The Official Stewart Film Screen thread. - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 507Likes
post #3331 of 3353 Old 01-11-2020, 06:40 PM
Ericglo's Avatar
Quoted: 3779 Post(s)
Liked: 2179
Originally Posted by Kris Deering View Post
As a professional calibrator and reviewer, I am constantly working in different projects with different screen materials on site. One thing that consistently stands out about Stewart products are their build quality and measured results. For build quality the first thing I focus on is the quality of the frames and tension systems. Stewart frames are typically properly level and plumb with no sag or obvious compromises. I see a LOT of frames from other resellers that are warped or sagging, creating their own geometry issues. I also see issues with tab tension systems from other manufacturers that start to degrade or have geometry issues. Stewart screens also meet their performance specs more often to most "value" brands.
My Stewart frame is excellent. I like the fact that if you want to order new material that they keep your serial number on file to easily match your frame with the new material.
Craig Peer likes this.
Having fun playing the new mobile game Volley Village
Ericglo is offline
post #3332 of 3353 Old 01-11-2020, 07:00 PM
Craig Peer's Avatar
Quoted: 7452 Post(s)
Liked: 9021
Originally Posted by asharma View Post
Thanks Craig...I’m not sure 8x11 samples will tell me anything except for color tone...I would have to have a much larger sample to determine if there were any sparkles or artifacting...Am I wrong?
If you hang them in front of your existing screen and take your time, yes, you can tell a lot from samples.
asharma likes this.
Craig Peer is online now
post #3333 of 3353 Old 01-11-2020, 08:04 PM
scanido's Avatar
Quoted: 184 Post(s)
Liked: 64
Hi folks...
Could someone please help me understand the benefits of the 100 material vs the Neve...? I’️m in a bat cave with velvet walls and ceiling...
I think the gain is less on the 100...is that correct? Is there a noticeable brightness loss? What are the benefits of the 100 over the Cima Neve and is there an area where the Cima Neve performs better than than the 100? Thanks folks...
Edit...also interested in opinions on ST130 because I feel with the ST100 I may see a brightness difference vs the Cima Neve and I really wouldn’️t prefer to lose brightness...perhaps you may feel brightness may be a none issue in a velvet bat cave but interested in your opinions...thanks
I started off with this same dilemma. Started off with the Neve and then to the ST130 and finally landed on ST100. My room is far from being a Batcave with dark grey walls and lots of ambient lights from my amps and chairs, I still find the St100 puts out an awesome image even with cove lighting in the room. But when lights go out the picture is amazing. My reasoning for choosing the st100 was I wanted as dark blacks as possible so no additional gain, and with the trend of projectors getting brighter I didn’t feel the extra gain would be needed. With a my Sony vw500es I still have lamp on low and brightness down and find it very bright. Of course the screen depends on your projector.
asharma likes this.
See Profile
scanido is offline
post #3334 of 3353 Old 01-11-2020, 08:14 PM
asharma's Avatar
Quoted: 1988 Post(s)
Liked: 664
Thanks, very helpful...how big is the st100? 2.35 or 16x9 What did u not like about the st130? What is better about the 100 compared to the Neve? Just blacks or is the st100 sharper at all? Does the 100 look dimmer to you compared to Neve? Sorry for all the questions...very interested in your findings...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual SVS SB3000, Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is online now
post #3335 of 3353 Old 01-11-2020, 09:06 PM
scanido's Avatar
Quoted: 184 Post(s)
Liked: 64
I started off with this same dilemma. Started off with the Neve and then to the ST130 and finally landed on ST100. My room is far from being a Batcave with dark grey walls and lots of ambient lights from my amps and chairs, I still find the St100 puts out an awesome image even with cove lighting in the room. But when lights go out the picture is amazing. My reasoning for choosing the st100 was I wanted as dark blacks as possible so no additional gain, and with the trend of projectors getting brighter I didn’️t feel the extra gain would be needed. With a my Sony vw500es I still have lamp on low and brightness down and find it very bright. Of course the screen depends on your projector.
