Oppo BDP93EU and JVC RS50 do not display 3D from USB Disk - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-30-2011, 12:19 AM - Thread Starter
winnetout's Avatar
Hello,
I'm new to the Forum and hope to find a solution because right now no one can help me! I already posted this message in the section on Blu-ray and advised me to discuss it here!
I called Oppo support and that of JVC to no avail.
So I have an Oppo BDP93EU and a JVC RS50
The problem is:
When I watch a 3D movie since the Blu-ray player to my Oppo everything works!
When I watch a 3D movie from a USB drive connected to my Oppo does not work!
The problem is that the JVC displays two images side by side and does not project the image in 3D!
I changed the settings on the JVC to force side by side but that does not change.
If I use my Popcorn C200 or my Dvico M6500 to view the film it works (JVC mode side by side).
Does anyone have an idea of the problem?
My Oppo and my JVC have the latest version of Firmware
Thank you in advance and sorry for my English
Winnetout
winnetout is offline
post #2 of 7 Old 06-30-2011, 06:30 AM
Bryan Jozwiak's Avatar
Quoted: 14 Post(s)
Winnetout,
Sorry I cant help but I saw the same behavior with my RS40 and Oppo 93. I hope someone has the answer for this. I look forward to understanding if there is a fix for this.
-- Bryan
Bryan Jozwiak is offline
post #3 of 7 Old 06-30-2011, 06:58 AM - Thread Starter
winnetout's Avatar
Hello Bryan,
I'm glad to see that I'm not the only one to experience this problem even if it did not correct our mistake;-)
Currently I opened a box from Oppo, JVC and to my dealer!
answer:
Oppo: Oppo's team took time to look for or the problem may come but they have not found solutions. Currently on hold.
JVC Pro JVC's team does not understand or can come to the problem but think it comes from the Oppo! JVC proposal, please contact my dealer;-( (That's how you solve a problem with JVC Pro!
My dealer: It will look at whether a customer of the same problem.
Well, I think the Oppo sends a signal when reading the file that is poorly understood on the JVC which captures a 3D movie when it should read like a side by side!
That is, if I have a solution I immediately post on the Forum! Can you do the same.
If someone has the solution or the same problem, that person is welcome
Thank you
post #4 of 7 Old 06-30-2011, 11:53 AM
city's Avatar
Try to force the display to side by side in the JVC hdmi menu.
If this does not work then the look at the setting in your OPPO and try turning the 1080p24 output to off. This works for some files on my system
city is offline
post #5 of 7 Old 07-01-2011, 01:23 AM - Thread Starter
winnetout's Avatar
Hello City
I tried to force on the JVC but it does not work!
Can you tell me where do I change the setting on the Oppo ?(1080p24 output to off)
Thank you for your help and I hope it will work!
Bye
post #6 of 7 Old 07-01-2011, 02:23 AM - Thread Starter
winnetout's Avatar
Hello City
I set the Output Resolution 1080i on the Oppo and configured the 3D JVC side by side and everything works.
Congratulations and thank you for your advice because it works!
Bye and good day
Winnetout
@ Hello Bryan, I think thanks to the help of this City will also work with you!
post #7 of 7 Old 07-01-2011, 11:59 AM
city's Avatar
Your welcome it worked for me and the quality is still top notch enjoy !
city is offline
Jvc Rs50u
