JVC DLA-RS2 Lens shift problem - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 02-18-2018, 11:50 AM - Thread Starter
guitarman's Avatar
Quoted: 16 Post(s)
I bought the part from AVS they're JVC dealers. Contact one of their reps or Alan. I'm looking for the pictures on old computers. Actually Alan gave it to me for free. Don't know if they can do the same these days, worth a try. Tell them guitarman said so. good luck
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #32 of 33 Old 10-09-2019, 11:41 AM
Liked: 0
Hi,
I am also having the vertical lens shift problem with my JVC DLA-RS2. Those links you mentioned are not working any more. Any chance you still have those ?
Mahesh
Mahesh Chandak is offline
post #33 of 33 Old 10-09-2019, 12:11 PM
Liked: 0
Originally Posted by Preciseone View Post
After a few weeks I still need a little help. I bought part # LC33703-001C which should be the correct part for the lens shift but if you look at the two pictures the one JVC sent me shows it should have something to connect to but if you look at the picture of mine there is nothing there at all. The number for JVC is for easier trouble shooting than this type of stuff. Dave at JVC parts has been trying to help me the best he can but has no more ideas for me. Anybody have any ideas?
Hi,
I am also in the same boat. My vertical lens shift does not work for DLA-RS2. Were you able to change the gear ?
Mahesh