It really came down to the type and size of cinescope frame for my application. Unfortunately the Cima Neve didn’t have the size screen to maximize my wall otherwise I would have gone with it. But I wanted the largest possible screen so it had to be Stewart’s Baylon Borderless product in 2.40:1 in 130” diagonal. Literally have 1.5” on either side of the screen! The design of the frame is what really sold me. As for St130 vs st100 there’s another thread here on AVS on that. Really depending on what you are looking for. Can’t go wrong with either really as they are both reference screens.
Craig Peer and asharma like this.
See Profile
scanido is offline
post #3336 of 3353 Old 01-11-2020, 11:03 PM
WCW
Quoted: 17 Post(s)
Liked: 9
Love our G4 ST130 2:35.1 127”. No artifacts what so ever.
WCW is offline
post #3337 of 3353 Old 01-12-2020, 04:40 AM
asharma's Avatar
Liked: 664
Thanks, doesn’t look like you are suffering from any brightness issues with a 1.0 gain...what projector?
post #3338 of 3353 Old 01-12-2020, 04:41 AM
asharma's Avatar
Liked: 664
G4 is the new material, correct?
post #3339 of 3353 Old 01-12-2020, 05:42 AM
asharma's Avatar
Liked: 664
Aspect ratio question
Hi folks
For scope screens, in the past I’ve had 2.35 but I find most movies today are 2.39 or 2.40 (correct me if I am wrong please) resulting in slight overlap on each side on to the black masking...
What are most of you using/ordering these days for scope screens? 2.35, 2.39, or 2.40? Thanks folks...
post #3340 of 3353 Old 01-12-2020, 08:36 AM
Craig Peer's Avatar
Liked: 9021
Hi folks
I’d probably go with a 2.40:1 myself.
post #3341 of 3353 Old 01-12-2020, 08:36 AM
Craig Peer's Avatar
Liked: 9021
Yes - that’s the new material.
post #3342 of 3353 Old 01-12-2020, 09:27 AM
asharma's Avatar
Liked: 664
Thanks Craig, is that because most new flicks are 2.40 or do u find ones say up to 20 years old are also?
post #3343 of 3353 Old 01-12-2020, 09:28 AM
asharma's Avatar
Liked: 664
Thanks Craig, Do we know what the specific benefits are over G3?
post #3344 of 3353 Old 01-12-2020, 09:30 AM
Craig Peer's Avatar
Liked: 9021
I think most scope films are closer to 2.40:1 that I have. You could split the difference with a 2.37:1 screen too.
asharma likes this.
post #3345 of 3353 Old 01-12-2020, 09:31 AM
Craig Peer's Avatar
Liked: 9021
Less screen artifacts. I think there could be a review coming from Kris Deering soon.
asharma likes this.
post #3346 of 3353 Old 01-15-2020, 09:27 AM
pink soda's Avatar
Quoted: 181 Post(s)
Liked: 203
I had a great experience with AV Science and Stewart that I wanted to share.
I talked to @Mike Garrett at AV Science about two months ago while shopping for a new screen, and he recommended the Cima FF with Neve material for my dark home theater setup. Before, I was using an Elite Cinegrey which I chose at the time because I do often use the HT while keeping dim ambient light on (but walls are blacked out and no direct ambient light reaches the screen). Mike insisted that a white screen like the Neve should still work great in my particular setup.
I received the Cima Neve and I was pleased with the results -- colors popped like never before and bright whites could get blinding at times but resulted in a much more realistic look. Blacks were still excellent with my JVC X790R, so my overall contrast improved considerably. Sharpness was incredible and allowed me to focus my projector better than on my previous screen. I once saw a comment that said upgrading to the Cima Neve felt like updating one's glasses prescription, which sounded funny to me at the time, but I couldn't agree more.
