft issue.
Not sure if feasible for your setup, but perhaps some fabric covered soft foam blocks that the back of the screen rests against.
Noah
noah katz is offline
post #5 of 5 Old 06-29-2020, 05:36 PM
humbland's Avatar
Liked: 373
That is a good idea. An improvement would be to glue some small refrigerator magnets to the back of the screen. Then when it deploys, line up a small piece of sheet metal (or two) at the appropriate level of the magnets. When the screen drops, they will secure the bottom to the foam blocks. Then, when you retract it, the small magnetic force should just pull loose. Just and idea. As I said before, Elite CS would be my first try...
noah katz likes this.
Reply Screens
