The official SeymourAV center stage screen thread! - Page 126 - AVS Forum | Home Theater Discussions And Reviews
 446Likes
post #3751 of 3841 Old 06-20-2019, 08:01 AM
Quoted: 92 Post(s)
Originally Posted by howiee View Post
Cheers Jonny. Sounds encouraging! Did you get a chance to measure gain on any of these?
I do not have that equipment, I trust Seymour's reported numbers are accurate.
howiee likes this.
JonnyFive54950 is offline
post #3752 of 3841 Old 06-20-2019, 08:25 AM
J.P
J.P's Avatar
Quoted: 134 Post(s)
Liked: 48
Originally Posted by chriscmore View Post
The Glacier White PS will end up measuring about the same gain as the previous version Jeff tested. I think he's had a sample to test, as I know I sent him the Enlightor-Neo when it was developed. It would compare well with the ST100, as it doesn't have the high-gain elements that the ST130 has on it.
Interesting, so that means Glacier White PS will have a gain of 1.05 on axis.
But how does it compere to the ST100 on visible texture(not from sitting position) ? And how accurate does it track D65 ?
And also, how thick is the screen, can you see light on the backside ?
Dedicated Theater :
JVC-X7000 Stewart-Studiotek100/2:35.1-133"Diagonal Marantz-8802a Oppo-205-modified Pioneer-BDP-LX88 Auralic-Aries 4x.KenKreisel-DXD.808 2x.NAD-M27 3x.Hypex-Ncore400
2x.B&W-803D B&W-HTM2D 4x.B&W-CWM7.4 4x.B&W-CCM7.4 2x.B&W-CCM682
Isotek-EVO3Acuarius 2x.Isotek-EVO3-Sirius Isotek-EVO3-Mini.Mira
J.P is offline
post #3753 of 3841 Old 07-08-2019, 02:40 PM
NIN74's Avatar
Liked: 24
Jon, I have emailed you about buying a screen.
Sound and video is not magic, it is pure physics. Physics that can be magical
NIN74 is offline
post #3754 of 3841 Old 07-09-2019, 08:54 AM
Gates's Avatar
Quoted: 321 Post(s)
Liked: 167
I will be doing a new build in a few months and with all my research, I came to the conclusion that I want a Stewart screen. Do they sell them in Canada?
JVC DLA-RS1000, 120″ EluneVision Reference Studio AudioWeave 2.35:1 CinemaScope screen, Marantz AV8802a Pre/Pro, Anthem MCA 525, Anthem MCA 225, Anthem PVA-4, Paradigm CI Elite E80-R ceiling speakers x4, Paradigm Prestige 95F, Paradigm Prestige 15B x4, Paradigm Prestige 55C, Paradigm Signature Sub 1, Panasonic UDP820 UHD player, OPPO 203 UHD player, Richard Gray 1200c Custom power conditioner, AC Infinity AIRCOM X4.
Gates is offline
post #3755 of 3841 Old 07-09-2019, 09:47 AM
StevenC56's Avatar
Quoted: 587 Post(s)
Liked: 206
This is the SeymourAV thread, so you'll need to post your question in the Stewart thread.
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #3756 of 3841 Old 07-09-2019, 09:48 AM
Gates's Avatar
Quoted: 321 Post(s)
Liked: 167
Sorry I meant Seymour, don't know why I had Stewart on the brain.
Gates is offline
post #3757 of 3841 Old 07-09-2019, 09:54 AM
Mahuzz13's Avatar
Quoted: 408 Post(s)
Liked: 833
Did you notice the the title of this thread and it is unfortunate that you would want to pay such a higher price for minimum amount of different. Of course the sell them in Canada but agin at crazy pricing from an authorized dealer.
Mahuzz13 is online now
post #3758 of 3841 Old 07-09-2019, 10:00 AM
Gates's Avatar
Quoted: 321 Post(s)
Liked: 167
Well if you would of read to the end of this thread you would of seen that I made a mistake when mentioning the name.
llang269 likes this.
Gates is offline
post #3759 of 3841 Old 07-09-2019, 10:44 AM
Mahuzz13's Avatar
Quoted: 408 Post(s)
Liked: 833
Sorry I think I was typing at the same time you corrected yourself again sorry
post #3760 of 3841 Old 07-10-2019, 03:27 PM
chriscmore's Avatar
Quoted: 264 Post(s)
Liked: 319
I will be doing a new build in a few months and with all my research, I came to the conclusion that I want a Seymour screen. Do they sell them in Canada?
Yes, we sell into Canada no problem. Simply contact us for what you're interested in and we'll figure out shipping costs.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #3761 of 3841 Old 07-22-2019, 06:45 AM
LIPLASMA's Avatar
Quoted: 26 Post(s)
Just wanted to say received my premiere 16x9 fixed frame 120" Glacier White screen w/ masking panels. The frame itself is very high quality and the install was very easy.
The masking panels are a great addition and make such a difference when watching content with bars. I was on the fence about ordering them but they look great. The panels are so easy to attach and remove and are very high quality. I got the single piece panels which I would also highly recommend.
Just wanted to post my impressions for anyone thinking about using Seymour for their screen.