I did notice what I would call horizontal "screen ripples" at the time, that appeared most prominently in very bright panning shots, but I wasn't sure if these would go away with time or not. I did double check screen tension and it seemed properly tensioned everywhere from what I could tell. One month later, I had Chad B over to do a calibration with the new Cima Neve screen, which showed off how good the screen is even more. But the screen ripples were still there, so Chad suggested I ask my screen dealer about it.
I reached out to Mike again, sent him some photos of the screen ripples, and he suggested that I use lens shift to confirm that the ripples were coming from the screen rather than the projector. With lens shift I was able to confirm that the screen was the issue, so Mike forwarded my issue to Stewart, and they ended up deciding to send me an ST130 G4 fabric replacement as a one-time accommodation. Great customer service!
I just installed the ST130 G4 replacement fabric yesterday, and it's absolutely perfect. No screen ripples at all. I was concerned about changing screen materials after Chad had already calibrated against the Neve, but from my subjective viewing tests, at least, I was relieved to see that there were no noticeable color or gamma shifts at all. It just looks slightly better than the Neve was in every way that I could tell, even though the calibration was done against the Neve and not the ST130. I know people say the Neve and ST130 are very close fabrics and my experience confirms that for me. But despite how close they are, the difference was enormous for me, because the screen ripples are finally gone. The result is just stunning. It looks so good I am constantly distracted from actually watching the movie I'm trying to watch.
Thanks AV Science, Mike, and Stewart! I can't imagine ever needing to buy another HT screen. But I know where I'll be telling my friends to shop.
Speakers: Ascend Acoustics Sierra RAAL Towers & Horizon w/ Mapleshade 4" Maple Platforms & Brass Heavyfeet ・ Ascend Sierra Luna satellitesRythmik FV18 aluminum cone subwoofer x2 ・ JBL GX-1200 subwoofer x5 direct mounted to seats
Components: Monoprice Monolith HTP-1 w/ Dirac Live ・ Anthem Statement P5 ・ JVC DLA-RS540 ・ Stewart Cima FF 123 inch w/ Studiotek ST130 G4
pink soda is online now
post #3347 of 3353 Old 01-15-2020, 09:31 AM
Craig Peer's Avatar
Liked: 9021
Stewart's customer service is 2nd to none !
post #3348 of 3353 Old 01-18-2020, 08:55 PM
Skimanfz1's Avatar
Quoted: 58 Post(s)
Liked: 60
My motorized 123" Stewart Luxus screen will not lower anymore. I've checked the 115V power and 12V trigger. I've tried tapping numerous times. Nothing. It's in a recessed ceiling and is way too heavy to move. Any suggestions?
Skimanfz1 is offline
post #3349 of 3353 Old 01-19-2020, 10:05 AM
Craig Peer's Avatar
Liked: 9021
Contact your dealer or Stewart customer service.
post #3350 of 3353 Old 01-19-2020, 10:51 PM
Skimanfz1's Avatar
Quoted: 58 Post(s)
Liked: 60
After plugging and unplugging everything repeatedly, and banging on the screen case, it finally did lower itself.
post #3351 of 3353 Old Yesterday, 08:52 AM
SJHT's Avatar
Quoted: 1211 Post(s)
Liked: 819
May want to check the connections inside the case if made during installation..
SJHT is online now
post #3352 of 3353 Old Yesterday, 08:25 PM
stef2's Avatar
Quoted: 522 Post(s)
Liked: 311
Is is possible to purchase some ST130 screen material without the frame? I have a nice frame from SeymourAV and I would rather keep the frame but change the screen material for the ST130.
stef2 is online now
post #3353 of 3353 Old Today, 10:31 AM
Craig Peer's Avatar
Liked: 9021
Do you have a Stewart dealer there ? You would need to ask them.
Reply Screens
Projection Screens , Stewart Firehawk G3