Mahuzz13 and howiee like this.
LIPLASMA is offline
post #3762 of 3841 Old 07-22-2019, 07:41 AM
Quoted: 92 Post(s)
I'm thinking this exact combination (GW 16x9 120" wide with masking to scope). I was thinking of two piece panels, since 10' wide panels seem rather cumbersome to move around. Do you find the one piece panels easy to maneuver?
post #3763 of 3841 Old 07-22-2019, 06:03 PM
LIPLASMA's Avatar
Quoted: 26 Post(s)
I do not find the panels hard to move around. The panels are much easier to put in place than I had pictured in my mind before I purchased. I was on the fence also about the single panel but it looks amazing when attached and you would be hard pressed to tell the screen didn't come like that. The magnets just let you pop them right in place and the fit is great. I didn't want the noticeable split you can see with the 4 piece panels. I would say the single panel is the way to go at 120" if you are going panels, which I highly recommend once I started watching scope with panels I cant go back to bars.
For reference I am using a Epson 6050UB @16ft
If you have any other questions I would be glad to answer them.
JonnyFive54950 and Mahuzz13 like this.
LIPLASMA is offline
post #3764 of 3841 Old 07-22-2019, 07:59 PM
Mahuzz13's Avatar
Quoted: 408 Post(s)
Liked: 833
Did you go 120” diagonal or 120” wide? Jut wanted to clarify if they make that single panel 10’ wide or wider that’s all. I would like the masking panel to be 1 piece as well.
I am hoping Chris could answer what is the widest masking panel you could make?
post #3765 of 3841 Old 07-23-2019, 06:37 AM
LIPLASMA's Avatar
Quoted: 26 Post(s)
I have a 16x9 screen so the masking panels are on the top and bottom of the screen for scope content. My panels are almost 9' long.
LIPLASMA is offline
post #3766 of 3841 Old 07-24-2019, 07:50 AM
Quoted: 92 Post(s)
Thanks for the input! I am going to see if I can create space right under the floating screen to store them when not in use (I play a lot of PS4 in 16x9). If so, I'll definitely do the one piece panels.
post #3767 of 3841 Old 07-24-2019, 09:08 AM
chriscmore's Avatar
Quoted: 264 Post(s)
Liked: 319
I think we did some around 20ft long. The reason we split the top/bottom into halves as standard is so that you're not swinging around a 10-12' long panel. But, if you think you can swing it (ha!), we'll make about anything you want.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #3768 of 3841 Old 07-24-2019, 10:13 AM
Mahuzz13's Avatar
Quoted: 408 Post(s)
Liked: 833
Cheers,
Chris
Thanks Chris for the info much appreciated and yes I think I can swing it (ha ha!)
post #3769 of 3841 Old 08-04-2019, 02:11 PM
monstosity12's Avatar
Quoted: 39 Post(s)
Polarization
Going to be ordering the Seymour matinee silver 2.0 or ambient visionaire 2.1
Just had a question regarding the screens polarization properties. Do these screen have polarization? Need to know since I’m getting a jvc rs2000 and read something about matching the correct 3D glasses with projector/screen.
monstosity12 is offline
post #3770 of 3841 Old 08-07-2019, 10:16 AM
chriscmore's Avatar
Quoted: 264 Post(s)
Liked: 319
They do retain polarity, so you can use them with polarized 3D systems (passive, or JVC, etc) The Ambient-Visionaire 1.3 is wide angle enough that it's polarity retention is borderline. The scatter screens (white, gray) do not retain polarity.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #3771 of 3841 Old 08-08-2019, 04:39 AM
BrolicBeast's Avatar
Quoted: 1895 Post(s)
Liked: 2311
After 3 years with my 12ft wide 16:9 SeymourAV Centerstage XD screen, I decided to FINALLY apply my magnetic 2.35 masking last night, just to switch it up. I love the look, and while I’m on the fence as to whether or not I”ll keep it like this, I encourage anybody here to go with 16:9 screen WITH scope masking so you have the option for either-or. It’s a great feeling knowing I can switch back and forth at will.
Sent from my iPad using Tapatalk Pro
BrolicBeast is offline
post #3772 of 3841 Old 08-08-2019, 07:33 AM
Bittermidget's Avatar
Quoted: 81 Post(s)
Liked: 80
...or a 2.35:1/2.40:1 screen with side masks. Either way, you are absolutely correct and the masks are a really nice visual upgrade, even with a high contrast projector.
Nice room!
JVC DLA-X790R, Seymour AV Centerstage UF 2.40:1 tensioned electric screen w/ motorized masking, Anthem AVM 60, Jim Holtz Statements L/C/R, SVS SB-16 Ultra (X2), Oppo UDP-203, Parasound Halo A-21, Parasound Halo A-51, Bluesound Node 2i, miniDSP 2X4 HD, NVIDIA Shield 2015, QNAP 453Pro
Bittermidget is offline
post #3773 of 3841 Old 08-08-2019, 07:47 AM
Liked: 2311
Nice room!
True, true!!! Side masks work too!! And thank you!
Sent from my SM-G975U using Tapatalk
post #3774 of 3841 Old 08-13-2019, 02:21 AM
Liked: 2311
Man this CinemaScope masking is growing on me. I'm starting not to miss the 16:9 floor to ceiling image... Don't tell anybody though. Shhhh.
post #3775 of 3841 Old 08-13-2019, 12:51 PM
Ladeback's Avatar
Quoted: 1418 Post(s)
Liked: 523
Send a message via MSN to Ladeback
Ya, but when watching sports the big 16:9 is nice I bet.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #3776 of 3841 Old 08-26-2019, 10:59 PM
Liked: 0
Hi Chris,
I'm sure you hear this all the time but I'm looking to buy a screen and the options, opinions and information are overwhelming. I was hoping you could recommend a screen for me? My room in 16' 4" long x 14' 2" wide. It is a dedicated theater room with no windows and a large double door opening in the back right corner. The ceiling slopes back to front from 12' to 8' so the average height is about 10' high. Anyway, I only plan on having one row of seating. It can be anywhere in the room but I'm thinking the back of the seats will be about 3' off of the back wall. That puts my head 13' from the screen. I also will be using an epson 5040ub projector. The walls are dark gray and the ceiling and screen wall are black. I can completely control the light in the room but it would be nice to be able to leave some lights on, or at least dimmed during the sporting events, etc. So with that being said, which screen do you recommend? I really would like to have 120" diagonal 16:9 with masking panels for 2.4.
Iceberg62 is offline
post #3777 of 3841 Old 08-27-2019, 10:36 AM
chriscmore's Avatar
Quoted: 264 Post(s)
Liked: 319
Originally Posted by Iceberg62 View Post
Hi Chris,
Sitting 13' back from a 105"w/120"d screen would be a bit small at 37 degree wide viewing. If you can scoot your seating forward or entertain a bit larger screen, the guidelines would vote for you getting up to around 40 degrees. Of course personal preferences reign and often room constraints are just that.
Kudos on the darker colors. Are you looking for acoustically transparent or non-AT?
For masking panels, we'll narrow it to the Premier frame (3.3"w) or the Metro (1.5"w).
Keep in mind that we make every screen custom to the 0.1" resolution, so let's make sure we get it perfect for you. As they say, you date the projector and marry the screen.
Cheers,
Chris
Mike Butny and Iceberg62 like this.
Seymour AV
515-268-3369
515-450-5694
post #3778 of 3841 Old 08-27-2019, 12:17 PM
Liked: 0
Thanks for the reply. I could definitely go with a larger screen. I need to see how much vertical space I have above my media console. I don’t need an AT screen. I was in a local store that had an epson 5050 with a Da Lite Parallax that I thought looked really good. That made me think that maybe I wanted a ALR screen but if I can leave a few cans on (and dimmed) and still get a better picture with the projector I have then I’m up for that too. I was reading about the two glacier materials trying to decide if one of those might be a better option.
For reference, the room has:
-four cans on a dimmer that wash the screen.
-four overhead cans on a separate dimmer
-two cans in a soffit on each side of the room that are wall washers, on their own dimmer.
-led up lights in the soffit on their own dimmer
-led floor lights that go around the room built into the baseboards on their own dimmer
I would like the option to not have to be in a cave and still be able to have a watchable screen for sports, etc.
post #3779 of 3841 Old 08-27-2019, 09:22 PM
Audixium's Avatar
Quoted: 61 Post(s)
Liked: 63
Cheers,
Chris
First time seeing this phrasing...many thanks for the reminder as my room is close to screenwall phase.
Audixium is offline
post #3780 of 3841 Old 08-28-2019, 08:38 AM
chriscmore's Avatar
Quoted: 264 Post(s)
Liked: 319
The Glacier screens are still Lambertian, or scatter type screens, so they don't offer ambient light rejection. They're still intended for as perfectly dark a room as possible. The benefit, however, is that they offer a perfectly smooth, uniform image. The more aggressive you incorporate ambient light fighting features, the further you move away from reference. It can still look very good, and we always seek to marry the perfect type of screen to the room, but like in acoustics, starting with a better room is always better. To continue the analogy in acoustics, you can go with narrow dispersion horn drivers to reduce the ambient effects (just like ALR screens), and they can sound great, but take on a character of their own.
Make sure all the lights are as spot/narrow focus as possible. Wide or flood light angles wash more light on the screen, reducing image quality. You can get a surprising amount of audience lighting without degrading the image much, if your bulb angles are narrow enough.
If you stuck with the smaller 105"w/120"d then I think the Glacier Gray would be a good choice since an Epson would have plenty of power and could benefit from having its black level improved by 20% (and a theoretical room splash contamination resistance of 36%).
If you went larger - tougher to do with a non-AT screen - then that'd start to vote for the Glacier White to keep the luminance levels up. With either screen, sports and some lights would be fine, as you can kick the Epson up to a higher output picture mode and shadow details aren't as important.
If you want to talk specs and pricing, I'd email Jon at [email protected] or hit us up through the contact us template.
Cheers,
Chris
Iceberg62 likes this.
Seymour AV
515-268-3369
515-450-5694
Reply Screens
Seymour Av
